Re: Anybody else get overwhelmed by your car project?
[Re: BradH]
#2377512
09/27/17 12:26 AM
09/27/17 12:26 AM
Posts: 12,593 Great Neck,LI,new york
hemi-itis
Seems everything takes so much longer.Always a new issue to throw money at.I'm driving with no bumpers till next week.
[Re: dvw]
#2377564
09/27/17 08:04 AM
09/27/17 08:04 AM
Posts: 10,119 MN
JERICOGTX
MN
The idea of a project is to have fun. Don't worry about time lines. Figure out what you want to build. Move back and forth to different areas, motor, body, brackets, ect. If the part doesn't meet your expectations, redo or pitch it. Eventually the big picture will come together. You'll forget about the time spent. But you won't forget something you let slip instead of doing righht. Doug If it isn't fun, it's not worth doing... Sometimes a deadline helps. It might not get finished, but the project will for sure get pushed forward. Without a deadline, it's easy to say "I'll get to it later". One of the biggest things is you have to have the finished project pictured in your head. Having the vision helps you get there.
69 GTX
68 Road Runner
[Re: Hemi_Joel]
#2377565
09/27/17 08:05 AM
09/27/17 08:05 AM
Posts: 10,119 MN
JERICOGTX
MN
I kinda know what you mean, except I have 4 in progress right now and several more in pieces waiting their turn. Sometimes A.D.D. is brutal. KINDA??? We do not call you Captain Distracto for nothing.
69 GTX
68 Road Runner
[Re: JERICOGTX]
#2377657
09/27/17 11:26 AM
09/27/17 11:26 AM
Posts: 20,536 north of coder
moparx
in 1974 or so, i started my 33 dodge humpback project by dragging a lump out of a south carolina swamp. i had a vision that would later become termed "pro street". many, many years later, life and MS took over, and time marched on. i managed to go 42 1/2yrs as a machinist, which allowed me to acquire the skills necessary to fulfill my vision, but the effects of my health took a toll, and not much progress was made. also, the medical costs i incur each month leave not much disposable income to play with. i have many, many fabricated parts on the shelf [sub assemblies] awaiting to be installed for this build, but it is closely coming to the point of big money needing to be invested to finish this. luckily, my fab skills have saved a ton of bucks by being able to make most items needed myself instead of paying someone else to do so, including fabricating fixtures, tooling and equipment to get the results i am after. i am only able to work a few hours on any given day, health permitting, but i'm determined to see this through ! first pic is what i started with after being retrieved from the swamp. second one in 2006 gives some idea what it will look like. i don't have any recent ones, but many, many more parts have been fabbed and installed, but i'm slowly gaining......
[Re: BradH]
#2377697
09/27/17 12:28 PM
09/27/17 12:28 PM
Posts: 1,954 Blairsden, CA
Triggerfish
Blairsden, CA
As in... you look at how much work you still have left to do... and think about the $$$ you'll need to spend to get there... and how much time it will take to make real progress... and your brain starts to swell... and the thought that forms in between your ears is a 100 db scream of: "What the F-$-&-K have I gotten myself into???"
OK, all better now.
Well, not really, but it's definitely time to get off the 'puter and do something (anything) constructive... Absolutely, especially when I have 3 projects going on at the same time & need to get one done sold before winter hits. Biggest pain in the azz is vendors who can't keep their word & keep the project hanging. I usually fall asleep at nite planning some part of the build.. Keep visualizing the end result & don't give up & sell your project for pennies on the dollar.. something you'll always regret.
[Re: hudsonhornet7x]
#2377789
09/27/17 03:35 PM
09/27/17 03:35 PM
Posts: 31,261 Oregon
AndyF
I've been overwhelmed many times over the years by various projects. I have a long list of tricks to get me out of being overwhelmed but sometimes my list of tricks isn't long enough...... Care to share some of your secrets? Like I said, there is a long list of tricks. Not all of them work for everybody but some are fairly universal. If you step back from the question a bit the issue is similar to other difficult things like losing weight or stopping drinking or whatever. People have come up with tools or tricks for these things over time. 1. Peer group, support group, etc. is very helpful. If you don't have anyone local to share your build with then post a progress report on here once a week. Do it for yourself, not for anyone else. You don't even need to read the replies if you don't want to, just make the post to show yourself what you accomplished that week. 2. If you are really stuck then set an easy goal and do it. Something as simple as washing the car can be a simple goal, or sweeping out the garage. Hitting an easy goal then gets you in the mood to tackle the harder goal. 3. Order just a few parts at a time so you don't get overwhelmed with things to do when the UPS shows up. I usually order $100 worth of stuff from Summit a couple of times of week. That way I always have some new stuff showing up. Sometimes if I'm stuck then getting a box of new stuff gets me going again. 4. Find some people in your local area who can get you unstuck. I have local resources who I can toss projects to if I can't get it done. Some stuff I just can't do like installing glass or covering seats. Other things like TIG welding I can do but I'm not good at it so I take it to a shop. 5. Crank up some music, sometimes that helps. 6. Invite a friend over in a week to show them what you finished up. That will give you a little bit of a deadline to hit. 7. Take pictures on a regular basis and then flip back thru them to see what you have accomplished. Post the pictures so you have a record that you can refer back to. 8. Ask for help. A little bit of help even from someone who is unskilled can be a big deal. I had a college kid come over and help me during the summer a few times. Even if they are just sweeping the floor while you are working on the car it helps. 9. Hire some help for the non-car stuff. Have a kid mow the lawn so you don't have to do it and stuff like that. 10. Turn off the TV 11. If you are really stuck then go get some exercise 12. If you are really stuck then go do something unpleasant that needs to be done like scrub the toilets, clean the oven, etc. Sometimes that will clear your head and get you motivated to go do some car work. 13. Go to a car show and wander around looking at other projects. I could go on but I think you get the drift by now......
