Re: All the specs to start your dyno #s guesses! 8^)
[Re: BradH]
#2391399
10/22/17 07:42 PM
10/22/17 07:42 PM
BradH
QFT 1.52 downleg, 38*, 2" Super Sucker - 684.2 at 6800, 606.2 at 5000 - the "Big Number Run" although I would not be able to use a 2" spacer with an air cleaner, even with my raised T/A scoop
[Re: BradH]
#2391420
10/22/17 08:27 PM
10/22/17 08:27 PM
Posts: 2,860 Pattison Texas
CSK
Pattison Texas
I am very surprised it liked 38* timing.
[Re: BradH]
#2391423
10/22/17 08:36 PM
10/22/17 08:36 PM
Posts: 14,498 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
We ended up putting 5 different carbs on the motor, and all were briefly tested for part throttle operation. At a variety of low loads(35-80-ish hp), at a variety of rpm's(2200-3200), looking at A/F ratios being displayed from the flow turbines and a Daytona Sensors wide band showed that none of the 5 had what either of us considered "acceptable" part throttle operation...... with the best of them being in the low-12's, and some in the 11.0-11.2 range. They worked perfectly well to use on a "race car", but wouldn't be the hot ticket on the street(in their current configuration).
I can't believe I'm going to say this........but........this is an example of a good argument for EFI.
[Re: Clanton]
#2391430
10/22/17 08:49 PM
10/22/17 08:49 PM
fast68plymouth
So. Burlington, Vt.
Can you post a couple tq# from 3k rpm?THX! The pulls were started at 3500. Once we started to get it dialed in, the tq at 3500 was a little over 500. Things didn't really start to happen until it was closer to 4K.
[Re: BradH]
#2391444
10/22/17 09:11 PM
10/22/17 09:11 PM
Posts: 1,051 The Great White North
RAMM
You did better than I thought on HP but I was fairly close on my TQ guess. IFR and PVCR circuits are always too big it seems for part throttle operation. Good job Brad and Dwayne and thankyou for sharing this. Brad your big block is going to feel like a supersized small block with this power and RPM. J.Rob
2009 PHR\EMC Competitor 2010 PHR\EMC Competitor 2011 PHR\EMC Competitor 2012 PHR\EMC Competitor 2013 PHR\EMC Competitor 2014 HotRod/EMC Competitor 2015 HotRod/EMC NoShow 2016 HotRod/EMC 3rd place SPEC Bigblock 2018 HotRod/EMC 7th place G3
[Re: CSK]
#2391454
10/22/17 09:42 PM
10/22/17 09:42 PM
Posts: 2,463 Sydney,Australia
tex013
Sydney,Australia
I am very surprised it liked 38* timing. my 440 liked the same 38/39. my 505 is 35 iirc a function of efficiency Well done Brad and Dwayne , good to see the results Tex
New best ET 10.259@129.65 . New best MPH 130.32 Finally fitted a solid cam, stepped it up a bit more 3690lbs through the mufflers New World block 3780lbs 10.278@130.80 . Wowser 10.253@130.24 footbraking from 1500rpm Power by Tex's Automotive
[Re: fast68plymouth]
#2391480
10/22/17 10:22 PM
10/22/17 10:22 PM
Posts: 31,033 Oregon
AndyF
I can't believe I'm going to say this........but........this is an example of a good argument for EFI. Yep, Holley carbs are almost always rich in the mid-range. On the dyno you can crutch it by turning the idle screws in since you don't usually need the idle circuit on the dyno. On a street car it needs to be sorted out. On the dyno we typically use the idle screws to get the mid-range cleaned up and then use the main jets for WOT. It takes way too much time to mess with the PVCRs during testing. Besides, it all changes once the engine goes in the car so no reason to mess with the carb twice. And I agree with your EFI comment. Once you start tuning EFI engines you'll wonder why people waste their time with carbs!
#2391484
10/22/17 10:25 PM
10/22/17 10:25 PM
Posts: 4,243 Charlotte, North Carolina
sgcuda
Why do you say that? Just because nobody had time to fix a part throttle lean issue? An EFI system with a lean part throttle concern is still going to need calibration also. 5 minutes booting up a laptop or 5 minutes changing a bleed. I had someone drive over their laptop on a test day. Guess how much data we got that day?
