Swaybar strut bushings - Nylon for Less deflection? #2380185
10/01/17 08:53 PM
10/01/17 08:53 PM
The Netherlands
BigBlockMopar Offline OP
The Netherlands
Anyone running anything else than the rubber or polyurethane bushings in the vertical struts on the anti-swaybars?
I know aboutthe center tube which can be beefed up to prevent flex but I was just wondering about the bushing material at the moment.
Re: Swaybar strut bushings - Nylon for Less deflection? [Re: BigBlockMopar] #2380243
10/01/17 09:57 PM
10/01/17 09:57 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
I think the green brick modded some spherical end links to work. I think they used ones off a Viper, rusty memory there.
Don't be the exception.
Re: Swaybar strut bushings - Nylon for Less deflection? [Re: BigBlockMopar] #2380263
10/01/17 10:16 PM
10/01/17 10:16 PM
Colorado
Bob J Offline
Bob J  Offline
Colorado
Drop links I know this is not Mopar but this is what I run on my Porsche. You can adjust out all the preload with you sitting in the car. The only down side is that you can hear them clank from time to time mainly in parking lots never driving. Love them just use plenty of anti seize.
07 Porsche C2 997.1 6spd DD and SCCA Solo II SS
68 Plymouth GTX Convert. 493cu Hotkiss Wilwood Classic air, Building for Solo II Cam
65 Chrysler 300 Convert. project
57 Desoto 2dr. Firesweep 392 Hemi,Wilwood Project with son
2003 Dodge Dakota R/T "DEAD"
Re: Swaybar strut bushings - Nylon for Less deflection? [Re: Supercuda] #2380286
10/01/17 11:07 PM
10/01/17 11:07 PM
On The Boat, On The Lake, Wa. ...
amxautox Offline
Still Retired. Still Posting on Moparts. A Lot.
amxautox  Offline
I used spherical end links on the front bar on my '71 Sebring back in the '70s. Addco bars and they came from Addco with those links. Worked great and no noise.
Tom
"Everyone should believe in something; I believe I'll go fishing."
-Henry David Thoreau
Men and fish are alike. They both get into trouble when they open their mouths
author unknown
Re: Swaybar strut bushings - Nylon for Less deflection? [Re: BigBlockMopar] #2380425
10/02/17 07:07 AM
10/02/17 07:07 AM
The Netherlands
The Netherlands
Trying googling for images but didn't find any yet.
Did notice this type online, for GM cars;
(This will only take just one set of bushings out of the link.)
The amount of space is fairly tight between the mounting points of the LCA and swaybar.
Re: Swaybar strut bushings - Nylon for Less deflection? [Re: BigBlockMopar] #2380546
10/02/17 01:15 PM
10/02/17 01:15 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
All you have to do is go to Rock Auto and look at the Viper end links.
They look to be easily shortened if need be as well.
Re: Swaybar strut bushings - Nylon for Less deflection? [Re: BigBlockMopar] #2380713
10/02/17 05:47 PM
10/02/17 05:47 PM
The Netherlands
The Netherlands
My Google Ninja-Skills were down for the flew I guess... You're right. The Viper's end links look like they could work.
Nicely priced as well.
Re: Swaybar strut bushings - Nylon for Less deflection? [Re: BigBlockMopar] #2380834
10/02/17 08:57 PM
10/02/17 08:57 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
We're here to help
Re: Swaybar strut bushings - Nylon for Less deflection? [Re: BigBlockMopar] #2381300
10/03/17 04:42 PM
10/03/17 04:42 PM
NW Chicago suburban area
Mopar Mitch Offline
Mopar Mitch  Offline
Adjusting the sway bar end-link pre-load is important IF you want to get the best balance for the 4-corners. After I've set the 4-corner weight balance, WITH the sway bar end-links disconnected, then I re-attach the end links using extra as-needed same factory metal shims around the bushings so that each end link is near equal in its compression (load) to each other. In other words, you don't want any end-link to have more load than its opposing side... it will have some effect on the corner weight balance which you want to try to keep equal LH-RH (as well as the front and rear sway bears, respectively). IF I could figure adjustable end-links, I will (someday) install them and forget about the multiple shims. I need to look at the Viper setups and others. (Also... adjusting the 4-corner weight balance and the sway bar end links should be done with the car as-driven... driver's weight in driver's seat, if possible).
Reinforcing the LCA end-link tab is helpful... weld on an additional large washer to one side (top ok).
