Re: 1970 Roadrunner Project
[Re: cataclysm80]
#2379700
10/01/17 12:03 AM
10/01/17 12:03 AM
Posts: 4,165 Florida
cataclysm80
October 2016
table of parts waiting to be installed
looking over the manual trans. Looks like I'm going to need shift levers, linkages, shift mechanism with mounting bracket, shift handle with grips etc. Also need lockout linkages that go to steering column.
Coded on the Fender Tag Plum Crazy 1970 two door hardtop (no B pillar) Plymouth Road Runner with a 383 four barrel engine and console shifted 4 speed pistol grip manual trans. Premium vinyl bucket seats in a white interior with black A pillars, dash, kick panels, carpet, & seat belts. Scheduled Production Date of April 8th 1970 in St. Louis MO Light package 3.55 Performance Axle Package with Max Cooling fan & 26 inch radiator Remote control driver's side mirror 3 speed wipers Rallye Dash (standard on Road Runner) Stereo 8 Track Radio with 3 speaker dash Performance Hood Stripe Road Runner Dust Trail side stripes Reflective White Road Runner tail panel stripe
Not coded on the tag, but would have been on the Broadcast Sheet All glass factory tinted (which is a little odd for a non-air conditioned car) Woodgrain steering wheel (desireable) Power Steering Day / Night rearview mirror Carpet Ashtrays in the rear armrests were standard The Hardtop (23) armrest bases are chrome. The Coupe (21) armrest bases were color keyed unless you paid extra for the A87 Road Runner Décor Group which was only available on the Coupe (21) cars. This décor group got you chrome armrest bases, and several other upgrades which came standard on the Hardtop (23).
Factory Options being added to the car Air Grabber Hood Go-Wing Spoiler Passenger Side Mirror Hood Pins Exhaust Tips Extra Heavy Duty Suspension (Hemi Suspension) (and then some) I enjoy the 3 speaker dash, but the original 8 track was missing, so I'll use a reproduction 1970 Plymouth AM/FM with modern internals. Power Front Disc Brakes (11.75 inch, so actually larger than factory) The car originally had manual drum brakes on all four corners. I'm going to run 15 inch Rallye wheels. I've no idea what wheels the car originally had, but they were probably 14 inch. High Capacity fan blade which pulls more air at all RPM.
Modifications I'm going to run Pertronix electronic ignition inside the distributor. I want electronic ignition, but these cars never had it, so it will remain mostly hidden inside the distributor. The original antenna was also missing. I'll use a power antenna with a stock bezel so that it looks close to original, but a car cover will be easy to use. Power Antennas that use stock bezels are made by Retro Sound. I ordered one through Classic Industries. Radial Tires and improved suspension
[Re: cataclysm80]
#2379704
10/01/17 12:17 AM
10/01/17 12:17 AM
cataclysm80
January 2017
The engine is still patiently waiting.
