Re: Project VIP to drag week 2017
[Re: jyrki]
#2390185
10/20/17 03:26 AM
10/20/17 03:26 AM
Posts: 2,933 Finalnd, Perkele
jyrki
Finalnd, Perkele
Once I get the heads back, I'll measure the valves. The ones in the extra set seemed pretty new, and they were smaller than in the other set.
Plynouth VIP '67 TT IC EFI
[Re: jyrki]
#2390280
10/20/17 01:43 PM
10/20/17 01:43 PM
Posts: 14,513 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
The Manley 11223 is a 6.7" long "blank" with a 2.060" head for extreme duty exhaust use.
It is machined to the desired diameter, length, and groove configuration as needed.
Lash caps not required.
[Re: fast68plymouth]
#2390413
10/20/17 06:54 PM
10/20/17 06:54 PM
birdtracker
So I am assuming I would have to call Manley and they would make the exhausts if I wanted new? Is this a stainless blank? thanks Birdtracker
[Re: jyrki]
#2390488
10/20/17 08:58 PM
10/20/17 08:58 PM
Posts: 2,540 Milwaukee WI
TRENDZ
Milwaukee WI
No. Not stainless. Inconel. The stuff high temp smoke stacks are lined with, and turbine wheels in turbochargers are made of.
[Re: jyrki]
#2573897
11/04/18 03:14 PM
11/04/18 03:14 PM
jyrki
Finalnd, Perkele
Now ti seems that since we had pretty much material from the trip, they are going to make a 10 episode series of our trip in a national channel. The only difficulty I can see with it is, that they can't show any people smoking or drinking alcohol, the politics of the channel. I think there is a chance to see it in the net too, but of course it's mainly in Finnish at least the first episode which I have seen a part of.
