Page 1 of 3 1 2 3
quench, gasket bore and compressed height #2394226
10/28/17 02:14 PM
10/28/17 02:14 PM
Valencia, España
NachoRT74 Offline OP
Valencia, España
If I'm using Felpro 1039 headgasket with 4.590" bore and 0.051 CH, on a 400 block +0.020" so 4.362" bore... that makes 0.228" bore difference between block and headgasket... this means 0.114" difference between cylinder wall and gasket all around being with 0.051" gap between block and head... will this area affect quench ?
DESPITE ALL THE REST OF DISCUSSION AND GET FOCUSSED ON THIS PLEASE!!!!
ONCE AGAIN!
wondering if this area around the cylinder bore being 0.051" will affect quench efficiency still if my make sit my pistons quench pad still at 0.040 on the 452 heads.
Re: quench, gasket bore and compressed height [Re: NachoRT74] #2394240
10/28/17 03:17 PM
10/28/17 03:17 PM
IN
ahy Offline
ahy  Offline
IN
In short, the bigger bore of the gasket will not affect quench. As long as the piston to cylinder head distance is dialed in you have it.
The larger bore of the gasket does slightly increase total chamber cc's and reduce compression but not a significant impact.
Re: quench, gasket bore and compressed height [Re: ahy] #2394243
10/28/17 03:23 PM
10/28/17 03:23 PM
North Dakota
6PakBee Offline
6PakBee  Offline
North Dakota
I think that the benefit of quench would be affected, but so minimally I doubt you could tell the difference. But practically speaking, other than having a custom head gasket made, what options do you have other than to live with what you have?
Re: quench, gasket bore and compressed height [Re: NachoRT74] #2394244
10/28/17 03:25 PM
10/28/17 03:25 PM
Valencia, España
Valencia, España
I can't afford $100 per gasket, plus international shipping
other options... use the felpro kit gaskets ( 0.039 ) and felpro copper shims ( 0.020 ), decking block even lower ( 0.010 more ). All thse parts in hands.
reduce CR will be a benefit in fact
Re: quench, gasket bore and compressed height [Re: NachoRT74] #2394457
10/28/17 11:38 PM
10/28/17 11:38 PM
North Dakota
6PakBee Offline
6PakBee  Offline
North Dakota
I guess what I meant with living with what you have is that once you are at minimum quench distance, other than having a custom gasket made to your bore size, you are pretty much out of options. Sorry I wasn't clearer.
Re: quench, gasket bore and compressed height [Re: NachoRT74] #2394470
10/28/17 11:50 PM
10/28/17 11:50 PM
Pattison Texas
CSK Online shake_head
CSK  Online Shake_Head
Pattison Texas
It will be ok.
Re: quench, gasket bore and compressed height [Re: 6PakBee] #2394620
10/29/17 03:48 AM
10/29/17 03:48 AM
Valencia, España
Valencia, España
Cool!
Re: quench, gasket bore and compressed height [Re: CSK] #2394621
10/29/17 03:48 AM
10/29/17 03:48 AM
Valencia, España
Valencia, España
Originally Posted By csk
It will be ok.
Good to know
Re: quench, gasket bore and compressed height [Re: NachoRT74] #2394668
10/29/17 10:39 AM
10/29/17 10:39 AM
USA
3
360view Offline
Moparts resident spammer
360view  Offline
3
USA
The gasket to bore mismatch will create more "crevice volume" for the air and fuel mixture to be driven into. A lot more gasoline "hides here" in the crevice volume than you might at first suspect, because the rapidly rising pressure "pushes" air and fuel there. The air and fuel might get compressed by the rising piston to 160 psi, but the burning flame front that started near the spark plug can reach 1600 psi as it reaches the outer edges of the cylinder where the crevice volume is. Metal surfaces near the crevice volume "quench out" any flames so this gasoline remains unburned.
People think some of the gasoline remains unburned because the carburetor does not make smal enough droplets.
It is truer to say that some of the gasoline remains unburned because it hides near cool metal walls in the crevice volume.
