Re: Vote for the Carb(s) I test on the Dyno! [Re: davenc] #2389058
10/17/17 11:41 PM
10/17/17 11:41 PM
Charleston
sixpackgut Offline
Drag Week Mod Champion
sixpackgut  Offline
Charleston
TEST THEM ALL, LET DYNO SORT THEM OUT
Re: Vote for the Carb(s) I test on the Dyno! [Re: fast68plymouth] #2389062
10/17/17 11:59 PM
10/17/17 11:59 PM
AndyF Offline
AndyF  Offline
6a was dialed in pretty good when I ran it. AFR was in the low 13's, made 650 hp on my 470 back before the intake was ported, BSFC was 0.400, Correction Factor was 1.02 so pretty good air. Dyno shop is close to sea level.
My dyno sheets show that we had 88 and 99 jets in it for those pulls. That was the Mark W tune. Worked great from 3500 to 7000 rpm. If you're testing near sea level then I'd use the original Mark W. tune and let it rip.
Re: Vote for the Carb(s) I test on the Dyno! [Re: BradH] #2389125
10/18/17 02:23 AM
10/18/17 02:23 AM
Mark Whitener Offline
#5, 6B will be nearly identical but 5 gets the nod. Scrap the 1.60 you got from Andy for the test. And the Race Q1000 down leg should be a 1.500 venturi, that might be an interesting test against the 1.59 annular.
Mark Whitener
[url=www.racingfuelsystems.com[/url]
Re: Vote for the Carb(s) I test on the Dyno! [Re: AndyF] #2389289
10/18/17 01:12 PM
10/18/17 01:12 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Makes sense that as MOST dyno's do from 3500-7500 and up it may have been ok but trust me, it killed my oil n plugs below that and could NOT even do a burnout. I'm not bagging on anyone or pointing fingers but on the steet where it matters most, it was a pig and I know it was loaned out as well so who knows there. IIRC, it had .080-.090 but not 100% and not near my book..............I see zero reasons to EVER run a 4150 on any motor making good power and have proved it many times even on small-blocks that have picked up a several mph and .010's so me, I'd ditch/sell em all and put a real carb on that puppy........... biggrin apimp And .088-.099 jets........that's insane and even 1250's rarely run that size which should tell ya something........... work
Re: Vote for the Carb(s) I test on the Dyno! [Re: Mark Whitener] #2389333
10/18/17 03:10 PM
10/18/17 03:10 PM
Val-haul-ass... eventually
BradH Offline OP
BradH  Offline OP
I had been thinking along the same carbs to test (the QFT 1.52 downleg & the QFT 1.59 annular) along w/ the baseline BG.
The Holley 1.60 annular conversion is sitting on a stand ready to bolt on (except I did notice the linkage is binding for some reason). No reason not to at least throw it on to see how it does... time permitting.
That's what I expected, too (i.e., 1.50" venturi). However, I measured mine after you installed the BLP boosters and found it measured 1.52", and later on found a QFT spec sheet that listed the RQ-1000 as 1.52", also. It makes sense, considering their venturi increases from "950" to "1000" is .07", and from "1000" to "1050" is another .07".
Re: Vote for the Carb(s) I test on the Dyno! [Re: sixpackgut] #2389337
10/18/17 03:11 PM
10/18/17 03:11 PM
BradH Offline OP
BradH  Offline OP
This is the carburetor equivalent of "Kill 'em all. Let God sort 'em out.", right?
Re: Vote for the Carb(s) I test on the Dyno! [Re: davenc] #2389339
10/18/17 03:13 PM
10/18/17 03:13 PM
BradH Offline OP
BradH  Offline OP
Originally Posted By davenc
What criteria are you planning to use to evaluate the carbs? Peak numbers, area under the curve, something else??
The evaluation won't be strictly on peak HP & torque #s, but also the fuel curve, amount of air being used, differences in where a particular carb might show better than another, etc.
I've seen where two carbs that made virtually the same power on the dyno still ran .2 & 2 MPH differently on the car. Whatever looks like the most worth testing based on the dyno results will still get flogged on the car to prove it.
Re: Vote for the Carb(s) I test on the Dyno! [Re: BradH] #2389354
10/18/17 03:32 PM
10/18/17 03:32 PM
Charleston
sixpackgut Offline
sixpackgut  Offline
Charleston
Yes smile
Re: Vote for the Carb(s) I test on the Dyno! [Re: sixpackgut] #2389356
10/18/17 03:37 PM
10/18/17 03:37 PM
tboomer Offline
tboomer  Offline
Just put the motor in the car and run it... beer
Re: Vote for the Carb(s) I test on the Dyno! [Re: tboomer] #2389428
10/18/17 05:58 PM
10/18/17 05:58 PM
BradH Offline OP
BradH  Offline OP
NOTHING in my life is that simple...
Re: Vote for the Carb(s) I test on the Dyno! [Re: BradH] #2389468
10/18/17 07:34 PM
10/18/17 07:34 PM
AndyF Offline
AndyF  Offline
Any chance you have more carbs than you need Brad?
Oh wait, before you answer that would you like to buy a carb Brad? I don't think I need my QF-1050-AN anymore now that I switched to EFI so I'll make you a good deal on it.......
Re: Vote for the Carb(s) I test on the Dyno! [Re: AndyF] #2389477
10/18/17 08:07 PM
10/18/17 08:07 PM
BradH Offline OP
BradH  Offline OP
Why the He11 would you think that??? wink
That reminds me... can you provide me w/ your QFT RQ-1050-AN tune so I can duplicate it w/ all the parts I have sitting around to build one myself? laugh2
Re: Vote for the Carb(s) I test on the Dyno! [Re: BradH] #2389623
10/19/17 12:05 AM
10/19/17 12:05 AM
NC, USA
davenc Offline
davenc  Offline
NC, USA
And that is what I was wondering. If the criteria isn't clear going into your test, you may pick the wrong carbs to test. To me, it would seem that the best criteria would be area under the curve, in the RPM range encountered during the run; the right carb for a narrow range is likely different than for a wider range. Not knowing any of those details, my vote would be for 1, 4, and 6B.
Re: Vote for the Carb(s) I test on the Dyno! [Re: davenc] #2389718
10/19/17 08:53 AM
10/19/17 08:53 AM
BradH Offline OP
BradH  Offline OP
The on-track differences like I pointed out were due to shift recovery (how quickly the carb adjusts to change in RPM & load) characteristics, which a basic engine dyno doesn't take into account.
Re: Vote for the Carb(s) I test on the Dyno! [Re: BradH] #2390002
10/19/17 08:18 PM
10/19/17 08:18 PM
BradH Offline OP
BradH  Offline OP
Survey says...
#4
#5
#6a
That's all for now! wave
