Re: Cost vs benefits of a counterweighted crankshaft
[Re: sgcuda]
#2389128
10/18/17 02:39 AM
10/18/17 02:39 AM
Posts: 43,722 Bend,OR USA
Cab_Burge
I bought a old Bryant top fuel full counter weighted 4.250 stroke years ago, it had spun the #1 and 2 rod bearings on the original Mopar size rod journals. I had it magged and then offset ground to 4.375 stroke with 2.200 rod journals, I'm going to use it in my Koleno high nickel iron block to make a 555 C.I. race motor with a set of B1-MC heads, I'm hoping to make right at or above 2.0 HP per C.I. Gregs Dart convinced me about using full counter weight stroker cranks several years ago so I'm hoping for good results I wish I had enough extra money for a fully light weight version of that same crank, but I don't
[Re: sgcuda]
#2389135
10/18/17 03:01 AM
10/18/17 03:01 AM
Posts: 19,537 Las Vegas
Al_Alguire
Las Vegas
All I will say on the subject is pretty much EVERY high end race motor out(WOO, Nascar F1, SCORE etc etc)out there uses center counter weighted cranks. Must be a reason.
[Re: sgcuda]
#2389160
10/18/17 07:30 AM
10/18/17 07:30 AM
Posts: 10,081 Frostbitefalls MN (Rocky&Bullw...
gregsdart
Got a reply from Ohio Crank today and they said the billet can only be made with Chrysler journals. Well, since I don't want to run with anything larger than BBC journals, the billet piece is out. From the info I have gathered, I have learned that 1) aluminum rods will not clear the cam with crank strokes longer than 4.500" and 2) crank strokes longer than 4.500" will cause excessive piston skirt wear. Interesting enough, I have read somewhere about a new piston being made with an asymmetric skirt, favoring the major thrust side. Maybe just for this kind of build. You may be able to have the rod journals cut to bbc size by another grinder, if you decide you want an Ohio ccw crank
8.582, 160.18 mph best, 2905 lbs 549, indy 572-13, alky
[Re: sgcuda]
#2389202
10/18/17 11:02 AM
10/18/17 11:02 AM
Posts: 13,492 Marion, South Carolina [><]
an8sec70cuda
Got a reply from Ohio Crank today and they said the billet can only be made with Chrysler journals. Well, since I don't want to run with anything larger than BBC journals, the billet piece is out. From the info I have gathered, I have learned that 1) aluminum rods will not clear the cam with crank strokes longer than 4.500" and 2) crank strokes longer than 4.500" will cause excessive piston skirt wear. Interesting enough, I have read somewhere about a new piston being made with an asymmetric skirt, favoring the major thrust side. Maybe just for this kind of build. You don't need aluminum rods for a N/A bracket motor. If it were me, I'd be running a good steel rod in that motor. Less maintenance and there's really no benefit as far as weight. Not to mention you can go w/ more than a 4.5" stroke in a std. cam height block if you want. Just me, but I really wouldn't be concerned w/ a little skirt wear on a motor like this. It isn't gonna be driven 50k miles back and forth to work.
CHIP '70 hemicuda, 575" Hemi, 727, Dana 60 '69 road runner, 440-6, 4 speed, Dana 60 '71 Demon 340, no drivetrain, on blocks behind the barn '73 Chrysler New Yorker, 440, 727, 8.75 '90 Chevy 454SS Silverado, 476" BBC, TH400, 14 bolt '06 GMC 2500HD LBZ Duramax
[Re: dvw]
#2389327
10/18/17 02:58 PM
10/18/17 02:58 PM
Posts: 4,243 Charlotte, North Carolina
sgcuda
With a.9 mm ring pack and Molnar 7.100"/2.2000"/.990" steel rods my reciprocating weight was actually lighter than with the BME aluminum rods. The rotating weight was so close that we trimmed a little from the journal side to rebalance. Doug Wow. That's good to know. I just thought that aluminum rods always weighed significantly less than steel rods.
[Re: sgcuda]
#2389350
10/18/17 03:28 PM
10/18/17 03:28 PM
Posts: 4,632 Motor City
6PKRTSE
Motor City
No need for a CCW crank in a street or drag race piece. It is overkill but couldn't hurt anything other than the wallet. In a endurance type racing as mentioned above NASCAR, F1, Off Shore Boat Racing, Truck & Tracvtor Pulling etc where engines sustain long durations of higher RPM is would be beneficial.
1963 Belvedere 440 Max Wedge Tribute 1970 Charger R/T S.E. 440 Six Pack 1970 Challenger R/T, 528 Hemi 1970 Charger 500 S.E. 440 4 BBL 1970 Plymouth Road Runner 383 1974 Chrysler New Yorker 440 1996 2500 RAM 488 V-10 4X4 2004 3500 Dually Cummins 4x4 2012 Challenger R/T Classic.
