Re: Need 440 Fuel Pump
[Re: 44D6PAKCUDA]
#237824
03/01/09 07:32 PM
03/01/09 07:32 PM
Posts: 2,852 Dallas, TX
70challrtse
super gas
super gas
Dallas, TX
You can also bolt on a Hemi filter. That's what I had on mine until I knew better.
[Re: Prodart440]
#237827
03/02/09 03:34 PM
03/02/09 03:34 PM
Posts: 15,134 Kelowna, B.C. Canada
DPelletier
What do you mean until you knew better???
I don't know what HE meant, but I also bought the Hemi pump and was about to use it until several knowledgable people told me it'd have way too much pressure for my 6 Pack. It was a carter that came from Chrysler and was rated at 8.7 PSI; I was told that anything over 5-6PSI was too much.
I ended up using the M4845 pictured above.
1970 Super Bee 440 Six Pack
1974 'Cuda
2008 Ram 3500 Diesel
2006 Ram 3500 Diesel
2004.5 Ram 2500 Diesel
2003 Ram 3500 Diesel
2006 Durango Limited
[url] http://1970superbee.piczo.com [/url]
[Re: DPelletier]
#237828
03/02/09 03:40 PM
03/02/09 03:40 PM
Posts: 878 Avondale AZ
Prodart440
Avondale AZ
Would that be too much for a Holley??
Aaron
68 Roadrunner 383/AT 69 Dart GT Conv. 383/AT 05 Dodge Ram 4x4 Cummins 06 GoManGo R/T Daytona #757 68 Coronet 440
[Re: Prodart440]
#237829
03/02/09 03:41 PM
03/02/09 03:41 PM
70challrtse
super gas
super gas
Dallas, TX
Someone told me it was wrong. It worked fine on my U code, but obviouly not was not aesthetically correct.
[Re: Prodart440]
#237830
03/02/09 06:32 PM
03/02/09 06:32 PM
DPelletier
I would imagine so (after all the 6 pack centre carb is basically half a 4150), but I have no relevant direct experience.
1974 'Cuda
[Re: DPelletier]
#237831
03/02/09 09:56 PM
03/02/09 09:56 PM
Posts: 173 Florida
hemisurfer
I run the Hemi 120gph pump 8.5 psi max with no regulator on a six pack and it works great. Pulls hard through all the gears. At the worst you would need to add a regulator, if i did that I would set it at 7.5 psi, as far as the 120 gph the engine won't use more fuel than it needs but it certainly will run bad if it doesn't get enough. I used some of the other Carter pumps and my engine layed over in 3rd and 4th gear and ran like crap, didn't pull the way it should have. The other pumps discussed are prob fine for stock rebuilds, any modifications and I would use the Hemi pump. Just my
Chris
[Re: DPelletier]
#237832
03/03/09 07:04 PM
03/03/09 07:04 PM
Posts: 5,123 Warrenton, VA
RoadRunnerJD
Warrenton, VA
I use a Hemi type pump on mine but it has a max of 7.5 psi pressure. Carter has several. The #4589 pump has a 3/8" inlet. I use the 3/8" Hemi fuel line from the tank and am planning to switch over to the 6.5 psi #4845 from my current 7.5 psi Hemi type pump. You can get whatever you want from Summit. It's not a bad deal except for the mandatory $9.00 handling charge...or is it more now? Check out the available Carter pumps on the link below. Click on the part number for the specs. http://store.summitracing.com/egnsearch....&rsview=sku
[Re: RoadRunnerJD]
#237833
03/03/09 07:20 PM
03/03/09 07:20 PM
Posts: 173 Florida
hemisurfer
The 6.5 flows 80gph the 8.5 psi flows 120gph. My car wanted the extra volume.
Chris
[Re: RoadRunnerJD]
#237835
03/03/09 08:26 PM
03/03/09 08:26 PM
Posts: 173 Florida
hemisurfer
I have no issues with the 8.5 psi pump the part number is 4862 you might be right on the flow for the part you mentioned there is another version that only flows 80gph. Check it at Mancini. I have no issues with the 8.5 psi not blowing past the seat 6 pack runs strong with no issues. Real world...if there was an issue all you need is a reg after the pump set it to 7.5 psi. A good six pack will run out of steam with the lower psi IMO.
Chris
