Re: Cam Bearings on 77 440 - Loose Flakes [Re: Clair_Davis] #2383698
10/08/17 01:59 AM
10/08/17 01:59 AM
Congratulations up
A little knowledge, hard work and perserverance pays off again up bow wrench
Re: Cam Bearings on 77 440 - Loose Flakes [Re: Clair_Davis] #2383703
10/08/17 02:05 AM
10/08/17 02:05 AM
MR_P_BODY Offline
MR_P_BODY  Offline
You basically did as I said by cutting the
slots in the cam.. I cut them about 1/8" deep
maybe a little less but when you spin the cam
it cuts like a knife.. glad to hear you got it.
People that do it for a living do the whole
thing in a minute.. for them time is money..
but thats where I learned it at
EDIT
I use a .040 cut off wheel to cut the slots
wave
Re: Cam Bearings on 77 440 - Loose Flakes [Re: MR_P_BODY] #2383790
10/08/17 11:32 AM
10/08/17 11:32 AM
moparx Online content
moparx  Online Content
for some reason, i thought those slots should be cut on a diagonal ? shruggy or doesn't it matter ? i like the approximate 1/8" depth of cut, and i used a .035 wheel.
beer
Re: Cam Bearings on 77 440 - Loose Flakes [Re: moparx] #2383802
10/08/17 11:58 AM
10/08/17 11:58 AM
MR_P_BODY Offline
MR_P_BODY  Offline
beer
I really dont think it matters if they are
cut on a diagonal or not.. its to get the
trash out of the way.. I flood it with oil
when I cut so the trash is being removed
wave
Re: Cam Bearings on 77 440 - Loose Flakes [Re: Clair_Davis] #2384026
10/08/17 06:22 PM
10/08/17 06:22 PM
The Netherlands
BigBlockMopar Offline
The Netherlands
A diagonal cut might have some 'self cleaning' properties if lubed properly.
If not it could 'store' more scrapings before needing to be cleaned.
Re: Cam Bearings on 77 440 - Loose Flakes [Re: MR_P_BODY] #2384145
10/08/17 10:36 PM
10/08/17 10:36 PM
Fort Worth, TX
Clair_Davis Offline OP
Fort Worth, TX
EDIT
wave
Yes, thanks for that tip, it worked great! I thought about cutting the groove on a diagonal, but I wasn't sure how well I could pull that off with a hacksaw, and I wanted the cutting edge to be straight and sharp. I should have cut the groove deeper, that would have let me cut a bit longer and reduced the number of times I had to R&R the cam to clean the groove out.
Another thing I did that worked well was pack the oil feed holes with axle grease. This caught all of the loose cuttings and kept them from falling down the oil feed. I didn't do this for the feed lines to the heads, since I figure I can flush those out with some brake cleaner from up above.
Thanks again for all the tips and advice to keep this project moving!
Clair
Re: Cam Bearings on 77 440 - Loose Flakes [Re: Clair_Davis] #2384242
10/09/17 01:33 AM
10/09/17 01:33 AM
Southern Alberta
Uberpube Offline
Uberpube  Offline
Southern Alberta
Did you try chilling them? On some projects with press fit bearings, I've been able to pop them in by hand if you get enough temperature difference, and the clearances seem to work out better.