Even natural gas and propane engines have unburned fuel because of crevice volume.
Glowing Hot carbon deposits
can also build up at the edges of crevice volumes,
and these can potentially set off the air/fuel to burning ( preignition)
before the spark plug fires.
Piston ring land is another crevice volume.
Newer design "Direct Injection" engines get an advantage when at the last moment they spray fuel into hot compressed air only near the spark plug. Oxygen has to come inward toward this centered "flame Kernel". Fuel gets very little time to move outward to "hide" in whatever crevice volume is out there. The crevice volume ends up with mostly Nitrogen gas in it when Direct Injection is used.
(on the downside the air passages in the intake manifolds of DI engines and intake valve backsides tend to fill up with crudy deposits since there is new liquid fuel to rinse them off)
Re: quench, gasket bore and compressed height [Re: NachoRT74] #2394738
10/29/17 12:46 PM
10/29/17 12:46 PM
Valencia, España
Valencia, España
And that does mean?
Re: quench, gasket bore and compressed height [Re: 360view] #2394783
10/29/17 01:36 PM
10/29/17 01:36 PM
I'm thinking that a gasket bore clos(er) to the bore perimeter would be a somewhat more efficient eng by eliminating the unburned fuel/air in the aforementioned "crevice volume" but this does not make/break quench efficiency that you asked about since the piston plateau/head interface (the quench area) is inward further from that perimeter. A gasket with a smaller bore would get a person closer to a "spot on" engine but whether it would be worth it to you to add that expense I cannot say. Just me I sleep better at night (& function better in the day) knowing I built the most efficient eng that my knowledge (& the collective knowledge of my fellow Moparts brothers) will allow me to accomplish (& my budget!). I gotta go, some hand egg is on the menu for this morning.
Re: quench, gasket bore and compressed height [Re: NachoRT74] #2394842
10/29/17 02:52 PM
10/29/17 02:52 PM
Valencia, España
Valencia, España
yes! I'm pointing out in the future to the cometic headgasket on 4.380 bore 0.051 thickness, but can't make it now. Headgaskets are easy to replace in a close future though, but need to assembly the car ASAP which what I have in hands right now
http://www.cometic.com/i-24768321-chrysl...-bore-each.html
it seems after several decking block corrections I can get pistons around 0.010-0.013 out of the bore... IF FINALLY THEY MAKE IT RIGHT!
will need to equalize the quench pads on combustion chambers too ( it seems the deeper one is around 0.120", then maybe cut some ( 0.020" ) the heads to get that area on 0.095-0.100" deepness rate to match the KB215 pistons quench pad step
Re: quench, gasket bore and compressed height [Re: NachoRT74] #2394851
10/29/17 03:04 PM
10/29/17 03:04 PM
Valencia, España
Valencia, España
by I could understand that "crevice volume" area is prone to preignition due carbon deposits there becoming on a pocket for them! sooooo... the quench job could be a lost job getting another problematic area now.
Re: quench, gasket bore and compressed height [Re: NachoRT74] #2394858
10/29/17 03:11 PM
10/29/17 03:11 PM
Valencia, España
Valencia, España
well thinking it now, the regular 0.039 headgasket is also bigger bore, just not that big ( barelly 0.050 to my actual cylinder bore, 3/4 less than the 1039 gasket), but still becoming on a pocket for carbon deposits
Re: quench, gasket bore and compressed height [Re: NachoRT74] #2395005
10/29/17 07:32 PM
10/29/17 07:32 PM
MYRTLE BEACH SOUTH CAROLINA
E
ek3 Offline
ek3  Offline
E
I think you are over thinking this... the - CORRECT - swirl ratio will clean all un-burned gases from the chambers... the small area you refer to would simply be unused fuel...[ if you are worried about unburnt gases ] focus on proper combustion chamber shape and piston that works with it and the proper intake port shapes ,,, that problem is gone.. proper quench will reduce burn time , lower octane requirements, lower the overall timing advance needed, resulting in more complete burn..it also reduces the pressure rise in reverse with respect to the crankshafts angle to tdc...that's why most swirl heads make best power with 32* timing ...
