440 starts & runs bad after sitting for a week
#2395885
10/31/17 06:27 AM
10/31/17 06:27 AM
Posts: 32 New Zealand
RayR
New Zealand
My '73 440 in a street vehicle generally runs great and starts fine after sitting for 1 or 2 days, but if it sits for a week it is very hard to start, backfires and runs really bad for 5 or 10 minutes before "cleaning up". Once clean it runs great again. It has been doing this for close to a year, 5000 miles, but I put it down to poor tuning as I was doing other things.
Now the Thermoquad is great, after a lot of help from this site, and the problem still exists.
Some information, bottom end is old original (200,000 miles +)but still sound, heads were rebuilt with all new parts a year ago, moderately flowed and ports matched. Standard cam. Vacuum is fine with about 17 - 18 ins at 2500rpm cruise (65mph). The low garage temperature is about 50F and when good the car starts without needing choke.
I have one thought but would like to hear what people think could be the problem.
Thanks,
Re: 440 starts & runs bad after sitting for a week
[Re: RayR]
#2395926
10/31/17 10:29 AM
10/31/17 10:29 AM
RapidRobert
that is a strange one! Nothing is hitting me at the moment. is it backfiring out the ex or up thru the carb?
[Re: RayR]
#2395931
10/31/17 10:37 AM
10/31/17 10:37 AM
Posts: 13,380 Marion, South Carolina [><]
an8sec70cuda
Sure the carb isn't leaking down and flooding the engine after a few days? Is the carb empty when this happens? Is it "making oil"?
[Re: RayR]
#2396072
10/31/17 02:55 PM
10/31/17 02:55 PM
Posts: 960 Chicago
PurpleBeeper
Chicago
Another idea that pops into my head is that will 200k on the short block, your rings/cylinder walls are likely a little loose. Do you maybe oil up the plugs causing the engine to run a little rough until the oil burns off? I have no clue why it wouldn't do that EVERY time though.
70 Roadrunner convt. street car
440+6, NOS, 4-spd, SS springs
'96 Mustang GT convt. street car
'04 4.6 SOHC, NOS, auto, lowered
"Officer, that button is for short on-ramps"
[Re: RayR]
#2396299
10/31/17 09:41 PM
10/31/17 09:41 PM
RapidRobert
I had the same problem with the AFB before the TQ went in during the last year. Comments? Am I reading this right, that the eng acted the same with the AFB?
[Re: RayR]
#2396395
11/01/17 12:34 AM
11/01/17 12:34 AM
RapidRobert
before the head work it ran poor & was hard to start & after the head work now it is really hard to start (plus the posted symptoms in the first post?) then a carb swap (to the AFB) & no real change? I wonder if there is a vac leak from the metal valley pan & it runs poor cuz it is lean cuz of the rich(er) mixture required when cold makes it sneeze then when it warms up, a leaner mixture suffices & it is pretty much alot better (tho I wouldn't think a vac leak would be spot on). just thinking out loud. I ain't thinking ign cuz they (when bad) can usually run OK when cold then act up when hot. Keep after it & keep us posted. I love the toughies.
[Re: krautrock]
#2396700
11/01/17 03:12 PM
11/01/17 03:12 PM
RapidRobert
Ray what about blocking the metering rod tree up so it is on the power circuit then starting it & see how it acts & see if that enrichment helps things (not permanent of course but to see if it is way lean).
[Re: RayR]
#2397119
11/02/17 01:08 AM
11/02/17 01:08 AM
RapidRobert
this is gonna be an interesting discovery, tho I'm sure it will be simple once uncovered. (We'll be waiting). Hurry!
[Re: RapidRobert]
#2397137
11/02/17 01:41 AM
11/02/17 01:41 AM
Posts: 954 garnett kansas
rhad
garnett kansas
i had a 390 ford wagon decades ago that acted that way,turned out it had a cracked dist cap!
my ladder of success is missing some rungs