[Re: Al_Alguire]
#2378280
09/28/17 01:02 PM
09/28/17 01:02 PM
Posts: 4,852 Wichita
GY3
Wichita
I threw my junk together a couple of years ago and enjoy it after it languished in various storage since 1993.
The plan was to have a nicely restored and detailed car but I wanted to drive it NOW!
I keep picking at it and improving things and when something breaks or needs upgrades, I fix it quickly. It is amazing when you focus what you can accomplish.
I toasted a couple of rod bearings recently and knew I HAD to get it back on the road. I started with a bare block on Tuesday morning and by Thurday morning it was rebuilt and back in the car!
'63 Dodge 330
11.19 @ 121 mph Pump gas, n/a, through the mufflers on street tires with 3.54's. 3,600 lbs.
9.92 @ 135mph with a 350 shot of nitrous and 93 octane pump. 1.43 60 ft. 3,750 lbs.
[Re: GY3]
#2378286
09/28/17 01:08 PM
09/28/17 01:08 PM
Posts: 1,509 TN
SCATPACK 1
TN
X2 Got my current Challenger in 1981 right after I sold my SS Hemi Challenger. My current car is an early production car and I was of the mind set that it had to be back perfect. Well 30 years later I finally go t mart enough to just throw it back together and drive the heck out of it. Took a long time to get the parts back on where they went as I had torn this car down to nothing but the unibody right after I got it in 1981. Hang in there Brad it will come together. Take lots of pictures during the process.
Old Geezer Racing
[Re: parksr5]
#2378287
09/28/17 01:09 PM
09/28/17 01:09 PM
AndyF
I'm very analytical and some of these posts tie into my situation. I have a running, driving cruiser that is nice but, I'd like to restore the car some day.
I always struggle with the thought of the car being down for years while the restoration is occurring. I often wonder if I'm willing to accept that. I’ve also thought about addressing certain areas of the car but, in some situations, it would be like putting lipstick on a pig or a waste of money given I’d have to undo things I’ve already done if I did ever fully restore it.
There is some heavier metal work that I'm not willing to tackle so; it will go somewhere to have at least some of the metal work done. Then I think about the inefficiency of having a shop doing a portion of the metal work, just to bring it home to finish the remaining items. It almost makes sense just to have a shop deliver me a rolling painted car for me to reassemble. Then I struggle with the fact that I’ll look at the car for years and not have the satisfaction of having done the body work myself; especially since I did it for a living for several years and can do it. Maybe the shop doing the work won’t do it to my liking either.
I just finished all the metal and body work for my Father in Law’s 55 Ford f100. I worked on it for the past 3 Winters. My car will need more than his truck so; how long would all of this take if I did it myself? Knowing me, I’ll work on my own stuff for longer hours as I just want things done; doing this may result in not having a father in law any longer too.
Money, locating parts and all the other things also come into play.
Man, I’m getting overwhelmed just thinking about it. Seems to me you have enough data to make a decision! You've done similar projects so now you know how much time it takes and whether or not you can do it.
[Re: 70RT Charger]
#2378290
09/28/17 01:13 PM
09/28/17 01:13 PM
AndyF
I've had my Charger for 12 years. I got tired of the old rotten interior, leaks and so forth and decided to completely restore it. I'm trying desperately to get it finished. Was hoping by this fall but ain't going to happen. I'm completely restoring and replacing everything new or rebuilt. I've done lot of the work myself but do to my work schedule im paying a couple of guys to try and get it finished for me. They've been really fair with me but the cost of all of the new parts have been really staggering. Seems like they are no end to any of it. I'm about to give it a break as soon as I get my motor, trans., wiring and gauges in it. Sometimes I wished I never tore it apart and made it my Ratty muscle car lol I don't think very many people have the resources (time, money, space, tools, etc.) to tackle a full resto project. It is probably smarter for people to just do one part of the car at a time. Rebuild the brakes as one project then upgrade the suspension, then fix the heater box, then rebuild the transmission, etc. Projects like that can be handled in a few weeks each by most folks. Taking the whole thing apart tends to set off a mushroom cloud in the garage!
[Re: parksr5]
#2378532
09/28/17 09:54 PM
09/28/17 09:54 PM
Posts: 257 Way North Idaho
1KoolBee
Way North Idaho
I hear you on that one. Paint/body is most time consuming and costly part of the build for most. It would be nice to have someone complete that part as it would help the build make a huge leap forward. But with high cost (most shops around here charging $7K -12K for a quality paint job, plus any metal replacement) and all the horror stories of projects permanently screwed up by "professional" shops, parts stolen, delays, etc., its a tough hurdle to get past.
'68 Bee 383/TF/Factory Air...high school sweetheart '67 GTX Clone project,500 six pack,Hemi4-speed,Dana 05 Dodge Viper, 505 V-10, 6-speed Tremec
