Page 8 of 8 1 2 3 4 5 6 7 8
Re: Vibration at 2500 rpm [Re: pjc360] #2378236
09/28/17 12:52 PM
09/28/17 12:52 PM
You can drill out the pin & sub in a new one for the wobble & Nacho bent the magnet & got the gap change down to .001" (iirc) but a plug & play unit is a bennie.
Re: Vibration at 2500 rpm [Re: RapidRobert] #2378511
09/28/17 10:13 PM
09/28/17 10:13 PM
montana
P
pjc360 Offline OP
pjc360  Offline OP
P
montana
Ya I tried messing with my unit from don at fbo systems to get the advance plate more sturdy and nothing really worked, I wrapped some teflon tape around the pin and tried bending the magnet and I just ended up getting frustrated and giving up on it.
I still can't believe that vibration I was feeling at 2500 rpm was from rotor phasing.
I would have never guessed that was the issue, I thought for sure it was a balance issue with the engine or a drivetrain issue somewhere.
Just goes to show you should always rule out ignition first even when it comes to something that doesn't quite seem like it could be ignition related.
Re: Vibration at 2500 rpm [Re: 360view] #2393497
10/26/17 07:51 PM
10/26/17 07:51 PM
Windsor, ON, Canada
Diplomat360 Offline
Diplomat360  Offline
Windsor, ON, Canada
360view:
Originally Posted By 360view
A special meter is useful to track down ignition faults.
I now have two of these Actron KAL Equip 2969 three way ignition testers
http://www.ebay.com/itm/Kal-Equip-Spark-...509&vxp=mtr
Any chance you have the manual for this unit?
I picked one up, but no instructions included, I suppose the only question I have is what to do with the small aligator clip wire? I think it attaches to the signal (-ve?) coil terminal? I'm guessing the unit uses that to start the signal timer for measuring the duration?
Thanks!
Re: Vibration at 2500 rpm [Re: pjc360] #2410625
11/29/17 12:16 PM
11/29/17 12:16 PM
montana
P
pjc360 Offline OP
pjc360  Offline OP
P
montana
Bump for rapid Robert
