Re: Bought my first 400 Block this Weekend
[Re: Dragula]
#2332071
07/05/17 06:27 PM
07/05/17 06:27 PM
Posts: 13,492 Marion, South Carolina [><]
an8sec70cuda
The headers with -1 heads on the low deck should sit in almost the same place as the EZ heads on the RB block. Looks nice Randy, hope it runs good for you!
CHIP '70 hemicuda, 575" Hemi, 727, Dana 60 '69 road runner, 440-6, 4 speed, Dana 60 '71 Demon 340, no drivetrain, on blocks behind the barn '73 Chrysler New Yorker, 440, 727, 8.75 '90 Chevy 454SS Silverado, 476" BBC, TH400, 14 bolt '06 GMC 2500HD LBZ Duramax
[Re: an8sec70cuda]
#2332107
07/05/17 07:22 PM
07/05/17 07:22 PM
Posts: 12,477 Taxes & Virus's R-US, NY
Dragula
The headers with -1 heads on the low deck should sit in almost the same place as the EZ heads on the RB block. Looks nice Randy, hope it runs good for you! I can always upgrade later....Been really happy with the performance of this mild wedge so far. Doesn't flow anything like Hemi heads, but it stays together, and just works in a stock block. My next build, I want to do a 383/496 from 440Source with the light weight crank again, and an F1R on pump gas...
[Re: cudadon]
#2333147
07/07/17 03:59 PM
07/07/17 03:59 PM
Posts: 2,131 New Lenox IL
cudadon
New Lenox IL
Who built your short block? Dwayne did my SR MW 765 hp on RBRE dyno. 337 cfm @ .650
Don 496 ci 12.8:1 on E86 Don
[Re: cudadon]
#2333166
07/07/17 04:34 PM
07/07/17 04:34 PM
Dragula
Don Farley's Racing Engines here in the Lockport area...Waiting on push rods and a low deck distributor...Goes back in the car next weekend. 9.59 at 140mph is the goal....And maybe upgrad to 440-1's next year.
[Re: Whompin_Wedge]
#2333246
07/07/17 07:00 PM
07/07/17 07:00 PM
Dragula
Why 9.59? lol
Just curious..
Thanks,
Casey Well it went 9.70 with the 440/512...We figure 50lbs off the front, and that would put us at 9.65, then maybe a tad more performance for another 1/2 tenth, maybe?...9.5 anything would be really awesome.
[Re: Dragula]
#2333273
07/07/17 08:08 PM
07/07/17 08:08 PM
Triple Threat
Renton Washington
Why the switch from Tall deck to low deck? Seems like the old combo was working fine?
[Re: Triple Threat]
#2333293
07/07/17 08:41 PM
07/07/17 08:41 PM
Dragula
Why the switch from Tall deck to low deck? Seems like the old combo was working fine? Well, a bunch of reasons, why not....we had the block, and we had not done a serious build on one..We see other folks flog the heck of them, and say they have zero issues. Rod angle is way better, mains are smaller, less surface area for oil to hide, 40-50lbs lighter, roomier engine bay... The RB engine has been in the car a while and is due for a good going thru, and as performance has increased, so has the rpm across the strip..Which is putting us in a spot where we either need 4.30 Dana 60 gears or preferably somthing that will go a little more rpm without any issues when we do race the 1/4. We do not want to push the rpm in an RB... We have seen very mild cap walk on some tear downs, and we know it was not timing, so we try and stay 6500rpm or under. But we seem to be crossing lately at 6700rpm...Luckily we mostly run 1/8th mile. Also, its a smaller package and give us a little room under the hood as well as a weight reduction.
[Re: Triple Threat]
#2333321
07/07/17 10:15 PM
07/07/17 10:15 PM
Posts: 43,725 Bend,OR USA
Cab_Burge
Why the switch from Tall deck to low deck? Seems like the old combo was working fine? All the 400 blocks have a lot thicker main web in them than any of the production RB or the earlier B blocks I'm looking forward to my next low deck build of 511 C.I. with either one of the new cast iron former Muscle Motor blocks or one of the stock type 400 blocks I have in stock. Shooting for 800 + HP on E85 with the stock block Or 900 HP + with the after market block and better heads
[Re: Dragula]
#2333595
07/08/17 01:22 PM
07/08/17 01:22 PM
Posts: 14,531 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
I see you cleaned up the appearance of the intake manifold. Looks nice like that.
[Re: fast68plymouth]
#2333761
07/08/17 07:26 PM
07/08/17 07:26 PM
Dragula
I see you cleaned up the appearance of the intake manifold. Looks nice like that. Yes....I remove anything not needed...I can't help myself anymore, all of mine are done that way...
[Re: Dragula]
#2337467
07/15/17 05:58 PM
07/15/17 05:58 PM
Cab_Burge
