Re: Aftermarket RB Block [Re: JERICOGTX] #2382583
10/05/17 06:27 PM
10/05/17 06:27 PM
Cab_Burge Online work
Cab_Burge  Online Work
I know a well known 10.5 heads up racer that did that with a aluminum block and had issues with ring seal and crankcase pressure on the data logger. He switch to a cast iron block and went faster work
Re: Aftermarket RB Block [Re: 10sec440] #2382592
10/05/17 06:48 PM
10/05/17 06:48 PM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
I have to laugh out loud when I hear about bad ring seal on aluminum blocks
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: Aftermarket RB Block [Re: pittsburghracer] #2382995
10/06/17 03:19 PM
10/06/17 03:19 PM
Laugh all you want, I have heard the same results from many heads up west coast racer, power adders included work shruggy
80 to 130 HP loss(700 + and above HP) on engine combination with all the exact same parts being transferred from a iron block to a aluminum block with or without fill shruggy
Bottom line now is we have no good source of both types of RB or B block today, aluminum or iron whiney
Re: Aftermarket RB Block [Re: 10sec440] #2383283
10/07/17 02:53 AM
10/07/17 02:53 AM
Salt Lake City
camastomcat Offline
camastomcat  Offline
Salt Lake City
I have 6 rebuilds on my 572 aluminum World block, it leaks 0-2% and did after 142 passes with Predator heads. I also have a 604 Predator on a steel block, with 2 carbs and more camshaft. It won't keep up with the 572 with one because of weight. Not much more I can say. You won't make up for 150 pounds of weight, bottom line.
Re: Aftermarket RB Block [Re: 10sec440] #2385665
10/11/17 03:34 PM
10/11/17 03:34 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
Well we run an aluminum block in the heads up car and will take the weight saving ANY day over the minimal HP cost from any minor ring seal issue. We used both and there is a VERY VERY VERY tiny amount of difference in power. More than offset by the lower weight of the block. In fact a new Dart ALUMINUM block was just ordered for it a couple weeks ago as it will be going to a much shorter deck height for next year. Also ordered was another block for a S/G racer for the same reason, the weight. Everything will be transferred from the old 582, rotating assy etc and headed to the dyno. I don't expect to see more than a 5hp difference.
Re: Aftermarket RB Block [Re: 10sec440] #2385680
10/11/17 03:54 PM
10/11/17 03:54 PM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
When it comes to a BB Mopar....... I'll take the 150lb weights saving from an aluminum block every time.
Re: Aftermarket RB Block [Re: Al_Alguire] #2386092
10/12/17 02:48 AM
10/12/17 02:48 AM
Oakville, Wa
HOTMOPR Offline
HOTMOPR  Offline
Oakville, Wa
I assume this is not a mopar block?
67 Barracuda, 470" B, Glide, FuelTech FT600, Precision, Ptc, QA1, Calvert, Smith racecraft, Afco, Dana 60. 275 radials
Re: Aftermarket RB Block [Re: 10sec440] #2386276
10/12/17 02:06 PM
10/12/17 02:06 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
Yes a Chevy deal..FWIW I have four engines all with aluminum blocks and wont go back to iron...
Re: Aftermarket RB Block [Re: 10sec440] #2386322
10/12/17 03:07 PM
10/12/17 03:07 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
My car has a very nice late Mega Block, 4.505" with bushed lifter bores. I'd love to have a nice aluminum block.
Doug
Re: Aftermarket RB Block [Re: Al_Alguire] #2386341
10/12/17 03:51 PM
10/12/17 03:51 PM
MD
JACK1440 Offline
JACK1440  Offline
MD
Hey Al, I haven't spoken to you. Finally got down the track once. Popped a rod cap off and beat up two bores as well as trashed a crank. Well... after investigation we found a oil system problem in my new aluminum block (sound familiar?) Turned out there is a feature off location which connected the intake and exit of the oil pump. Once it got rpm on it she starved for oil. Still working it out with the block manuf so I'll keep names out of it for now.
Re: Aftermarket RB Block [Re: dvw] #2386745
10/13/17 11:15 AM
10/13/17 11:15 AM
Liverpool, NY
SILVER67 Offline
SILVER67  Offline
Liverpool, NY
Doug
Have the aluminum 4.5 bore version of your iron World block in the basement.
Thing can't even weigh 150.
Mike
Re: Aftermarket RB Block [Re: 10sec440] #2386782
10/13/17 12:07 PM
10/13/17 12:07 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
Mine isn't a World, It's a late Mopar Mega Block. 270lbs
Doug
Re: Aftermarket RB Block [Re: 10sec440] #2386816
10/13/17 12:38 PM
10/13/17 12:38 PM
an8sec70cuda Offline
I have a World cast iron hemi block in the shop and holy crap is that thing a tank!
My KB hemi block is about 140 lbs if I remember right. I'll take the aluminum block all day every day over cast iron.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Aftermarket RB Block [Re: an8sec70cuda] #2386822
10/13/17 12:49 PM
10/13/17 12:49 PM
NE Ohio
DoubleD Offline
DoubleD  Offline
NE Ohio
World cast iron hemi block is 325+ pounds its a hefty thing
