There are things that can effect both numbers; spinning the tires before breaking the beams, jerking the tire straight up out of the beam when the car normally drives out and up, not staging in the same location everytime, parts broken or worn (i.e. converter). But RT stops and ET starts when the front tire clears the stage beam.
