Re: Backfiring through the exhaust
[Re: Crizila]
#2389269
10/18/17 12:32 PM
10/18/17 12:32 PM
RapidRobert
#1 on the hit parade should be to get the battery problem fixed. X2 then (charged up (from a charger not the alt) take it out & if still bad change the coil, put in any one from your stash just for a test (with a ballast if need be). EDIT vac leak is another potential & you did change plugs correct? plug wires would be further down on the list
[Re: 1968RR]
#2389689
10/19/17 02:43 AM
10/19/17 02:43 AM
Posts: 6,257 gulfport, ms, west mi
rowin4
Mine is a stock 1964 points ignition. Coil, condenser what's left ? I guess I'll just start throwing money at it till it stops .
[Re: 1968RR]
#2389867
10/19/17 03:46 PM
10/19/17 03:46 PM
Posts: 1,943 San Angelo, Texas, U.S.A.
1968RR
I swapped out the battery and the plugs and the backfire went away. I was surprised, considering that I didn't replace the two plug wires that lacked continuity. I guess that the spark is able to arc across whatever gap is in the wires with a good battery. Of course, I'll be replacing the wires soon. On a side note: my engine seemed to like the NGK V-Power plugs that I used to have in there a lot more than the Autolite Racing plugs that I swapped in.
"When I'm in a slump, I comfort myself by saying if I believe in dinosaurs, then somewhere, they must be believing in me. And if they believe in me, then I can believe in me." - Mookie Wilson