Re: quench, gasket bore and compressed height [Re: ek3] #2395257
10/30/17 10:57 AM
10/30/17 10:57 AM
Valencia, España
Valencia, España
yes, probably you are right, but an opportunity to learn about
I still dunno about all this tech stuff and therms about, combustion, ignition times and everything related.
I was mainly worried about preignition ( pinging ) problems due this pocket around cylinder using this bore diameter gaskets after work on all the quench stuff.
Re: quench, gasket bore and compressed height [Re: NachoRT74] #2395438
10/30/17 03:45 PM
10/30/17 03:45 PM
dogdays Offline
dogdays  Offline
When you get the squish distance correct, the air that squirts out of the squish zone should move at least some of the air/fuel out of the crevice volume. Think about it - unless you have built some directional flow in the in the squish zone, the air rushes out of the chamber past the piston top in all directions. That should move things around in that gap.
You are absolutely correct to suspect that the additional crevice volume could cause knock. When the air/fuel is heated and the chemical reaction starts, pressure and temperature increase. The fuel decomposes and forms knock causing compounds. A squish chamber moves the flame around so combustion takes place more rapidly, faster than the new compounds can autoignite. No knock.
In a chamber with no squish and a pretty static volume of air/fuel, it will take the flame much longer to get to those areas farther away from the spark plug. The new compounds then have the time to autoignite and you have knock.
R.
Re: quench, gasket bore and compressed height [Re: NachoRT74] #2395575
10/30/17 07:14 PM
10/30/17 07:14 PM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
Instead of using .039 and a shim just cut the open part of the chamber deeper and do not use the shim. That area of the chamber is .300 thick, taking an extra .020 out of that area will not be a problem.
Re: quench, gasket bore and compressed height [Re: NachoRT74] #2395805
10/31/17 12:43 AM
10/31/17 12:43 AM
Valencia, España
Valencia, España
dogdays:
yes that was my thought, but my doubt was that because per what I have read on several places the quench/squish area can be on 0.050" rate and still be good even the advice is around 0.040"
John:
that could be good too! and will make to keep the heads unmilled, saving from ANOTHER mistake from machine shop. However that could make also to get really close the piston diameter out of the quench pad close to the head around the combustion chamber to allmost 0.020" I think... isn't that some dangerous ? I recall the combustion chamber bore is sligthly smaller bore than the cylinder bore... isn't ?
Wouldn't actually need to cut 0.020" but maybe the 0.010-12 extras the thicker felpro headgaskets got with bigger bore, and keep using the 0.39 with small bore... in another words, cut the combustion chamber quench area same ammount the pistons leaves the deck. Maybe in fact they are actually close to what I need. I'm pretty sure this area is deeper than the piston quench pad height and maybe close to what I need as mentioned on a previous reply.
I will know just once the block is correctly decked and once assembled measured with clay
Re: quench, gasket bore and compressed height [Re: NachoRT74] #2396024
10/31/17 01:20 PM
10/31/17 01:20 PM
Valencia, España
Valencia, España
making maths without actual measurements yet...
If I have to get the quench area deepness on heads equalized up to .120" taking the deeper one as a starting point( to be confirmed, thats was a rude measurement I made once ), plus .039" of gasket makes .159"
less .095" of piston step and .012" ( or so ) of pistons leaving the deck... total 0.052" of quench. It seems not to be bad. To be used on 95 octanes gas in Vzla, and once move to Spain, probably 98 octanes
Definitelly I'm overthinking the deal with the 0.051 gasket!!!
just thinking on the area out of the combustion chamber, being smaller than the piston bore, that should be on 0.027" rate. Am I fine with it ?
That will get me also the static CR close to 10.5 on the iron heads.
I have 6 and 7 NGKs heat range spark plugs to play... also platinum Bosch plugs WR9FP
Opinions
Page 1 of 3 1 2 3
