Re: How to... Proper Tire Heating?? [Re: Kam*Kuda] #2392692
10/25/17 12:59 AM
10/25/17 12:59 AM
Puyallup, WA
StealthWedge67 Offline
Puyallup, WA
I admit I do the no-no and start in 1st. But I do run an LBA valvebody and only just get the tires turning before moving to 2nd while holding it at about 4500 still on the line lock, then into 3rd and let it start to move along, easing out of the brakes I typically git it a little more R’s to keep it moving. I can usually feel the tires start to grab at that point and I let out of it and bring it to a stop. I run my line lock backwards to lock out the rears, so I have full control of the front brakes as it starts moving forward. With an automatic, that just makes so much more sense to me.
As it rolls out I let out of it and put the car on my line as I come to a stop. I always check my gauges at that point, turn off the line lock and turn on the 2-step and the aux. fuel pump. Then move into the pre-stage beams.
I read someone say they “clear the carb” in neutral after the burnout. I believe this unloads the sprag, which I’ve been told is a bad idea and could put it at risk at launch. And really.... whatever is accomplished by ”cleaning out the carb” is something I don’t understand. I would submit that it accomplishes nothing.
Re: How to... Proper Tire Heating?? [Re: Kam*Kuda] #2392717
10/25/17 01:34 AM
10/25/17 01:34 AM
MN
JERICOGTX Offline
JERICOGTX  Offline
MN
Jeez you guys boil the tires...
69 GTX 68 Road Runner
Re: How to... Proper Tire Heating?? [Re: Kam*Kuda] #2392736
10/25/17 02:28 AM
10/25/17 02:28 AM
Cotati, CA
Dave Hall Offline
Dave Hall  Offline
Cotati, CA
Looked good to me! You could come out of the water a smidge more but otherwise fine. That car hauls the mail! Nice job!
Re: How to... Proper Tire Heating?? [Re: Kam*Kuda] #2392798
10/25/17 10:16 AM
10/25/17 10:16 AM
crabman173
crabman173
Look at Mickey Thompsons website tech--they give exact instructions on how to mount, burn out, etc do like they say and away you go--same with other tire brands--they do publish the correct how to
Re: How to... Proper Tire Heating?? [Re: Kam*Kuda] #2392859
10/25/17 12:49 PM
10/25/17 12:49 PM
Metro Detroit
OUTLAWD Offline
OUTLAWD  Offline
Metro Detroit
The Track workers always seem to want to park you in the water...I always inch up when they turn their back so I am not in the water.
I start it in second, sometimes shifting to third, let off the line lock, then roll out of the gas. Stop, shift to first, roll up to the beams and have at it.
The car still has a stock drum, and a non LBA VB...According to most I should have lost a foot by now, but the car has been together for almost 20 years with the same combo, tons of street miles and stack of time slips. But I will be upgrading the innards this winter...haha
and cleaning out the carb....lol
Faster, Faster until the thrill of speed overcomes the fear of death...
71 Swinger - slowly collecting dust/parts
66 Belv. II - just a streetcar
88 Mustang - turbo LS beater
Re: How to... Proper Tire Heating?? [Re: Kam*Kuda] #2393024
10/25/17 07:15 PM
10/25/17 07:15 PM
northwest USA
N
NANKET Offline
NANKET  Offline
N
northwest USA
You ever revved up an engine with a gas analyzer in the tailpipe?
You are not cleaning out anything folks.
Re: How to... Proper Tire Heating?? [Re: Kam*Kuda] #2393037
10/25/17 07:42 PM
10/25/17 07:42 PM
northwest USA
N
NANKET Offline
NANKET  Offline
N
northwest USA
Pretty brave with a 9 second car all the way off the groove like that. Looking good though next run.
Re: How to... Proper Tire Heating?? [Re: Kam*Kuda] #2393049
10/25/17 08:02 PM
10/25/17 08:02 PM
Can , Nova Scotia , Cape Breto...
caper Offline
caper  Offline
If you have to clean out your carb, it is time to get it fixed or get a new one.
New best 10.18 , 1.40 60 ft 496 Scott Brown built, street driven 3600 lbs,654 hp , 653 ft tq
Re: How to... Proper Tire Heating?? [Re: Kam*Kuda] #2393100
10/25/17 09:50 PM
10/25/17 09:50 PM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
Whacking the throttle and pumping more fuel into it is not "cleaning it out". A better strategy would be to just bring the RPM up to 2.5 or 3k for a few seconds IF it does load up some after the burnout.
Re: How to... Proper Tire Heating?? [Re: NANKET] #2393167
10/26/17 12:26 AM
10/26/17 12:26 AM
Canada
Kam*Kuda Offline OP
Kam*Kuda  Offline OP
Canada
I had no idea what it would run It was faster than I expected
1970 Barracuda Convertible
1968 Satellite Street Strip car
1654.5 Mustang
1955 Land Rover
Re: How to... Proper Tire Heating?? [Re: CMcAllister] #2393168
10/26/17 12:28 AM
10/26/17 12:28 AM
Canada
Kam*Kuda Offline OP
Kam*Kuda  Offline OP
Canada
I am fuel injected I assume I would not have to do that anyways. Would that be right?
1654.5 Mustang
1955 Land Rover
Re: How to... Proper Tire Heating?? [Re: Kam*Kuda] #2393178
10/26/17 12:53 AM
10/26/17 12:53 AM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
I would expect that to be right. No fuel sloshing around in the bowls. No oversize squirters pumping fuel into it.
Re: How to... Proper Tire Heating?? [Re: Kam*Kuda] #2393324
10/26/17 12:52 PM
10/26/17 12:52 PM
Minn
SportF Offline
SportF  Offline
Minn
Gang, that drum in there is perfectly fine, right up onto the micro second that its not.
Driving hard without blast protection is like running across the freeway. You may get away with it forever, or, maybe not.
