Re: Demon build
[Re: Quickrunner]
#2481637
04/12/18 02:10 PM
04/12/18 02:10 PM
Posts: 625 Indianapolis In. usa
Quickrunner
I had this jewel custom made to my specs locally here at Saldana Racing. They did and awesome job!
05 Ram 1500 Daytona package 71 Demon Gen3 hemi drag radial project
Missin' my 9 second 70 runner!
Re: Demon build
[Re: Quickrunner]
#2486813
04/23/18 01:31 PM
04/23/18 01:31 PM
Quickrunner
Got a little fab work done this weekend. Cut out core support, fabbed a removable lower rad mount, and working on new clean sheet metal sides for the core support.
Re: Demon build
[Re: Quickrunner]
#2512816
06/24/18 11:42 PM
06/24/18 11:42 PM
Quickrunner
Made bracket to mount Killer Chiller behind headlight under fender. This little baby will super cool the supercharger intercooler fluid via the AC!
Re: Demon build
[Re: Quickrunner]
#2521044
07/12/18 02:40 PM
07/12/18 02:40 PM
Quickrunner
Intercooler reserve tank for the Whipple I designed and had my buddy weld up. Its 2 1/2 gal per Killer Chiller recommendation. Mounts on inner fender recessed in at bottom.
Re: Demon build
[Re: Quickrunner]
#2521045
07/12/18 02:49 PM
07/12/18 02:49 PM
Posts: 11,710 Portage,michigan
B3422W5
Portage,michigan
Dave...... you coming to Norwalk?
69 Dart GTS A4 Silver All steel, flat factory hood, 3360race weight 418 BPE factory replacement headed stroker, 565 lift solid cam Best so far, 10.40 @127 1/4 1.41 best 60 foot 6.60 at 103.90 1/8
Re: Demon build
[Re: Quickrunner]
#2521396
07/13/18 11:07 AM
07/13/18 11:07 AM
Posts: 1,942 Metro Detroit
OUTLAWD
Metro Detroit
Interesting. I hadn't seen the Killer Chiller before. Just a heat exchanger that uses the AC to cool the CAC water? could be better from a packaging standpoint than adding a cool circuit radiator up front
Faster, Faster until the thrill of speed overcomes the fear of death...
71 Swinger - slowly collecting dust/parts 66 Belv. II - just a streetcar 88 Mustang - turbo LS beater
Re: Demon build
[Re: OUTLAWD]
#2521547
07/13/18 06:35 PM
07/13/18 06:35 PM
Quickrunner
Interesting. I hadn't seen the Killer Chiller before. Just a heat exchanger that uses the AC to cool the CAC water? could be better from a packaging standpoint than adding a cool circuit radiator up front Exactly why I went with it, eliminates the heat exchanger in front of rad. Most of their kits say to remove factory exchanger for best results. I obviously went with their builder universal kit. The owner/designer was cool to work with on the phone. Lots of modern blower cars using this setup.
Re: Demon build
[Re: Quickrunner]
#2528486
07/29/18 01:00 AM
07/29/18 01:00 AM
Quickrunner
Intercooler tank mounted, pump bracket made, killerchiller unit mounted all in fenderwell.
