Re: BES at engine masters getting it done with a bb mopar [Re: BradH] #2382998
10/06/17 03:22 PM
10/06/17 03:22 PM
Guitar Jones Online laugh2
Originally Posted By BradH
EDIT: After seeing both BES and Kasse's EMC entries over the years, I've come to the opinion that Bischoff is amazing, but Kaase is the brilliant Mad Scientist who can re-think just about any perceived obstacle in ways that would never occur to others.
Kaase has to be, he builds Fords.
Re: BES at engine masters getting it done with a bb mopar [Re: SCATPACK 1] #2383011
10/06/17 03:59 PM
10/06/17 03:59 PM
Downtown Roebuck Ont
Twostick Offline
Still wishing...
Twostick  Offline
Still wishing...
Originally Posted By SCATPACK 1
Kasses engine is bogus and not even close to being within the rules. Should have been thrown out.
Smokey Yunick would disagree.
It's not a deck plate, it's a REALLY thick head gasket.
That combustion chamber insert is something else too. I'd be curious to see how that is located and sealed.
Kevin
Re: BES at engine masters getting it done with a bb mopar [Re: Twostick] #2383038
10/06/17 04:53 PM
10/06/17 04:53 PM
Canada
WO23Coronet Offline
WO23Coronet  Offline
Canada
Kevin
My guess, is he bored/countersunk the chamber, only enough to properly locate the insert and stay out of water. On the insert, I’d guess it has two threaded holes on the backside. On the valve cover side of the head, two holes would be drilled to match the threaded holes on the insert, install two bolts/cap screws to hold the insert in place. Wouldn’t need to be very big bolts at all, the valves and combustion pressure would keep them put for the most part. After the inserts are in, machine you chambers and valve job.
If you hit water countersinking the chamber, I’d probably try the stuff you get from GM (little pucks) you put in coolant systems to fix small leaks
Re: BES at engine masters getting it done with a bb mopar [Re: HotRodDave] #2383079
10/06/17 07:02 PM
10/06/17 07:02 PM
The Great White North
RAMM Offline
RAMM  Offline
Kaases' MEL did fit the rules in terms of calling the deck plate his head gasket. However, What was that goop all over the "head gasket"? In years past you would have been asked to show what tube of goop you used--If it said GASKET MAKER anywhere on it then that would be considered the gasket and your deck plate would be ILLEGAL. Now if all the tube said was SEALANT then you were OK. J.Rob
2009 PHR\EMC Competitor
2010 PHR\EMC Competitor
2011 PHR\EMC Competitor
2012 PHR\EMC Competitor
2013 PHR\EMC Competitor
2014 HotRod/EMC Competitor
2015 HotRod/EMC NoShow
2016 HotRod/EMC 3rd place SPEC Bigblock
2018 HotRod/EMC 7th place G3
Re: BES at engine masters getting it done with a bb mopar [Re: BradH] #2383081
10/06/17 07:05 PM
10/06/17 07:05 PM
RAMM Offline
RAMM  Offline
[quote=BradH
EDIT: After seeing both BES and Kasse's EMC entries over the years, I've come to the opinion that Bischoff is amazing, but Kaase is the brilliant Mad Scientist who can re-think just about any perceived obstacle in ways that would never occur to others. [/quote]
My opinion is a little different here. I've always found that Tony seems to do more with less and Kaase's real talent is interpreting rules and working with the holes found in them. Tony seems to be able to build unreal power out of "normal" combos. J.Rob
Re: BES at engine masters getting it done with a bb mopar [Re: RAMM] #2383765
10/08/17 10:27 AM
10/08/17 10:27 AM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
Works for me. I'm just going off what I've read.
Re: BES at engine masters getting it done with a bb mopar [Re: mcat4321] #2384321
10/09/17 10:26 AM
10/09/17 10:26 AM
Finally a HUSKER again
Moparnut426 Offline
Moparnut426  Offline
I would expect a change in the rules next year as Kasses engine took them to the outer limits of said "rules"
Cool as hell, but stretching them to say the least
