Re: Winter upgrade plans, what are you guys( and gals) doing
[Re: B3422W5]
#2383006
10/06/17 02:43 PM
10/06/17 02:43 PM
Posts: 865 lancaster,california
johnnycuda
I'm looking into getting a Dana for my Cuda, and finish the 69 Valiant, drive it around, maybe take it to the track on a street legal day, should run around 12.0 or so I'm guessing...maybe faster. I'm kicking around going to the Zip-Tie Drags in Arizona in January.
1970 'Cuda,Lime Light,499 Indy S/R's 10.70's @125,street driven ALOT! 1966 Barracuda 360,now a 5spd,Hemi Orange,Hot Rod Air, New daily driver-2003 Ram 2500 Cummins 5.9 '69 Valiant 2-dr, sleeper! New project---1938 Dodge truck, plan is a 360 with a A500, AC, Calvert rear susp., rack and pinion front with coils.
[Re: B3422W5]
#2383013
10/06/17 03:04 PM
10/06/17 03:04 PM
Posts: 20,384 Park Forest, IL
slantzilla
Park Forest, IL
Got any pictures of her. What has it run before?
[Re: B3422W5]
#2383024
10/06/17 03:22 PM
10/06/17 03:22 PM
johnnycuda
I'm just getting it done now, haven't drove it yet, but think it should run close to that, 408 w/RHS heads, 10-1, solid lifter .542/.556 cam, LD340, 780 Holley, has a A500 (has a low first), 3.73 rear, Calvert Suspension, drag radials. Apparently my pics are too large to load here, just had it painted B5 blue, ProStars, black interior, bench with column shift.
[Re: johnnycuda]
#2383045
10/06/17 04:00 PM
10/06/17 04:00 PM
Posts: 348 Red Deer, Alberta
Greenwood
Red Deer, Alberta
New valve springs and retainers, plus I think I have my head wrapped around how to sort out my valvetrain deflection/pushrod length situation. I'm giving up a lot of net lift due to bad geometry. Plus, if anyone here has some old Crane 1.6 rockers for a small block that they're not using, PM me. I'm also refreshing the convertor. After the last freshening, it launched the car really well at first, but now it no longer flashes to the needed 4500-5000 rpm my heap desperately needs. (TCS 8") To top it off, after finding out the limitations of my mini-spool behind a a trans brake with new slicks (Yes, Virginia a small-block actually CAN completely destroy every part of a 9" if you really try.), I need every part of a 9" that exists between the end of the driveshaft and the wheels, except for the driveshaft yoke and the housing. Well, not every part. I don't need new nuts for the center section studs.
[Re: Mr340]
#2383118
10/06/17 07:41 PM
10/06/17 07:41 PM
Posts: 22,873 Chicken coop
dustergirl340
Chicken Little
Chicken Little
Chicken coop
I already did the hood swap on the challenger due to a little mishap @ Milan. I was thinking about a cam upgrade But I picked up a more door Dart so I'll be working on that. Install my old 340 with a 904, the car is a pushbutton car so I'm looking to keep that if I can find a v-8 pb 904. It also needs a rear axle swap, 8 3/4. Frame connectors. Oh yea and change the bench seat to buckets. Wife want the car ready for spring, I think I have my hands full Now you're an A-body weenie! What year Dart?
[Re: B3422W5]
#2383134
10/06/17 08:37 PM
10/06/17 08:37 PM
slantzilla
Park Forest, IL
Thank you. I really didn't need another project, but I always liked the car and Mike made me a pretty fair deal on it. It has lots ofmoney spent on it trying to get it light.
[Re: B3422W5]
#2383302
10/07/17 05:07 AM
10/07/17 05:07 AM
Posts: 2,501 Sydney,Australia
tex013
Sydney,Australia
Transbrake transmission to go in by december , fit anti balloon plates to current vert as stall is good Hope i dont need a taller radial or i will have to move rearend back a little . Get M1 intake cut to fit motor then try adapter and dominator . Will also probably get Modman cut to fit and try it as well . All to be done and tested by end February . So it will be hot testing over summer .
Tex
New best ET 10.259@129.65 . New best MPH 130.94 Finally fitted a solid cam, stepped it up a bit more 3690lbs through the mufflers New World block 3780lbs 10.278@130.80 . Wowser 10.253@130.24 footbraking from 1500rpm Power by Tex's Automotive
[Re: dustergirl340]
#2383320
10/07/17 09:28 AM
10/07/17 09:28 AM
Posts: 1,017 Richmond Twp. Mi.
