Page 3 of 3 1 2 3
Re: No oil pressure after changing rockers [Re: camastomcat] #2406186
11/20/17 01:59 AM
11/20/17 01:59 AM
gulfport, ms, west mi
rowin4 Offline
rowin4  Offline
Originally Posted By camastomcat
Stupid question but are you sure the oil holes in the shaft are pointed up?
This question was answered on the first page. A question to you, Why would you want the shaft holes up?
I thought that's the way I remember them going, it's been a while.
Most aftermarket have shafts drilled top and bottom , original stock only have one side drilled, it is to be installed down for rocker lubrication.
Re: No oil pressure after changing rockers [Re: Kam*Kuda] #2406188
11/20/17 02:09 AM
11/20/17 02:09 AM
Canada
Kam*Kuda Offline OP
Kam*Kuda  Offline OP
Canada
We got it all sorted out. It was a gauge issue. It is running decent pressure now, after the rocker shafts had the oil pouring out. Running proper pressure again.
Thank you all for the Help.
I did not feel the "wrist twisting" as described but it did read decent pressure with the drill and then I started and its running good pressure
I am going too mock up a second mechanical gauge in the engine bay instead of just the electric gauge in the interior. You cannot be inside the car and in the engine bay at the same time, so I was reliant on my son to read the gauges for me while I was priming
1970 Barracuda Convertible
1968 Satellite Street Strip car
1654.5 Mustang
1955 Land Rover
Re: No oil pressure after changing rockers [Re: Kam*Kuda] #2406328
11/20/17 02:17 PM
11/20/17 02:17 PM
Alexandria, LA
Blucuda413 Offline
Blucuda413  Offline
Alexandria, LA
An easy way to do that is to place unplugged drill and shaft in the pump, use wire to turn drill switch on and then go to where you can see gauge and then plug your drill in. You can basically be in both places at once. It works!!
Re: No oil pressure after changing rockers [Re: Blucuda413] #2406584
11/20/17 11:52 PM
11/20/17 11:52 PM
Australia
O
ozymaxwedge Offline
ozymaxwedge  Offline
O
Australia
panic fan
1963 Plymouth Max Wedge
1971 Barracuda
Re: No oil pressure after changing rockers [Re: Kam*Kuda] #2406592
11/21/17 12:05 AM
11/21/17 12:05 AM
A727Tflite Offline
A727Tflite  Offline
Auto shut off when the drill winds up and pulls the cord out of then wall.
Page 3 of 3 1 2 3
