Re: Torsion bars...what do you run? [Re: 383man] #2399126
11/06/17 12:00 AM
11/06/17 12:00 AM
Addison,IL
OUTLAWSSAA Offline
OUTLAWSSAA  Offline
Addison,IL
Six Cylinder bars here.
Re: Torsion bars...what do you run? [Re: hemi_doug] #2399151
11/06/17 01:11 AM
11/06/17 01:11 AM
Penna
70satelliteguy Offline
Penna
".810 MP drag bars in my small block A-body, 3100lbs., that sees street time, and has 600 hp on tap, and then add the nitrous. They are not strong enough, and have too much stored energy, especially for a ladder bar car at this power level"
Moparbilly I have been using MP drag bars purchased from Mancini racing for the past 12 years .BB B Body 3550 lbs. mid 9 sec car with ladder bars.
Maybe I am just lucky but have had No problem holding cars front up to whatever height you adjust them to! Weight transfer seems good.
How would I know if they have too much stored energy?
Mike
Re: Torsion bars...what do you run? [Re: 70satelliteguy] #2399258
11/06/17 11:12 AM
11/06/17 11:12 AM
an8sec70cuda Offline
My cuda still has its factory installed 340 torsion bars.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Torsion bars...what do you run? [Re: madscientist] #2399374
11/06/17 02:40 PM
11/06/17 02:40 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
Originally Posted By madscientist
Originally Posted By dvw
I've had no issue with the stock 6 cylinder bars, 550 passes so far.
Doug
Dam that thing looks good. What rear suspension are you using? Not to hijack the thread lo5l.
36" ladder bar, 130 lb springs, Koni rear/Afco front, doubles.
Doug
