Re: Brake Fluid DOT 3 Synthetic- any Good?
[Re: 65pacecar]
#2387780
10/15/17 04:31 PM
10/15/17 04:31 PM
Posts: 15,926 Central Florida
larrymopar360
Stud Muffin
Stud Muffin
Central Florida
Has anyone tried the Synthetic version of DOT 3? I assume it doesn't destroy paint like the old stuff. I have used Dot 5 in a recent build, is the DOT 3 Synthetic a better route for the old cars, or does it make much difference vs. Dot 5?
I put DOT 3 syntetic in my '89 Diplomat (if you consider that older car) without realizing it was synthetic until it was too late. No problems whatsoever.
Facts are stubborn things.
[Re: 65pacecar]
#2387826
10/15/17 07:13 PM
10/15/17 07:13 PM
Posts: 6,531 Jacksonville, FL
Chris2581
Jacksonville, FL
DOT 3 will still harm paint. Only DOT 5 which is a silicone fluid will not.
[Re: Chris2581]
#2387866
10/15/17 09:16 PM
10/15/17 09:16 PM
Posts: 6,717 KY
65pacecar
KY
DOT 3 will still harm paint. Only DOT 5 which is a silicone fluid will not. Thanks. I'll stick with dot 5 then since I've had good luck with it. I was st Meijer and saw the dot 3 synthetic and was just wondering.
[Re: RTSrunner]
#2387945
10/16/17 12:02 AM
10/16/17 12:02 AM
Posts: 3,379 KY USA
mopargem
KY USA
Don't mix DOT 5 with DOT 3 or 4,serious seal swelling will result. RT Sounds like a warning for Viagra
68 Polara 500...LL1 Y7 M6X 69 Hemi road runner...X9 X9 M6X 69 A12 road runner....R4 R4 M6X 69 ModTop FLORAL Super Bee...F6 M6W 70 AAR 'cuda...EW1 EW1 H4X9 71 Duster 340...FJ6 V24 L6X9 71 road runner FC7 V1X M6X9 72 Rallye Charger B5 V1W 74 'cuda 360...KB5 V1X A6X9 08 SRT Challenger #234
[Re: mopargem]
#2388006
10/16/17 03:11 AM
10/16/17 03:11 AM
Posts: 1,881 Pittsburgh,PA
RTSrunner
Pittsburgh,PA
Don't mix DOT 5 with DOT 3 or 4,serious seal swelling will result. RT Sounds like a warning for Viagra Disclaimer: Don't drink them either!
[Re: RTSrunner]
#2388225
10/16/17 04:03 PM
10/16/17 04:03 PM
Posts: 25,925 Rio Linda, CA
John_Kunkel
Rio Linda, CA
Don't mix DOT 5 with DOT 3 or 4,serious seal swelling will result. RT Myth. In order to receive DOT certification, all DOT fluids must be able to coexist in the same system with no ill effects.
[Re: 65pacecar]
#2388872
10/17/17 06:03 PM
10/17/17 06:03 PM
Posts: 905 SD
zrxkawboy
SD
Marketing gimmick. ALL brake fluid is synthetic.
It's Swifty! Swifty, you toad sucker!
[Re: zrxkawboy]
#2388966
10/17/17 09:04 PM
10/17/17 09:04 PM
larrymopar360
Stud Muffin
Stud Muffin
Central Florida
Marketing gimmick. ALL brake fluid is synthetic. But it wasn't always right?
