Page 2 of 6 1 2 3 4 5 6
Re: All the specs to start your dyno #s guesses! 8^) [Re: BradH] #2389807
10/19/17 01:22 PM
10/19/17 01:22 PM
AndyF Offline
AndyF  Offline
I'd think it would make 700 hp. You have better heads than my 470 and more compression. Your cam is similar to mine. Your headers aren't as good as mine but that shouldn't be more than 10 hp. Not sure about your oil pan, might not be as good as mine but maybe only 5 or 10 hp. My intake manifold is better than yours and I have a few more inches but it should all even out at around 700 hp with a correction factor of 1.00.
Re: All the specs to start your dyno #s guesses! 8^) [Re: BradH] #2389823
10/19/17 01:47 PM
10/19/17 01:47 PM
Missouri
jwb123 Offline
jwb123  Offline
Missouri
for the fun I like your baseline carb Demon RS next pick would be the Holley ultra hp/xp
688hp 652 torque on the demon baseline carb
705hp 667 torque on the Holley ultra
you mentioned 93 octane fuel my engine program shows that it needs more octane, at least 105
And if you have time it shows that it might like the cam installed heads up at 108, instead of advanced to 104.
The ramp rate the dyno guy pulls the engine at will affect the HP numbers as well. I used 600rpm per second ramp rate for the pull.
Re: All the specs to start your dyno #s guesses! 8^) [Re: BradH] #2389825
10/19/17 02:02 PM
10/19/17 02:02 PM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
A few tid bits.....
Water temp will be in the 160's for all the testing.
Weather is supposed to be pretty nice this weekend, so air temps would be mid-60's/70's.
The dyno exhaust isn't really "open".
There are 5" pipes coming off the collectors going through the wall, where they attach to tractor trailer mufflers.
Testing will be done at a 300rpm/sec rate.
Provided everything is still going smoothly at the end of the session, we'll take the "best" carb/spacer combo and make a cold water "bonzai" pull to try for "the big number"....... But we won't use that run for "scoring" wink
How low I can get the water temp will depend on how many runs we have made up to that point, and what the temp of the water in the storage tank has gotten up to......... But I'd expect to be able to get it down into the 110-120deg range.
The cooler temp is usually worth something...... But not always.
I think it would be on this motor though.
Re: All the specs to start your dyno #s guesses! 8^) [Re: fast68plymouth] #2389841
10/19/17 02:32 PM
10/19/17 02:32 PM
PA
Scully Offline
Scully  Offline
PA
Originally Posted By fast68plymouth
A few tid bits.....
How low I can get the water temp will depend on how many runs we have made up to that point, and what the temp of the water in the storage tank has gotten up to......... But I'd expect to be as to get it down into the 110-120deg range.
How many gallons is the water tank.
Re: All the specs to start your dyno #s guesses! 8^) [Re: Scully] #2389860
10/19/17 03:26 PM
10/19/17 03:26 PM
Val-haul-ass... eventually
BradH Offline OP
BradH  Offline OP
FWIW, I'd LIKE to post what I THINK it'll make, and what I HOPE that it makes... but I won't.
First, I don't want to influence anyone's predictions.
Second, if it's an underachiever and doesn't make nearly what I think it should... well, that's for me to think over afterwards.
Re: All the specs to start your dyno #s guesses! 8^) [Re: BradH] #2389885
10/19/17 04:32 PM
10/19/17 04:32 PM
Ontario,Canada
firefighter3931 Offline
Ontario,Canada
Good luck ! A Day at the PRH dyno cell is loads of fun and a real learning experience. cool
Baseline WAG ; 645hp@6900/605tq@5200
Best pull : 658hp@7100/617tq@5400
Re: All the specs to start your dyno #s guesses! 8^) [Re: BradH] #2389904
10/19/17 05:20 PM
10/19/17 05:20 PM
Northeast Indiana
73DAD Offline
73DAD  Offline
Northeast Indiana
750 zillion hp @ 7200 thousand billion rpm and 650 gazillion tq @ 5000 trillion million billion rpm!!!!!!!
Re: All the specs to start your dyno #s guesses! 8^) [Re: 73DAD] #2389998
10/19/17 08:14 PM
10/19/17 08:14 PM
BradH Offline OP
BradH  Offline OP
There's always an optimist around somewhere! laugh2
Y'all have fun with this. Unless something goes t!ts-up between now and Saturday night, this is my last post on this thread until I have some results to show. wave
Re: All the specs to start your dyno #s guesses! 8^) [Re: BradH] #2390000
10/19/17 08:17 PM
10/19/17 08:17 PM
So. Burlington, Vt.
So. Burlington, Vt.
Lots of good guesses so far........ And a pretty big spread from high to low, so I'm sure someone will be pretty close.
Re: All the specs to start your dyno #s guesses! 8^) [Re: BradH] #2390037
10/19/17 09:55 PM
10/19/17 09:55 PM
IL
Dart451 Offline
Dart451  Offline
IL
690 hp 6300 590 tq 5300 base
703 hp 6300 595 tq 5300 best
Re: All the specs to start your dyno #s guesses! 8^) [Re: jwb123] #2390235
10/20/17 11:28 AM
10/20/17 11:28 AM
Central TEXAS!!!!
sr4440 Online content
sr4440  Online Content
Central TEXAS!!!!
