Re: FiTech Fuel Injection [Re: OrangeProwler] #2387254
10/14/17 10:43 AM
10/14/17 10:43 AM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
I would look into the Holly Sniper system before making a final call on FiTech.
68 Barracuda Formula S 340
Re: FiTech Fuel Injection [Re: John_Kunkel] #2387286
10/14/17 11:53 AM
10/14/17 11:53 AM
Downtown Roebuck Ont
Twostick Offline
Still wishing...
Twostick  Offline
Still wishing...
Originally Posted By John_Kunkel
Originally Posted By Jerry
don't waste time with the fuel command center.
I have to disagree, way simpler installation than frame-mounted pumps or for cars where in-tank pumps aren't practical. Mine has given me zero problems.
That Fuel Command system would be cool in a Moon tank mounted in the grill for that gasser look.
Kevin
Re: FiTech Fuel Injection [Re: OrangeProwler] #2387325
10/14/17 01:30 PM
10/14/17 01:30 PM
Ontario, Canada
Stanton Online content
Don't question me!
Stanton  Online Content
Don't question me!
Ontario, Canada
When someone makes a statement like this with no reason I don't waste my time with it.
Re: FiTech Fuel Injection [Re: Stanton] #2387361
10/14/17 02:57 PM
10/14/17 02:57 PM
Warren, MI
Jerry Offline
Jerry  Offline
Warren, MI
there are lots of documented cases of the fuel command center failing. mine was one of them. I did try it. ended going with a tank mounted pump. don't know why it failed maybe not enough fuel flow? needs a real return back to the tank to circulate fuel so it won't over heat.
if you are going to try it. make sure you attach the vent line to a fuel return line back to the tank. plenty have tried not to, only to have fuel shooting out of it. its almost as if the float fails.
Superior Design Concepts
2574 Elliott Dr
Troy MI 48083
jerry@sdconcepts.com
www.sdconcepts.com
Facebook page: Superior Design Concepts
www.bcrproducts.com
Re: FiTech Fuel Injection [Re: Jerry] #2387376
10/14/17 03:49 PM
10/14/17 03:49 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Without a comparison of failure rates of other fuel delivery systems, anecdotal experience is just that.
Re: FiTech Fuel Injection [Re: John_Kunkel] #2387392
10/14/17 04:29 PM
10/14/17 04:29 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Don't need that.
All you need is data on the command center failures.
MTBF is solely calculated on the unit in question, not some other system.
Don't be the exception.
Re: FiTech Fuel Injection [Re: UCUDANT] #2387419
10/14/17 05:46 PM
10/14/17 05:46 PM
Central Florida
larrymopar360 Offline
Stud Muffin
Stud Muffin
Central Florida
Originally Posted By UCUDANT
I installed my unit myself cleanly and as the manufacturer suggested paying attention to the details. New clean tank, 3/8 fuel line, properly returned FCC vent. I've had not issues other than needed a software update
Mine is located in same spot, and that's the key, properly installed return line!
Facts are stubborn things.
Re: FiTech Fuel Injection [Re: OrangeProwler] #2387586
10/15/17 02:18 AM
10/15/17 02:18 AM
gulfport, ms, west mi
rowin4 Offline
rowin4  Offline
Well a little update on the FITech set up my buddy has. It seems that he doesn't like running 9 flat so he picked up the new Holley Sniper fabricated sheet metal intake for his big block. This set up is for 2-4"s. He says that another 1200 FITech will be just right. I looked at a number of those intakes, LS, Big blocks, Small block and for Fords. No mopar as of yet but they sure are light and look mighty fine. To be continued.
Re: FiTech Fuel Injection [Re: OrangeProwler] #2388608
10/17/17 09:59 AM
10/17/17 09:59 AM
Middle of A Field
O
OrangeProwler Offline OP
O
Middle of A Field
Thank you everyone. Looks FITech makes a kit for Summit too. I've read that part of the FCC failures is due in part to the fuel pump? I've read guys replacing the unit and pump. Anyways, I'll keep my eyes out and continue to see how things play out with these units.
Re: FiTech Fuel Injection [Re: OrangeProwler] #2388803
10/17/17 04:06 PM
10/17/17 04:06 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Without changing the default settings, the pump in the FCC runs at full pressure throughout the operating range which might account for the reported failures. The pump can be slowed at idle with the hand-held controller.
Re: FiTech Fuel Injection [Re: John_Kunkel] #2388970
10/17/17 09:08 PM
10/17/17 09:08 PM
Central Florida
Stud Muffin
Stud Muffin
Central Florida
Yes, this is what I read in FiTech's solution to problem and set my per. I did still have a bad pump from the get go because mechanic commented at install he didn't like how it seemed to be flooding at beginning.But as I said, all good now and I'm happy with it since and the easier starts and improved cold idle alone make it worth it to me.
