Re: Carb vs EFI... a decision I am contemplating [Re: DaveRS23] #2389799
10/19/17 01:10 PM
10/19/17 01:10 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Originally Posted By DaveRS23
Originally Posted By Thumperdart
Originally Posted By Paul_Fancsali
Carbs if right are generally faster then aftermarket TBI just a thought.
Yep, and EASY to tune if you don't mind installing a wide-band and making a few tweaks............ whistling
Thumper can get a carb 'happening' for less than half the EFI money. When EFI gets close to carb prices and uses a dry manifold, I might just consider it.
Don't know what the EFI systems run $$ wise and don't care either way but do what you need to do AFTER you try the new and improved main body......... apimp
Re: Carb vs EFI... a decision I am contemplating [Re: Jeepmon] #2389827
10/19/17 02:06 PM
10/19/17 02:06 PM
Sunnyvale, CA
Jeepmon Offline OP
Jeepmon  Offline OP
Sunnyvale, CA
Thanks everyone... Thanks for your advise and suggestions.. !!
There are many aspects of the EFI that I like and would love to incorporate into my car... but at this time, I will take the wisdom of those that have told me not to convert over.. at this time..
I will give the carb another shot and see if I can get it to work to where I'm happy with it...
Thanks again for answering questions and giving your insight
Re: Carb vs EFI... a decision I am contemplating [Re: Jeepmon] #2389864
10/19/17 03:38 PM
10/19/17 03:38 PM
Cranberry Twp PA (North of Pit...
rumblefish72 Offline
Ok - follow your gut instinct ... but check out this dyno run of the pump gas Hemi that I had MM finish up for me back in the spring: https://youtu.be/95gZTspdzsg
It starts right up, idles real nice and learned it's own tune over several dyno pulls. That's a dual throttle body FAST EZ-EFI 1.0 up on top. 888 HP @ 6300 RPM ... I just need to find the other 12 ponies so I can say I have a 900 HP street engine!
1972 Pro-Street 'Cuda, 500" Eagle stoker B Block, Eddy RPM heads, Victor Manifold, 850 Mighty Demon, Hemi 4 Speed, Dana 60 w/4.88 gears - Built by Hansen Racing Middlesex - NJ
Re: Carb vs EFI... a decision I am contemplating [Re: Jeepmon] #2389874
10/19/17 04:17 PM
10/19/17 04:17 PM
Sunnyvale, CA
Jeepmon Offline OP
Jeepmon  Offline OP
Sunnyvale, CA
Motor sounds awesome... and whats 12 HP between friends.. You have a nice 900 HP motor
Re: Carb vs EFI... a decision I am contemplating [Re: Jeepmon] #2389918
10/19/17 05:43 PM
10/19/17 05:43 PM
Cotati, CA
Dave Hall Offline
Dave Hall  Offline
Cotati, CA
Send the carb to Dom at Thumper carbs Jeepmon. Do you go to Sac. or Sonoma? Do I know you?
Re: Carb vs EFI... a decision I am contemplating [Re: Jeepmon] #2389974
10/19/17 07:24 PM
10/19/17 07:24 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
Carb has worked fine when I'm there smile Just take that POS off and send it to me. Ill send you a Division winning one to replace it, was good enough to be in a ton of finals racing .90 should be good enough for you. Oh yeah loose the lexan scoop or start cleaning your air bleeds AT EVERY RACE!!! We live and race at places that are filled with dirt, it don't take much to clog a .029" hole...My guess is you already had someone try to make it better and they either lost the intermediate circuit or put a HUGE bleed in there. That aint the way to make it happy on the stop...
Oh yeah don't waste the time energy and money to go EFI, unless you just have to be different. If it was more consistent every bracket and class hitter in the country would run it. Also inline stops=crap for consistency especially for cars on the stop for a fair amount of time. Once again if it was the hot ticket Bogacki and every other racer in S/G, S/C and S/ST would have already done it.
But what do I know...
Re: Carb vs EFI... a decision I am contemplating [Re: Triple Threat] #2389975
10/19/17 07:26 PM
10/19/17 07:26 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
Originally Posted By Triple Threat
I'd bolt a different Carb on it long before I attempted that switch. We have 1 person in D6 with Holley EFI on their 145mph SST car and he has told me it is a struggle to make it work.
I have offered one up more than once....And if he was pout winning every round he would not be alone smile
Re: Carb vs EFI... a decision I am contemplating [Re: Al_Alguire] #2389984
10/19/17 07:49 PM
10/19/17 07:49 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Ya, do this and enjoy the blubbery ass 3-circuit crap that MOST don't need or even understand............Gimme a break..........Forest has a 2-circuit and runs a stop and did I mention he just won a wally.......... down whistling drinking
Re: Carb vs EFI... a decision I am contemplating [Re: Jeepmon] #2389991
10/19/17 08:06 PM
10/19/17 08:06 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
Dom and INLINE stop and a baseplate stop are TWO completely different things. Re read what I wrote...
Oh yeah I have a pile of Wallys too, but how was that possible with three circuit junk, that Bogacki guy does ok with his too since we are gimmmeing us a break smile
Re: Carb vs EFI... a decision I am contemplating [Re: Al_Alguire] #2390005
10/19/17 08:36 PM
10/19/17 08:36 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
I'm no expert on any of the stops cos that's not my thing and makes no sense in my mind having a fast car and slowing it down but whatever werkz..............Even BLP likes 2-circuits fwiw up to 1200-1300 hp but I'm still learning everyday and will continue to till I croak......... realcrazy thumbs
Re: Carb vs EFI... a decision I am contemplating [Re: Jeepmon] #2390031
10/19/17 09:34 PM
10/19/17 09:34 PM
Sunnyvale, CA
Jeepmon Offline OP
Jeepmon  Offline OP
Sunnyvale, CA
Thanks Al for you offer to borrow a carb.. Thanks Dom for your suggestions..
For now, I think I will stay with the stuff I got and see if I can make it work..
Re: Carb vs EFI... a decision I am contemplating [Re: Jeepmon] #2390040
10/19/17 10:01 PM
10/19/17 10:01 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Anytime and if you post your tune maybe we can help ya out but like Al said, a clogged bleed or any vital passage as small as they are can end your day and have you chasing your tail....... beer
Re: Carb vs EFI... a decision I am contemplating [Re: Jeepmon] #2390138
10/20/17 01:11 AM
10/20/17 01:11 AM
Cotati, CA
Dave Hall Offline
Dave Hall  Offline
Cotati, CA
Didn't realize Jeepmon was Don! It all makes sense now...The "lexan scoop" thing gave you away Don.
Re: Carb vs EFI... a decision I am contemplating [Re: Jeepmon] #2390264
10/20/17 12:51 PM
10/20/17 12:51 PM
Renton Washington
Triple Threat Offline
Renton Washington
Lexan scoops win races in my neck of the woods smile
-Dustin
67 Dart, 9 second, 392" G3 Hemi
68 Barracuda 340 F/SA
Re: Carb vs EFI... a decision I am contemplating [Re: Triple Threat] #2390637
10/21/17 01:41 AM
10/21/17 01:41 AM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
in your neck of the woods you don't race at dusty facilities either. Unless you count Boise as High Desert dust..lol...