Mr340
Richmond Twp. Mi.
I already did the hood swap on the challenger due to a little mishap @ Milan. I was thinking about a cam upgrade But I picked up a more door Dart so I'll be working on that. Install my old 340 with a 904, the car is a pushbutton car so I'm looking to keep that if I can find a v-8 pb 904. It also needs a rear axle swap, 8 3/4. Frame connectors. Oh yea and change the bench seat to buckets. Wife want the car ready for spring, I think I have my hands full Now you're an A-body weenie! What year Dart? its' a '64. I was actually looking for a '60 valiant and this turned up. It kinda spoke to us ...buy me, buy me... I think the engine swap and exhaust will be slightly easier on this one.
[Re: B3422W5]
#2383364
10/07/17 11:35 AM
10/07/17 11:35 AM
Posts: 3,007 A shed in England
Tig
A shed in England
We finally got this back at the track after a 20 month total stripdown, paint and rebuild. Lots of minor issues to sort out. We're starting from scratch again with the chassis after replacing all the worn out stuff and putting re-valved dampers on. We also need to fit the old 8 inch converter behind the back up 572 motor while the 655 gets re-freshed and some upgrades. We tried the 9 1/2 inch converter specced for the 655 but we feel the 8 inch will be better. The suspension has settled after a dozen passes and the camber, castor and toe are a mile out so that needs sorting too. We also fitted the 655 induction system to the 572 to see what happened. Theoretically way over carbed at 2300cfm, we chased a rich bog for most runs until we realised it was sloshing fuel out of the vent tubes.I'm also considering running an electric fuel pressure gauge, a -4 fuel return and an ARC module. We've ran out of racing 'till next season so we'll have to see if we've cured it and continue ironing out the bugs. Motor Shot
'74 Challenger..9.46 @ 145.9 1/4, 6.001 @ 118 1/8 so far. 4023lb !!! # N/A, Marsh performance 655ci, Indy Maxx, T/R, Indy 600-13 X's, Street legal, pump gas, full interior, Cal-Tracs, mufflers, 3:73's and real 10.5 radials. 9.51 @ 142.4 1/4, 6.003 @ 114 1/8 with our old mule KB, 572-13, 580 wedge. RHD '68 Barracuda Fastback 323ci street/strip. Best ET 13.88 @ 99.03
[Re: B3422W5]
#2383383
10/07/17 12:07 PM
10/07/17 12:07 PM
Posts: 1,035 Missouri U.S.A.
71yelladustr
Missouri U.S.A.
Out with the 440 and in with a 5.7 based gen III hemi. Probably add a transbrake while I'm at it.
392 gen III hemi on E-85 727 trans Dana 60 10.02@134
[Re: Mr340]
#2384018
10/08/17 05:03 PM
10/08/17 05:03 PM
dustergirl340
Chicken Little
Chicken Little
Chicken coop
its' a '64. I was actually looking for a '60 valiant and this turned up. It kinda spoke to us ...buy me, buy me... I think the engine swap and exhaust will be slightly easier on this one. '64 Dart is (almost) as cool as a '65 Dart. Sounds like a fun project. It's for your wife?
[Re: dustergirl340]
#2384043
10/08/17 05:51 PM
10/08/17 05:51 PM
dartman366
Mt. Vernon, Ohio
not really doing much this winter, just tidying up some things, don't really need to do much since the motor and tranny are all new, would like to go thru the wiring and re-route a few hoses, and get it ready to send to the chassis shop in the spring for a once over.
[Re: B3422W5]
#2384329
10/09/17 09:54 AM
10/09/17 09:54 AM
Posts: 13,530 Marion, South Carolina [><]
an8sec70cuda
Just need to replace my twisted 35 spline axles and refresh the front brakes on the cuda.
All the while putting the '71 Demon back together.
CHIP '70 hemicuda, 575" Hemi, 727, Dana 60 '69 road runner, 440-6, 4 speed, Dana 60 '71 Demon 340, no drivetrain, on blocks behind the barn '73 Chrysler New Yorker, 440, 727, 8.75 '90 Chevy 454SS Silverado, 476" BBC, TH400, 14 bolt '06 GMC 2500HD LBZ Duramax
