Re: used cam/lifters into another block. Problem or OK? [Re: CSK] #2383071
10/06/17 06:23 PM
10/06/17 06:23 PM
Eagle, Idaho
Neil Online content
The Doctor is in.
Neil  Online Content
The Doctor is in.
Eagle, Idaho
Wow, now that is pretty cool!
Re: used cam/lifters into another block. Problem or OK? [Re: RapidRobert] #2383110
10/06/17 08:04 PM
10/06/17 08:04 PM
The Netherlands
BigBlockMopar Offline
The Netherlands
I've put used solid lifters from a different cam (which had wiped a lobe) on another hydraulic cam which was also a used one.
I picked out the lifters with no visible dish.
The lifters were incomplete so I used a 3 more solid lifters from another used stash.
I put some cam-paste on them and ran them through the rpms for about 5 orso minutes.
Ran it for three years without issues.
This was in a 496" stroker with Edelbrock heads.
Re: used cam/lifters into another block. Problem or OK? [Re: RapidRobert] #2383176
10/06/17 10:29 PM
10/06/17 10:29 PM
Pittsburgh,PA
RTSrunner Offline
RTSrunner  Offline
Pittsburgh,PA
I would think break in on a machine may be a bit inaccurate due to lifter angle and spacing variables vs any given engine block it would be installed into.
RT
Re: used cam/lifters into another block. Problem or OK? [Re: RTSrunner] #2383240
10/07/17 12:34 AM
10/07/17 12:34 AM
RapidRobert Offline OP
Yeah that'd be the same as what I was considering.
Re: used cam/lifters into another block. Problem or OK? [Re: RapidRobert] #2383795
10/08/17 11:50 AM
10/08/17 11:50 AM
North Dakota
6PakBee Online content
6PakBee  Online Content
North Dakota
I think that the statements in the FSM concerning camshaft and/or lifter replacement for stock components is the best guide. I'm not going to post any of the verbiage in the FSM because if you don't have the FSM for your car, you should get one.
Re: used cam/lifters into another block. Problem or OK? [Re: 6PakBee] #2383821
10/08/17 12:32 PM
10/08/17 12:32 PM
are you talking about lifter/bore clearances? I'm haveing an issue there too (low psi). I may have to use my solid & tube it (or bush em with the current hyd).
