Re: went to track today [Re: coronetkid] #239438
03/01/09 03:49 PM
03/01/09 03:49 PM
Newark, OH
springers340dart Offline
Newark, OH
before i got the dart i had a 76 aspen r/t with a 340, 904 w/low first gear, 4.30s gears w/ a 28in tall mickey and was runnin 12 teens at 110 while driving it on the street. i think you'll be ok w/ 4.30s, you'll see improvment. it was a 9 1/2 3800 stall 60'in low 1.60s
Re: went to track today [Re: coronetkid] #239439
03/01/09 04:01 PM
03/01/09 04:01 PM
Sk. Canada
RemCharger Offline
RemCharger  Offline
Sk. Canada
i'm running 28 inch tires and i go through the trap at around 6500 rpm in sec gear. i'm basically shifting into 3rd as i cross
Again thats what I did with my street charger but a 3.23 with 26" .. 6500 through traps at a100 in second. That was 13.9-8 . I went to a 4.56 gear (same tires) and a few other things (intake, ditched fan) and went 13.1 at 105 now at 6500 in third..
Know anyone that you could borrow a set of 4.56s off of?
Re: went to track today [Re: RemCharger] #239440
03/01/09 04:12 PM
03/01/09 04:12 PM
Cumberland County, NJ
coronetkid Offline OP
my buddy has a set off 4.88s set up in a 742 case. i have a 741 will they swap in? do you think 4.88s will get me all the way down the track or will i run out of steam before the trap?
Re: went to track today [Re: coronetkid] #239441
03/01/09 04:28 PM
03/01/09 04:28 PM
Sk. Canada
RemCharger Offline
RemCharger  Offline
Sk. Canada
She'll be maxed out.. is the engine balanced?
Or if you could get a cheap set of 29's too
I saw a 742 case 4.56 sure grip in the for sale race section...375$...in the northeast
Re: went to track today [Re: RemCharger] #239442
03/01/09 04:45 PM
03/01/09 04:45 PM
land of 10,000______'s
BDS871Cuda Offline
BDS871Cuda  Offline
It's just to heavy of a car and not enough HP/TQ.
4.10's might get you in the 12's but say good bye
to any highway driving. I would put in a stroker
kit in that 383 (say 496) and let TQ pull you in the 12's.
Then you could run 3.23's and have a good high
way driver.
Snap your neck, mega G-force launch, is all I want!
Re: went to track today [Re: BDS871Cuda] #239443
03/01/09 05:21 PM
03/01/09 05:21 PM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
What carb are you running??
4.10 gears should pick you up 3 or more tenths.
What is your 1/8 mile MPH
two things jump out 60' is poor gear and maybe a TQ will help that a lot. but your 1/4 mph is low for 13.3?? I would think 104 or so would be more in line.
running out of fuel? But maybe a bad torque curve where you are forced to shift into third??
Re: went to track today [Re: Dodgem] #239444
03/01/09 05:39 PM
03/01/09 05:39 PM
Chicken coop
dustergirl340 Offline
Chicken Little
Chicken Little
Chicken coop
I'm running 12.91 @ 103 mph
Re: went to track today [Re: Dodgem] #239445
03/01/09 06:38 PM
03/01/09 06:38 PM
holley 850 dp best run
r/t .262
60' 1.909
330 5.480
1/8 8.482
mph 81.54
1000 11.107
1/4 13.358
mph 100.19
Re: went to track today [Re: coronetkid] #239446
03/01/09 06:52 PM
03/01/09 06:52 PM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
power valve front and back???
Re: went to track today [Re: Dodgem] #239447
03/01/09 08:13 PM
03/01/09 08:13 PM
power valve front only
Re: went to track today [Re: coronetkid] #239448
03/01/09 08:19 PM
03/01/09 08:19 PM
Central NC
gch Offline
gch  Offline
Central NC
That is a lot of carb for a 383.I bet a 750 would pick it up a tenth or more.
Re: went to track today [Re: gch] #239449
03/01/09 09:17 PM
03/01/09 09:17 PM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
I would leave the front jet 79 and use a 87 set in the rear ! try that.