[Re: sgcuda]
#2389373
10/18/17 04:14 PM
10/18/17 04:14 PM
crabman173
crabman173
The main benefit of aluminum rods in what we do is to help the bottom end --keeps caps from walking even on Megablocks--they act like a dead blow hammer--it used to be one of the ways we kept stock blocks alive when -1 Indys first started making some real HP--they are all about the main caps not weight--and in a stroker like you plan steel rods are sooo much easier to get in there and not hit the cam etc so if you have an Indy block or KB block then it becomes less critical Again I say Charlie Buck has built more 1000--3000 Hp engines than all of us on here combined --ask someone that really has the experience and knows
[Re: AndyF]
#2389438
10/18/17 06:16 PM
10/18/17 06:16 PM
Superfreak
Superfreak
Got a reply from Ohio Crank today and they said the billet can only be made with Chrysler journals. That doesn't seem to make sense. I can understand a forged crank only available in a certain journal size but billet is billet. It is all being machined anyway so all they have to do is punch a few buttons and then instant presto you have 2.200 rod journals. If I got an answer like that from a place claiming to make billet cranks I'd move on down the line. I'm pretty sure if you call Winberg or Bryant or some other place that makes billet cranks and ask them if they can make the cranks with different rod journals they'll tell you sure. They can probably make each journal a different size if you want to pay for it. Someone at Ohio Crank either doesn't know what they are talking about or else they aren't really billet cranks. Or perhaps the cranks are made by someone else and Ohio Crank just sells them...... I was very surprised when I read their email and they suggested their forged piece. The price of $3024 from Bryant works but it would be nice if they could be at a $2000 mark.
[Re: sgcuda]
#2389442
10/18/17 06:31 PM
10/18/17 06:31 PM
Posts: 9,973 MI, usa
dvw
MI, usa
The problem with aluminum rods for me is that they have a short life span. I can't afford to buy a new set of $1300 rods after 300 passes. At a higher power level of course better parts are required. It's up to each individual as to how much they gamble on a part. That's why I posted here. My experience with the parts I mentioned have been trouble free for the number of passes at the stroke and RPM run in my motor. I've put over 500 runs on the crank. My bet is it had at least 200 on when I received it. Doug
[Re: 6PKRTSE]
#2389537
10/18/17 09:43 PM
10/18/17 09:43 PM
gregsdart
No need for a CCW crank in a street or drag race piece. It is overkill but couldn't hurt anything other than the wallet. In a endurance type racing as mentioned above NASCAR, F1, Off Shore Boat Racing, Truck & Tracvtor Pulling etc where engines sustain long durations of higher RPM is would be beneficial. Due to actual experience, I disagree. That cap walk in my Megablock DID go away when I put the ccw crank in. I cracked a non ccw crank at 100 runs, so the least it cost me to fix that was the crank and balancing. Another reason to run a ccw crank would be to add life to a stock block motor pushing the limits. It will definitely even out the stresses from balance, not force them through the block to other bearings adjacent; adding a lot of extra stress along the way. Save the cost of replacing a cracked and broken block one time and that ccw crank will look cheap.
[Re: dvw]
#2389557
10/18/17 10:16 PM
10/18/17 10:16 PM
sgcuda
The problem with aluminum rods for me is that they have a short life span. I can't afford to buy a new set of $1300 rods after 300 passes. At a higher power level of course better parts are required. It's up to each individual as to how much they gamble on a part. That's why I posted here. My experience with the parts I mentioned have been trouble free for the number of passes at the stroke and RPM run in my motor. DVW, what stroke and RPM are you running? Have you seen any advantages to a 9mm ring pack over a standard 1/16" 1/16" 3/32" ring pack?
[Re: sgcuda]
#2389795
10/19/17 01:03 PM
10/19/17 01:03 PM
an8sec70cuda
Kenny...you have a good block that doesn't have problems w/ cap walk. You also are building a naturally aspirated bracket motor that will see a lot of runs. That does not fall into aluminum rod territory IMO, unless you just like wasting money. They will offer you no benefit and won't save any weight, but you'll have to change them out for a new set after 300 or so runs.
[Re: sgcuda]
#2389905
10/19/17 05:21 PM
10/19/17 05:21 PM
crabman173
crabman173
Fun Fact That 300 run zone has been the CW for as long as I can remember I guess that is what Bill Miller says and he sure is about 100 times smarter than I am but I used to buy aluminum BME's used from McCandless or wherever I could get them--and run them in bracket 440's that saw 200 plus runs per year sometimes 300 runs a season--I never ever had one fail in that application Have had some engines run for years with them well into the 700 run zone in a bracket 440 BME says make a few runs--resize them and run until you get enough $$ to buy more--he also says release the TQ on the bolts over the winter--I am SURE he is right about all that but just saying--I think we had nothing at risk but a stock block--If I had a high $$ block etc I would be much more careful Sort of like Dad told me You get a Shetland pony you tie him to the swing set and let him eat the onions in the yard--you get a thorough bred and you have to clean his oats, get him a goat for a barn pal, wash him like a new Porsche, etc etc
guess I have always had the ponys
[Re: sgcuda]
#2389972
10/19/17 07:19 PM
10/19/17 07:19 PM
Al_Alguire
Las Vegas
Here is my .02. Buy a center counter weighted crank and aluminum rods but aint my money....
