money not needed to be spent on yet.
i run it on 91, 22-38 timing, fires right up. pulls hard doesn't complain.
its a street vehicle and usually around 8 lbs. doesn't see 12 lbs till 5k+
its got a nice grind on the cam, best push-rods i could find. magnum 3/8s 9.300 long.
replaced the lifter retainers with snap rings.
nothing comes loose or has slack. works well with the valves i made and the 2 inch porting on exhaust side.
TTI440-200 headers. hardly goes past 180 in temps 210 if pushing it hard.
its a 3 speed with 4.88 rear. it doesnt see over 60mph much.
and in canada anything traveling 30mph over limit is a 10k fine. car impounded for a week. and loss of licenece.
i apparently do need a throttle/kickdown to be installed so i dont burn up the 727.
or perhaps go full manual valve body but dont feel like taking the trans out yet to cork the breather and relocate to rear.
eye candy is here and here. sadly the memory card lost the engine and transmission buildups.
https://imgur.com/a/Z8ZsQhttps://imgur.com/a/OHeK8https://imgur.com/a/iZPDI
