Re: VENT TUBES ON YOUR CARBS.......... [Re: ToddP] #239076
02/28/09 09:19 PM
02/28/09 09:19 PM
sc
tjmarcus1 Offline
tjmarcus1  Offline
sc
dom, i've never had a prob with the carb sealed. if it's not sealed or if you are not running a hood, then you might need those ugly hoses. either way, don't put the slot on the bottom of the curve. i don't like the hoses because i don't like anything messing with airflow.
Re: VENT TUBES ON YOUR CARBS.......... [Re: tjmarcus1] #239077
02/28/09 09:30 PM
02/28/09 09:30 PM
back in Georgia
dthemi Offline
dthemi  Offline
back in Georgia
The neatest ones I've seen are 180 tight radius bends of tubing the same size as the vent tubes connected with compression fittings pointing down at the carb.
Re: VENT TUBES ON YOUR CARBS.......... [Re: MR_P_BODY] #239078
02/28/09 09:52 PM
02/28/09 09:52 PM
State of confusion
Thumperdart Offline OP
State of confusion
Lots of ideas here.........I don`t know all of the specs on these metering blocks as far as the holes you mention but I`m taking the carb apart to fully clean and re jet so I`ll check. My carb is sealed to the scoop and actually picks up 1 mph and a bit of et w/out the air filter so that`s how I race it. Thankxx guys.
Re: VENT TUBES ON YOUR CARBS.......... [Re: Thumperdart] #239079
02/28/09 10:49 PM
02/28/09 10:49 PM
sc
tjmarcus1 Offline
tjmarcus1  Offline
sc
did you say it picks up et and mph without the seal?
Re: VENT TUBES ON YOUR CARBS.......... [Re: tjmarcus1] #239080
02/28/09 10:53 PM
02/28/09 10:53 PM
State of confusion
State of confusion
Sorry tj, I just fixed it.
Re: VENT TUBES ON YOUR CARBS.......... [Re: Thumperdart] #239081
02/28/09 11:10 PM
02/28/09 11:10 PM
sc
tjmarcus1 Offline
tjmarcus1  Offline
sc
not trying to hi-jack, but did i tell you i have a 72 dart? [actually, it's my son's that i bought for him when he was maybe 16]
Re: VENT TUBES ON YOUR CARBS.......... [Re: tjmarcus1] #239082
03/01/09 12:08 AM
03/01/09 12:08 AM
State of confusion
State of confusion
72 Darts rock don`t you know. I got your photos....nice stuff thankxx.
