Re: '76 3/4 ton, light versus heavy. [Re: bboogieart] #2376507
09/25/17 03:18 PM
09/25/17 03:18 PM
Richmond, Indiana
19swinger70 Offline
19swinger70  Offline
Richmond, Indiana
Originally Posted By bboogieart
Originally Posted By 19swinger70
My W300 has 5/8" studs. Not sure about the 3/4 ton trucks?
Was the 300 a 4 wheel drive, 1 ton truck?
Yes. Mine is a 1 ton Dump. Full Time 4x4.
1970 340 swinger. sublime
1967 barracuda fastback BB
55 Plymouth Project
Re: '76 3/4 ton, light versus heavy. [Re: 19swinger70] #2376517
09/25/17 03:27 PM
09/25/17 03:27 PM
Lost and Spaced
bboogieart Offline OP
Lost and Spaced
Sounds like a neat rig.
I have mechanical Aptitude.
I can screw up anything.
Re: '76 3/4 ton, light versus heavy. [Re: bboogieart] #2376771
09/25/17 09:48 PM
09/25/17 09:48 PM
Granite Bay CA
Kern Dog Offline
Striving for excellence
Kern Dog  Offline
Granite Bay CA
You guys ever heard of a "Camper 9000" ?
I had a 1974 truck with fender emblems reading Camper 9000. It had the fat 5/8 lugs, super heavy Dana 60 or 70, not sure which. The rear drum brakes were immense and hard to find used.
Re: '76 3/4 ton, light versus heavy. [Re: bboogieart] #2376917
09/26/17 01:00 AM
09/26/17 01:00 AM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
In 1974 Dodge was still building big trucks like semi tractors and 4-5 ton trucks. Some of the pickup style campers were getting pretty big as well. It would not be out of the realm of possibilities Dodge created a super heavy duty pickup to cart around those huge campers. It could also be possible Dodge joined with a camper manufacturer to build a special unit.
After all that, the 1 ton (5/8" wheel studs) brakes and suspension was pretty massive and could be hard to find in some locations. Gene
Re: '76 3/4 ton, light versus heavy. [Re: ruderunner] #2376934
09/26/17 01:59 AM
09/26/17 01:59 AM
n.c.
geo. Offline
geo.  Offline
n.c.
Originally Posted By ruderunner
Think you should be able to swap studs. Not sure the whole hub and rotor combo swaps.
As for model designation,. D is 2wd,. W is 4wd. 100 is light half ton, 150 is heavy half, these came about in the mid 70's due to emission regs. 200 is 3/4 and 300 is 1ton.
The 9500 tossed out above is referring to gvw.
I remember reading that the 150 designation was what allowed the '78 Little Red to have a higher GVWR and therefore escape the catalytic converter requirement.
I wonder if all 150s in '78 escaped the converter requirement?
Good luck on the stud search!
Re: '76 3/4 ton, light versus heavy. [Re: bboogieart] #2376966
09/26/17 07:47 AM
09/26/17 07:47 AM
ohio
ruderunner Offline
ruderunner  Offline
ohio
Dodge wasn't the only company to offer higher gvw half tons in order to get away from catalytic converter on the trucks.
Ford offered the F-150 starting in 76, Ih offered Scouts with the XLc package, GMC had I think the Big10 package and Chevy just called them heavy half.
Angry white pureblood male
Re: '76 3/4 ton, light versus heavy. [Re: bboogieart] #2377002
09/26/17 10:29 AM
09/26/17 10:29 AM
Richmond, Indiana
19swinger70 Offline
19swinger70  Offline
Richmond, Indiana
It is a handy blunt object to have around!
55 Plymouth Project
Re: '76 3/4 ton, light versus heavy. [Re: 19swinger70] #2377115
09/26/17 12:58 PM
09/26/17 12:58 PM
Lost and Spaced
Lost and Spaced
That is one gorgeous Dump truck.
Re: '76 3/4 ton, light versus heavy. [Re: bboogieart] #2377523
09/27/17 01:59 AM
09/27/17 01:59 AM
MN
58pwrwgn Offline
58pwrwgn  Offline
MN
They put 5/8 studs on my 58 W100. D44 front and 8 3/4 rear. 6 on a 7 1/4 circle 1 ton style pattern.
