Re: Holley carb disintegrating...ever seen this?
[Re: an8sec70cuda]
#2381785
10/04/17 02:24 PM
10/04/17 02:24 PM
Posts: 11,832 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
Over 40 years of fooling with carbs, I've never seen that. Plenty of damage from moisture, corrosion, fuel additives and contamination, abuse, but not cracked to pieces like that.
[Re: an8sec70cuda]
#2381816
10/04/17 03:02 PM
10/04/17 03:02 PM
Posts: 26,046 Rio Linda, CA
John_Kunkel
Rio Linda, CA
Complete six pack setup bought brand new as a kit through Mopar back in 2006 or 2007 I've seen this discussed before; evidently during that time Holley was in financial trouble and I believe the flaking and peeling you're seeing is the result of Holley's offshore casting supplier having different standards regarding the metallurgical composition of Zamac #3 casting alloy. The substandard alloy, incorrect temperature/pressure used in the production of thousands of Holley main bodies, metering blocks, and float bowls is the root cause of the problem. Any moisture present in the fuel or during storage exacerbates the problem.
[Re: an8sec70cuda]
#2381826
10/04/17 03:14 PM
10/04/17 03:14 PM
Posts: 14,515 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
It's one of their special "HP" metering blocks...... As in "high porosity".
[Re: fast68plymouth]
#2381880
10/04/17 05:54 PM
10/04/17 05:54 PM
Posts: 4,457 Washington
madscientist
Washington
It's one of their special "HP" metering blocks...... As in "high porosity". Ok that's funny right there!!!! And probably true.
[Re: an8sec70cuda]
#2381888
10/04/17 06:07 PM
10/04/17 06:07 PM
Posts: 192 Gravataí, RS, Brazil
360tripleblack77
I've seen some carbs that was bought in US having problems here in Brazil. Mainly because we've 30% of ethanol in our gasoline and our ethanol is very different then US ethanol. No issues with my Demon carbs so far, but with edelbrock and old holleys we had some problems with corrosion.
'77 Brazilian Dodge Charger R/T - Street Car Footbrake, Pump Gas, SB Mopar 360" N/A 3300lbs, Leaf Spring + Assassin Bars Best 1/8 mile ET 1.50 60' / 4.31 330' / 6.73@102.54mph
[Re: an8sec70cuda]
#2381997
10/04/17 06:56 PM
10/04/17 06:56 PM
Posts: 2,475 Sydney,Australia
tex013
Sydney,Australia
I have had similar issues with 1 carb here in Australia 3(?) years ago there abouts . Severe delamination/breakup up of the fuel bowls . Only 1 carb of a new pair used on a blown chev . This was a street motor running pump gas . There was no ethanol in the fuel here at that time . Swapped on a old pair of spare bowls and away we went no further issues
Tex
New best ET 10.259@129.65 . New best MPH 130.32 Finally fitted a solid cam, stepped it up a bit more 3690lbs through the mufflers New World block 3780lbs 10.278@130.80 . Wowser 10.253@130.24 footbraking from 1500rpm Power by Tex's Automotive
[Re: an8sec70cuda]
#2382050
10/04/17 08:28 PM
10/04/17 08:28 PM
fast68plymouth
So. Burlington, Vt.
I did a search on the bad Holley casting situation. Pretty interesting info about how that all happened.
I'm pretty sure that any zinc Holley parts I have were bought before that whole offshore casting situation was happening.
[Re: an8sec70cuda]
#2382070
10/04/17 09:46 PM
10/04/17 09:46 PM
madscientist
Washington
I'm going to have to google zinc pest. Never heard of it.
[Re: an8sec70cuda]
#2382317
10/05/17 10:14 AM
10/05/17 10:14 AM
Posts: 13,417 Marion, South Carolina [><]
an8sec70cuda
I looked up zinc pest and pretty much all the images I see of that look just like my metering block. Interesting, thanks for the info yall!
[Re: an8sec70cuda]
#2382390
10/05/17 01:27 PM
10/05/17 01:27 PM
fast68plymouth
So. Burlington, Vt.
Since it sounds like Holley is willing to do something about for Chip, it will be interesting to see if they do a metering block or the whole carb.
What I'm taking away from this thread, and the stuff I found relating to it is.... I'm going to stay away from Holley carbs made during that 2006-2009 era.
[Re: an8sec70cuda]
#2382425
10/05/17 02:35 PM
10/05/17 02:35 PM
Posts: 5,170 CT
GTX MATT
CT
Holley had some issues around that time causing the carbs to flake apart, IIRC it was porosity. One of my friends had bought a new carb around 2006, I never saw it and don't think it was anywhere near as bad as what you have, but he had it apart about a year later, saw the issue, called Holley and the rep at Holley told him they had been having issues and Holley sent him a new one. His was a 770 Street Avenger.
