Re: Best way to limit vacuum advance
[Re: AndyF]
#2418627
12/14/17 07:54 PM
12/14/17 07:54 PM
dogdays
In the future, if you are working on a Firecore distributor and want advice, it would help if you mentioned right off the bat that it was a Firecore.
Rick, aka Sparky, AKA Sunroof GTX, IS Firecore, or at least a good part of Firecore. So if he has a comment it would behoove you pay attention.
I agree that the use of springs and vacuum pots is much akin to witchcraft. It is true, also, that electronically setting advance is another level of witchcraft. Electronic setting has one advantage over the spring/slot witchcraft and that is this: You don't have to understand how the black box works, you just have to understand that it does work.
R.
[Re: pjc360]
#2418635
12/14/17 08:04 PM
12/14/17 08:04 PM
Posts: 1,239 Chicago, IL
PLUM_72
Chicago, IL
Is vacuum advance really needed? If so Why?
1972 Dodge Challenger
[Re: PLUM_72]
#2418679
12/14/17 09:14 PM
12/14/17 09:14 PM
Posts: 21,855 Kirkland, Washington
Pacnorthcuda
Is vacuum advance really needed? If so Why? It provides additional advance at part throttle conditions when the engine can take the advance (the additional advance would cause pinging at wide open throttle). The additional advance increases the engine efficiency at part throttle, does not affect WOT.
[Re: pjc360]
#2419123
12/15/17 06:25 PM
12/15/17 06:25 PM
PLUM_72
Chicago, IL
I was curious on vacuum advance as the new FBO distributors have vacuum advance. Their mod years ago was adjusting the advance profile and eliminate vacuum advance on the distributor.
[Re: PLUM_72]
#2420783
12/19/17 02:41 AM
12/19/17 02:41 AM
Posts: 1,379 Houston,Tx.
Lee446
Houston,Tx.
To limit the vacuum advance arm travel, I set my initial where I want it, use a timing light and a mighty vac hand pump to pull in an additional 10* and note the amount of vac required for the 10*, pop the cap off, pump the vac to noted amount, mark the vac advance arm with a sharpie right where it passes through the housing, pick a appropriately sized short roll pin and drill the correct sized hole through the arm where you marked it. Drive the pin in and you now have a mechanical stop on the vac advance.
[Re: Lee446]
#2420798
12/19/17 03:11 AM
12/19/17 03:11 AM
RapidRobert
^^^ Ding ding ding I do believe we have a winna.
