Re: keep wearing out my T&D rockers [Re: Old School] #2375188
09/22/17 08:17 PM
09/22/17 08:17 PM
America
WedgeFED Offline
WedgeFED  Offline
America
So your Jesel rockers were paired shafts and the T&D are a single shaft correct? Huge difference between the two.
Re: keep wearing out my T&D rockers [Re: Old School] #2375211
09/22/17 09:01 PM
09/22/17 09:01 PM
Mopar Country, Mi
ccdave Offline
The Ultimate
ccdave  Offline
The Ultimate
Mopar Country, Mi
This is why I like to use Comp Ultra Pro Magnum rockers on street cars with big boy valve springs.
Re: keep wearing out my T&D rockers [Re: ccdave] #2375219
09/22/17 09:35 PM
09/22/17 09:35 PM
Virginia Beach, VA
O
Old School Offline OP
O
Virginia Beach, VA
Those look interesting and they say they can handle up to 850 pounds of open pressure.....
68 cuda formula S 588" bb 5sp
70 CUDA CONVERT 500" 5SP (SUBLIME)
70 CUDA CONVERT 500" 5SP (PLUMCRAZY):TOO MUCH HORSEPOWER, IS ALMOST ENOUGH!
Re: keep wearing out my T&D rockers [Re: Old School] #2375294
09/23/17 12:44 AM
09/23/17 12:44 AM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
I have about 2000 miles on my T&D rockers, ran them on the MW victors with the PAC1325 springs, and currently with the stiffer 1326 springs. Not using any oil restrictors to the heads on mine?
I haven't had issues (with the rocker arms) so far, just the Edelbrock rocker stands.
Re: keep wearing out my T&D rockers [Re: Old School] #2375386
09/23/17 11:03 AM
09/23/17 11:03 AM
New York
polyspheric Offline
polyspheric  Offline
New York
if the rocker body bores are not wore out
660 bronze insert
Boffin Emeritus
Re: keep wearing out my T&D rockers [Re: Old School] #2375388
09/23/17 11:06 AM
09/23/17 11:06 AM
Tulsa, Oklahoma
340Cuda Offline
340Cuda  Offline
Tulsa, Oklahoma
I don't know which ones, but some Comp Rocker Arms are made by T&D.
Re: keep wearing out my T&D rockers [Re: polyspheric] #2375489
09/23/17 02:36 PM
09/23/17 02:36 PM
St. Louis, MO
mopardamo Offline
mopardamo  Offline
St. Louis, MO
660 bronze insert
This is the way to go if it were up to me. I'd also check the OD of the shaft in multiple areas. Something is amiss!
Re: keep wearing out my T&D rockers [Re: Old School] #2375503
09/23/17 02:52 PM
09/23/17 02:52 PM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
Just was thinking, check that the reduced diameter of the hold down studs is aligned with the center of the T&D rocker shafts. The T&D shafts are a smaller OD, with thick walls, and a regular bolt or stud (not reduced at the shaft center location) could block oil flow through the shaft.
Re: keep wearing out my T&D rockers [Re: Old School] #2375516
09/23/17 03:10 PM
09/23/17 03:10 PM
St. Louis, MO
mopardamo Offline
mopardamo  Offline
St. Louis, MO
Right, if the special stud from T&D is not being used then oil flow could be a concern on the BBM.
Re: keep wearing out my T&D rockers [Re: Old School] #2375520
09/23/17 03:20 PM
09/23/17 03:20 PM
So. Burlington, Vt.
fast68plymouth Online content
fast68plymouth  Online Content
So. Burlington, Vt.
The OP says the bearings and shafts are not worn....... So it shouldn't be an oil supply problem.
That being said, I usually run a .060 restrictor with Indy heads that are externally full time oiled.
From what I'm reading, it sounds like the bearing races are loose in the bodies.
To me, that's an indication the bores in the rocker bodies have distorted.
So far, no one who has posted has run as many miles on these rockers as the OP with the same kind of spring loads he has.
Re: keep wearing out my T&D rockers [Re: Old School] #2375527
09/23/17 03:32 PM
09/23/17 03:32 PM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
Originally Posted By Old School
Like the title says, I keep wearing them out. I get maybe 4000 miles out of them. all on the street.
So, this is not the first set to have this problem?
I don't know how aggressive the Indy R1 lobes are, but maybe they're not really "street friendly" and - in conjunction with those stiff springs - you're simply wearing parts out that fast wracking up miles on the street.
Re: keep wearing out my T&D rockers [Re: Old School] #2375538
09/23/17 04:03 PM
09/23/17 04:03 PM
AndyF Offline
AndyF  Offline
Probably a harmonic issue. Something about the combination of springs, pushrod, rocker arms and lobe and the RPM. Something as simple as changing to a stiffer pushrod might solve it but without spintron time you won't know for sure. More likely you can solve it by going with a less aggressive cam lobe and taking some spring pressure out of it.
I think the Indy R1 is a Comp grind but it has been a few years since I looked at one. If it uses Comp lobes then you could talk to Comp tech line and ask about spring pressures. The guys at T&D also might have some ideas. What pushrods are you running? If they aren't 7/16 or 1/2 inch then you might want to try that first.
Re: keep wearing out my T&D rockers [Re: Old School] #2375540
09/23/17 04:13 PM
09/23/17 04:13 PM
st.louis,mo.
dart games Offline
dart games  Offline
st.louis,mo.
go to harland sharp and dont look back,leave the t&d for drag engines,i seen a while back someone had probloms with t&d rockers,you never hear of anyone having problems with harland sharp,they might not require the restrictors on t&d,does the t&d has lash caps,i know mine on the indy 440-1 has them,on the indy sr heads i have i use harland sharps
Re: keep wearing out my T&D rockers [Re: Old School] #2375556
09/23/17 05:01 PM
09/23/17 05:01 PM
So. Burlington, Vt.
So. Burlington, Vt.
Another question I have is...... What is the actual installed height of the springs?
If someone set the springs up to the now popular .050-.080 from coil bind at full lift, that would have the installed height pretty short for the 1225 spring and only .650-.670 lift.
Set up in that scenario, the springs could be well over 300lbs closed.
Also, I've used PAC 1225's a number of times, and they are usually several pounds stiffer than spec as they come ootb.
