Re: keep wearing out my T&D rockers
[Re: ccdave]
#2375219
09/22/17 09:35 PM
09/22/17 09:35 PM
Posts: 1,169 Virginia Beach, VA
Old School
Virginia Beach, VA
This is why I like to use Comp Ultra Pro Magnum rockers on street cars with big boy valve springs. Those look interesting and they say they can handle up to 850 pounds of open pressure.....
68 cuda formula S 588" bb 5sp 70 CUDA CONVERT 500" 5SP (SUBLIME) 70 CUDA CONVERT 500" 5SP (PLUMCRAZY):TOO MUCH HORSEPOWER, IS ALMOST ENOUGH!
[Re: Old School]
#2375294
09/23/17 12:44 AM
09/23/17 12:44 AM
Posts: 5,399 Aurora, Colorado
451Mopar
Aurora, Colorado
I have about 2000 miles on my T&D rockers, ran them on the MW victors with the PAC1325 springs, and currently with the stiffer 1326 springs. Not using any oil restrictors to the heads on mine? I haven't had issues (with the rocker arms) so far, just the Edelbrock rocker stands.
[Re: Old School]
#2375386
09/23/17 11:03 AM
09/23/17 11:03 AM
Posts: 4,209 New York
polyspheric
New York
if the rocker body bores are not wore out
660 bronze insert
Boffin Emeritus
[Re: polyspheric]
#2375489
09/23/17 02:36 PM
09/23/17 02:36 PM
Posts: 1,328 St. Louis, MO
mopardamo
St. Louis, MO
660 bronze insert This is the way to go if it were up to me. I'd also check the OD of the shaft in multiple areas. Something is amiss!
[Re: Old School]
#2375520
09/23/17 03:20 PM
09/23/17 03:20 PM
Posts: 14,506 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
The OP says the bearings and shafts are not worn....... So it shouldn't be an oil supply problem. That being said, I usually run a .060 restrictor with Indy heads that are externally full time oiled.
From what I'm reading, it sounds like the bearing races are loose in the bodies. To me, that's an indication the bores in the rocker bodies have distorted.
So far, no one who has posted has run as many miles on these rockers as the OP with the same kind of spring loads he has.
[Re: Old School]
#2375527
09/23/17 03:32 PM
09/23/17 03:32 PM
BradH
Like the title says, I keep wearing them out. I get maybe 4000 miles out of them. all on the street. So, this is not the first set to have this problem? I don't know how aggressive the Indy R1 lobes are, but maybe they're not really "street friendly" and - in conjunction with those stiff springs - you're simply wearing parts out that fast wracking up miles on the street.
[Re: Old School]
#2375556
09/23/17 05:01 PM
09/23/17 05:01 PM
fast68plymouth
So. Burlington, Vt.
Another question I have is...... What is the actual installed height of the springs? If someone set the springs up to the now popular .050-.080 from coil bind at full lift, that would have the installed height pretty short for the 1225 spring and only .650-.670 lift. Set up in that scenario, the springs could be well over 300lbs closed.
Also, I've used PAC 1225's a number of times, and they are usually several pounds stiffer than spec as they come ootb.