FYI if he is using the latest version of windyn, it has an inertia correction factor, if set right, the sweep rate will not mater, 600 rpm vs 300 rpm vs step will lay right over the top of each other.
Explanation: the inertia correction factor is used to correct for the loss of torque as you accelerate the engine internals and related dyno equipment that is connected to the crankshaft. Without this correction you will get different torque reading @ each sweep rate.
Joe
Without Data, you’re just another guy with an opinion.
Re: All the specs to start your dyno #s guesses! 8^) [Re: sr4440] #2390300
10/20/17 02:29 PM
10/20/17 02:29 PM
SoCal
Brian Hafliger Offline
SoCal
680Hp@ 6700 and 610Tq@ 5500 base carb.
695Hp@ 6800 and 615Tq@ 5700 best carb.
Brian Hafliger
Re: All the specs to start your dyno #s guesses! 8^) [Re: BradH] #2390626
10/21/17 12:47 AM
10/21/17 12:47 AM
Brisbane Australia
572B1 Offline
572B1  Offline
Brisbane Australia
Base carb 665Hp@ 6850 590Tq@ 5200
Best carb 680Hp@ 6950 600Tq@ 5300
Re: All the specs to start your dyno #s guesses! 8^) [Re: Brian Hafliger] #2390975
10/21/17 09:40 PM
10/21/17 09:40 PM
The Great White North
RAMM Offline
RAMM  Offline
Peak torque cannot and will not occur at that RPM with the engine specs listed. If it does-dyno is screwy. J.Rob
2009 PHR\EMC Competitor
2010 PHR\EMC Competitor
2011 PHR\EMC Competitor
2012 PHR\EMC Competitor
2013 PHR\EMC Competitor
2014 HotRod/EMC Competitor
2015 HotRod/EMC NoShow
2016 HotRod/EMC 3rd place SPEC Bigblock
2018 HotRod/EMC 7th place G3
Re: All the specs to start your dyno #s guesses! 8^) [Re: BradH] #2391269
10/22/17 03:11 PM
10/22/17 03:11 PM
AndyF Offline
AndyF  Offline
Don't forget to shoot some video with your cell phone.
Re: All the specs to start your dyno #s guesses! 8^) [Re: BradH] #2391303
10/22/17 04:11 PM
10/22/17 04:11 PM
So. Burlington, Vt.
So. Burlington, Vt.
The big dyno day was yesterday.
I told Brad I wouldn't post up any numbers.......but I can say the motor ran well, and we made I think it was 28 pulls without any "incidents".
I'll also reveal that we tried the "cold water" pulls with two different carbs and got nothing out of that either time.
The cooler temps thickened up the oil enough(8-10psi higher oil pressure) to offset any gains from having the heads and intake cooler......so it was a wash.
In hindsight, I probably should have tried a run with "lowered" water temps, instead of the relatively cold temps I tried it at(105-110).
He's driving back home today........so I'd think there should be some results posted tonight.
Re: All the specs to start your dyno #s guesses! 8^) [Re: BradH] #2391322
10/22/17 04:43 PM
10/22/17 04:43 PM
AndyF Offline
AndyF  Offline
I run all of my dyno pulls with 180 degree water temp these days. I used to try and run cooler but eventually just decided it was easier to run everything at 180. I usually try to get the oil to 180 also but it tends to vary more. Sometimes the first pull is at 150 oil temp and then after a few back to back pulls it will get up into the 200 range.
Glad to hear it ran good. 28 pulls in a day is a lot of work, especially if you are swapping parts and then trying to get the engine pulled down and ready for the road.
Re: All the specs to start your dyno #s guesses! 8^) [Re: BradH] #2391327
10/22/17 04:54 PM
10/22/17 04:54 PM
So. Burlington, Vt.
So. Burlington, Vt.
I had a really mild 505 on the dyno last week.......the cold water test on that was a 14tq/8hp gain.
I've seen it change the numbers on a 700-800HP BBC by about 25hp.
Just depends on what it is.
Re: All the specs to start your dyno #s guesses! 8^) [Re: fast68plymouth] #2391387
10/22/17 07:29 PM
10/22/17 07:29 PM
BradH Offline OP
BradH  Offline OP
Greetings from I-81 south of Scranton, PA. Mike ("THESHAKERPROJECT") is driving, so I'll try to post some results from my phone.
Baseline Race Demon 1.42" v, 1/2" open spacers, 34* timing
- 654.5 at 6100, 594 at 4900
- Air-fuel ratio getting progressively richer across 3500 - 7200 test range, even after opening the MABs
Re: All the specs to start your dyno #s guesses! 8^) [Re: BradH] #2391392
10/22/17 07:34 PM
10/22/17 07:34 PM
northern,Ohio,USA
Clanton Offline
Clanton  Offline
northern,Ohio,USA
Can you post a couple tq# from 3k rpm?THX!
