Re: Disc brake conversion questions?
[Re: RapidusMaximus]
#2391106
10/22/17 10:53 AM
10/22/17 10:53 AM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
Discs vs drums.
Where discs shine is in fade and water resistance. Today's cars tend to run seriously undersized rotors with aggressive pads, which is why rotors don't last anymore.
Dry, first time stop, drums can actually out perform discs due to their self energizing capabilities.
Since this is a "resto" you aren't still running skinny bias plies are you? Any brake system is limited by traction. If the brakes are locking up adding more brake will do nothing. If the brakes do not lock up then you have a brake problem.
All that said, I prefer discs and you have more options in regards to pad aggressiveness. I tend to run the factory based 11.75" setup for several reasons. It's cheap, it is well engineered, parts availability is great.
So, are you current brakes capable of locking up the tires?
[Re: Supercuda]
#2391120
10/22/17 11:23 AM
10/22/17 11:23 AM
Posts: 2,412 Weatherford, Texas
RapidusMaximus
Weatherford, Texas
Mickey Thompson P225/70R15 on the front, P295/55R15 on the rear, will lock up the brakes, just takes alot of pedal pressure and seems like in emergency braking situations it really gets your attention...if you know what I mean
1968 Plymouth GTX 1974 Dodge P/U Long Bed Stepside 318 2019 Ram 2500 6.4, auto, 4WD
#2391129
10/22/17 11:37 AM
10/22/17 11:37 AM
Supercuda
About to go away
About to go away
up yours
Sounds more like a M/C issue than anything else. The manual drum M/C should be a 1" bore setup. What is your bore?
[Re: Supercuda]
#2391156
10/22/17 12:06 PM
10/22/17 12:06 PM
RapidRobert
What Supercuda said, see what the bore size is (post it) & I'm assuming the pedal ratio is correct (sounds like all that was unchanged). In addition you might need more aggressive shoes & a bed in procedure (Google it) & does your brake shop arc in shoes?
[Re: RapidRobert]
#2391161
10/22/17 12:12 PM
10/22/17 12:12 PM
RapidusMaximus
Weatherford, Texas
What Supercuda said, see what the bore size is (post it) & I'm assuming the pedal ratio is correct (sounds like all that was unchanged). In addition you might need more aggressive shoes & a bed in procedure (Google it) & does your brake shop arc in shoes? Bore size is 1", good point on the shoe bedding process, the brakes were finished long before the car was driveable and I know now that I neglected to properly break them in...may be time to revisit that...
[Re: Andrewh]
#2391176
10/22/17 12:28 PM
10/22/17 12:28 PM
Supercuda
About to go away
About to go away
up yours
actually I would think you want a smaller bore size if your complaint is amount of force needed to lock it up. there will be more travel, but should be less effort. Power disc brake version is 1.125", manual drum version is 1", so yeah it's smaller. Got to eliminate all the variables to narrow it down.
#2391180
10/22/17 12:35 PM
10/22/17 12:35 PM
RapidRobert
Andrew is right, a smaller bore might be the solution & very few people actually do take the trouble to do a bed in, I just figured it was worth mentioning as it is helpfull. With the MC potential dealt with just me I would get some agressive specialty shoes, they wear out the drums faster but you'll be alive to enjoy it. (sounds like you are "alive" now with your near misses!)
[Re: Supercuda]
#2391181
10/22/17 12:37 PM
10/22/17 12:37 PM
RapidusMaximus
Weatherford, Texas
I was thinking I was just spoiled from driving power disc equipped vehicles, maybe I'll try some new shoes and break them in properly this time before I jump to disc brakes. ![work work](/ubbthreads/images/graemlins/custom/work.gif) Or maybe I just need to slow my arsh down...
#2391198
10/22/17 01:04 PM
10/22/17 01:04 PM
RapidRobert
Or maybe I just need to slow my arsh down... Don't do that (not in this lifetime).
[Re: AndyF]
#2391213
10/22/17 01:51 PM
10/22/17 01:51 PM
RapidusMaximus
Weatherford, Texas
You have 15 inch rims so the 11.75 factory setup should fit on there. Fairly easy to find the parts these days for the conversion. One phone call to Doctor Diff should get you knuckles and adapters and then you just need to swing by the auto parts store for loaded calipers, rotors and hoses. I'll keep that in mind, thanks, on another note, if I converted to disc is there a big stopping difference between power and manual, would prefer not to clutter up the engine compartment with a brake booster if I can get away with it.
#2391231
10/22/17 02:21 PM
10/22/17 02:21 PM
RapidRobert
power mainly reduces the pedal input needed to generate a certain amt of brakeing output force so you're good there.
#2391321
10/22/17 04:39 PM
10/22/17 04:39 PM
Posts: 31,106 Oregon
AndyF
You have 15 inch rims so the 11.75 factory setup should fit on there. Fairly easy to find the parts these days for the conversion. One phone call to Doctor Diff should get you knuckles and adapters and then you just need to swing by the auto parts store for loaded calipers, rotors and hoses. I'll keep that in mind, thanks, on another note, if I converted to disc is there a big stopping difference between power and manual, would prefer not to clutter up the engine compartment with a brake booster if I can get away with it. Manual brakes work fine with the 11.75 rotors. You'll need the right master cylinder size and you'll want to use a high quality brake pad but it will work if you pay attention and do it correctly.
[Re: RapidRobert]
#2391328
10/22/17 04:55 PM
10/22/17 04:55 PM
RapidusMaximus
Weatherford, Texas
Or maybe I just need to slow my arsh down... Don't do that (not in this lifetime). Yeah, forgot how much fun this thing was to drive, I tend to lean on it from time to time ![up up](/ubbthreads/images/graemlins/custom/thumbs_up.gif)
[Re: AndyF]
#2391331
10/22/17 04:57 PM
10/22/17 04:57 PM
RapidusMaximus
Weatherford, Texas
You have 15 inch rims so the 11.75 factory setup should fit on there. Fairly easy to find the parts these days for the conversion. One phone call to Doctor Diff should get you knuckles and adapters and then you just need to swing by the auto parts store for loaded calipers, rotors and hoses. I'll keep that in mind, thanks, on another note, if I converted to disc is there a big stopping difference between power and manual, would prefer not to clutter up the engine compartment with a brake booster if I can get away with it. Manual brakes work fine with the 11.75 rotors. You'll need the right master cylinder size and you'll want to use a high quality brake pad but it will work if you pay attention and do it correctly. Will do, thanks again ![up up](/ubbthreads/images/graemlins/custom/thumbs_up.gif)
