MODERN CYLINDER HEAD
#2376958
09/26/17 04:43 AM
09/26/17 04:43 AM
Posts: 608 TN
1DGEMAN
TN
Don't take your parts to Modern Cylinder Head. They have had a good friends 308 heads intake manifold and rocker arms for 13 months and have nothing but excuses why they are not finished. Very poor business practices.
Real Men shift for themselves
Re: MODERN CYLINDER HEAD
[Re: 1DGEMAN]
#2377033
09/26/17 11:32 AM
09/26/17 11:32 AM
Posts: 1,561 Michigan
Kiddart
If Modern is so slow is there another option in the area to take heads to for work and or repair?
Thank you Kiddart
[Re: 1DGEMAN]
#2377131
09/26/17 01:16 PM
09/26/17 01:16 PM
Posts: 1,495 Shelby mi.
JAKE68
Shelby mi.
Got be another side of the story not being told.
JAKES AUTOMOTIVE
[Re: 1DGEMAN]
#2377168
09/26/17 02:15 PM
09/26/17 02:15 PM
Posts: 608 TN
1DGEMAN
TN
There is no other side of the story many phone calls, e mails and letters not bashing just telling the truth. These heads are for an NHRA Super Stock engine not your run of the mill bracket motor and were supposed to be done in a timely manner.
[Re: 1DGEMAN]
#2377189
09/26/17 02:47 PM
09/26/17 02:47 PM
JAKE68
Shelby mi.
Now I now what heads those are . very time consuming job. And there is another side to the story.
JAKES AUTOMOTIVE
[Re: 1DGEMAN]
#2377208
09/26/17 03:24 PM
09/26/17 03:24 PM
Posts: 608 TN
1DGEMAN
TN
No other side of the story if you take in work and make promises then you do the work. They have done this job before they know the work involved if you have no intention of doing the job don't take money and then blow the customer off. Total lack of integrity!
[Re: 1DGEMAN]
#2377234
09/26/17 04:44 PM
09/26/17 04:44 PM
Posts: 3,210 robin hood country
deaks
robin hood country
I bought my heads from modern, and they were great to deal with, yes they are busy but that's usually the case with anyone who's good at what they do. Also i had damage to one of the heads when my motor let go, Bob repaired that for me and was as good as Jeff to deal with. Mick
69 Dart GTS 440 mopar .590 cam, Edelbrock heads, 3200# best et 6.45, 106.78, 10.14, 132.88 mph, 1.47 60ft best 60ft 1.36
[Re: scottb]
#2377261
09/26/17 05:44 PM
09/26/17 05:44 PM
Posts: 1,845 Tampa
DusterDave
Tampa
I just talked to Bob about those heads and got the other side of the story if what he is telling me is the truth i would not do those heads either If that's the case, then Bob should call the customer and explain the situation with the heads, return the heads and his money.
Gone to the dark side with an LS3 powered '57 Chevy 210
[Re: DusterDave]
#2377264
09/26/17 06:06 PM
09/26/17 06:06 PM
Posts: 4,715 Wichita
GY3
Wichita
Bob cnc-ported my heads and turned them around in less than two weeks.
[Re: GY3]
#2377271
09/26/17 06:26 PM
09/26/17 06:26 PM
Posts: 20,207 PA.
pittsburghracer
"Little"John
"Little"John
PA.
Bob cnc-ported my heads and turned them around in less than two weeks. Going from what it says above these are Super Stock heads. Super Stock heads are on the edge of cheating and grey areas. NOT your typical job of throwing them on a CNC and walking away. Even the valve job takes extra special care.
[Re: pittsburghracer]
#2377277
09/26/17 06:40 PM
09/26/17 06:40 PM
Posts: 43,375 Bend,OR USA
Cab_Burge
Bob cnc-ported my heads and turned them around in less than two weeks. Going from what it says above these are Super Stock heads. Super Stock heads are on the edge of cheating and grey areas. NOT your typical job of throwing them on a CNC and walking away. Even the valve job takes extra special care. That be true, especially on SS Hemiroid heads ![shruggy shruggy](/ubbthreads/images/graemlins/custom/shruggy.gif)
[Re: 1DGEMAN]
#2377284
09/26/17 07:02 PM
09/26/17 07:02 PM
Posts: 9,826 las vegas
70AARcuda
las vegas
Don Little does a lot of SS and Stock heads for small block mopars out on the west coast...
Tony
70 AARCuda Vitamin C 71 Dart Swinger 360 10.318 @ 128.22(10-04-14 Bakersfield) 71 Demon 360 10.666 @122.41 (01-29-17 @ Las Vegas) 71 Duster 408 (10.29 @ 127.86 3/16/19 Las Vegas)