I've also varied (fine-tuned) the end link bushings from all rubber, partial rubber/poly, all poly... per my driving style (AX/HSAX/HPDE).
Over time, the poly bushing can self-destruct when driven very hard (i.e: competition AX/HSAX/HPDE), so, good idea to inspect and replace whenever needed (carry spares with you to the races). Also, carry spare end links... they can eventually break under hard driving/competition.
Re: Swaybar strut bushings - Nylon for Less deflection? [Re: Mopar Mitch] #2381571
10/04/17 01:13 AM
10/04/17 01:13 AM
Colorado
Bob J Offline
Bob J  Offline
Colorado
Viper Adjustable ends links
I need to look at these to see if the length is the same range. If it's not I would think that get the center in a longer length and cut it to size.
Re: Swaybar strut bushings - Nylon for Less deflection? [Re: BigBlockMopar] #2381614
10/04/17 05:09 AM
10/04/17 05:09 AM
Brisvegas, Australia
Alchemi Offline
Alchemi  Offline
find some cheap tie rod ends and the appropriate threaded sleeve and nuts at a hardware store - should cost all of $40ish
Re: Swaybar strut bushings - Nylon for Less deflection? [Re: Alchemi] #2381677
10/04/17 11:26 AM
10/04/17 11:26 AM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Do you know how stock Mopar endlinks attach?
Re: Swaybar strut bushings - Nylon for Less deflection? [Re: Bob J] #2381678
10/04/17 11:30 AM
10/04/17 11:30 AM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Yeah, stoopid money
$200 EACH for stock replacements
$260 for adjustable ones.
Wee.
Even the OEM MoPar ones are cheaper at RockAuto.
The aftermarket replacements at RA are even less. Less than a tenth the price.
Re: Swaybar strut bushings - Nylon for Less deflection? [Re: Supercuda] #2381681
10/04/17 11:38 AM
10/04/17 11:38 AM
moparx Online content
moparx  Online Content
throwing something out there. is there enough length on the sway bar arms to cut off the factory ends, then mill the remaining ends 90 degrees with corresponding holes to accommodate a "tie rod" style end ? i realize this small amount of shortening will affect the bar rate. the control arm mount could easily be fabbed to utilize this style of mount, and compensate for shortening of the bar.
beer
Re: Swaybar strut bushings - Nylon for Less deflection? [Re: BigBlockMopar] #2381682
10/04/17 11:39 AM
10/04/17 11:39 AM
central IL
myduster360 Offline
myduster360  Offline
central IL
Moog has some rock hard "problem solver" links, identical to stock Srt-4. several different lengths. They claim its polyurethane but they're very rigid and feel as hard as nylon.
K700528 is for a 73 Dart
http://www.moog-suspension-parts.com/moog-k700525
1972 Swinger 3.6L Pentastar
Diablo CMR tuner
Re: Swaybar strut bushings - Nylon for Less deflection? [Re: moparx] #2381742
10/04/17 12:59 PM
10/04/17 12:59 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
beer
Yeah, you can do that. It gets well outside the realm of cheap though. I don't have a mill so I can buy one and learn how to use it or I can find a competent machine shop and pay them to do it.
I can shorten stock Viper end links with my current tool and skill set and wallet contents.
Re: Swaybar strut bushings - Nylon for Less deflection? [Re: BigBlockMopar] #2381782
10/04/17 02:17 PM
10/04/17 02:17 PM
central IL
myduster360 Offline
myduster360  Offline
central IL
Step 1 Search Ebay for "swaybar links"
Step 2Find the design you like and note its application(year/make/model)
Step 3 Order off RockAuto
10min later
$10-$40 each 2007 Lincoln Navigator
Diablo CMR tuner
Re: Swaybar strut bushings - Nylon for Less deflection? [Re: myduster360] #2381784
10/04/17 02:24 PM
10/04/17 02:24 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
2004 Viper
$15
Re: Swaybar strut bushings - Nylon for Less deflection? [Re: Supercuda] #2381792
10/04/17 02:30 PM
10/04/17 02:30 PM
central IL
myduster360 Offline
myduster360  Offline
central IL
2004 Viper
$15
Perfect!! IF only it weren't 4" too long.
Try for the bolt on before hack/weld option
Diablo CMR tuner
Re: Swaybar strut bushings - Nylon for Less deflection? [Re: BigBlockMopar] #2381810
10/04/17 02:55 PM
10/04/17 02:55 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
You got dimensions on either?