[Re: tex013]
#2391489
10/22/17 10:31 PM
10/22/17 10:31 PM
BradH
Still about 2 hours out from home & Mike's driving again.
Miscellaneous comments...
I wasn't expecting it to want that much ignition advance. My Stage VIs' sweet spot was 35, which is why we started out about there. But we weren't seeing the results until bumping it up; 36 was better than 34, but 38 was better yet.
The Race Demon fuel curve made no sense given what I'd seen before. We went from .026 MABs to .028, but it wasn't much change. At that point we yanked it off and started testing other carbs.
Things that ended up NOT like I'd expected: - More torque by about 20 #s... and the peak RPM wasn't really any different than where it was for the old combination
- Harder to get "big" HP numbers, and I'd been HOPING we might be closer to 700, although Dwayne & I agreed it "should" make 670+ before it was tested
- Peak HP RPM... thought it would be around 6500... didn't think the small CSA heads and moderate cam would keep pulling that high
- NONE of the carbs were really "right", even after some tweaking
- The 1.52 downleg needed WAY more jet than I thought it should; we also appear to have maxed out fuel flow capacity of the metering blocks used, since adding more secondary jet stopped much in secondary fuel flow increases before we got to the 98s
- Enough of the carb stuff I saw didn't make sense to me that I ended up stealing Quick Fuel's tune (as much as I knew, at least) for the 1.59 v annular rather than use what I'd intended
[Re: sgcuda]
#2391496
10/22/17 10:39 PM
10/22/17 10:39 PM
BradH
Why do you say that? Just because nobody had time to fix a part throttle lean issue? An EFI system with a lean part throttle concern is still going to need calibration also. 5 minutes booting up a laptop or 5 minutes changing a bleed. I had someone drive over their laptop on a test day. Guess how much data we got that day? The part-throttle was rich on all of them, not lean, and really out of normal range in at least one case. It was a loooong day. Met Dwayne a the dyno at 8:00 AM, last pull was close to 7:30 PM. Then time to break it all down, etc.
[Re: BradH]
#2391509
10/22/17 10:53 PM
10/22/17 10:53 PM
Posts: 9,225 Charleston
sixpackgut
Drag Week Mod Champion
Charleston
What did i win?
Stopping in Hazleton for some Senapes Pitza would have been a nice prize
Gen 3 power 6.22@110, 9.85@135 Follow @g3hemiswap on instagram
[Re: BradH]
#2391516
10/22/17 11:01 PM
10/22/17 11:01 PM
fast68plymouth
So. Burlington, Vt.
The part-throttle was rich on all of them, not lean, and really out of normal range in at least one case. And not just a little rich either........some were way way rich with light loads simulating highway driving. Under those conditions, the main circuit is already flowing plenty of fuel,........and you're not going to lean out the mixture by 3.5 points by tweaking an air bleed. All the carbs had a tendency to richen up throughout the run(both the turbines and O2 agreed).......some worse than others. - Enough of the carb stuff I saw didn't make sense to me that I ended up stealing Quick Fuel's tune (as much as I knew, at least) for the 1.59 v annular rather than use what I'd intended And, as I recall, it seemed to have the flattest fuel curve.
#2391520
10/22/17 11:08 PM
10/22/17 11:08 PM
Posts: 2,094 central texas
krautrock
central texas
The part-throttle was rich on all of them, not lean, and really out of normal range in at least one case. And not just a little rich either........some were way way rich with light loads simulating highway driving. Under those conditions, the main circuit is already flowing plenty of fuel,........and you're not going to lean out the mixture by 3.5 points by tweaking an air bleed. All the carbs had a tendency to richen up throughout the run(both the turbines and O2 agreed).......some worse than others. this might be why some of the carb tuners talk about all the newer bodies such as QFT and the variants need transfer slot restrictors in the bodies?
[Re: BradH]
#2391521
10/22/17 11:10 PM
10/22/17 11:10 PM
fast68plymouth
So. Burlington, Vt.
I'm sure that would help with the part throttle.
#2391524
10/22/17 11:15 PM
10/22/17 11:15 PM
BradH
I'm sure that would help with the part throttle. Dude! Still about 30 minutes from home... at least we're in the right state now.
