Page 4 of 4 1 2 3 4
Re: Projected tip plugs more prone to detonation? [Re: CSK] #2375473
09/23/17 02:15 PM
09/23/17 02:15 PM
Mt Morris Michigan
mopar dave Offline
mopar dave  Offline
Mt Morris Michigan
Just ordered a set in a 6. See how those do. I put ngk race 7's in and had an intermittant misfire.
Re: Projected tip plugs more prone to detonation? [Re: mopar dave] #2375485
09/23/17 02:33 PM
09/23/17 02:33 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Unless you have a bad plug, connection or ? no reason the 7's should cause a misfire as I've run em w/zero issues at 12.1.1 comp..........
Re: Projected tip plugs more prone to detonation? [Re: Thumperdart] #2375548
09/23/17 04:42 PM
09/23/17 04:42 PM
Mt Morris Michigan
mopar dave Offline
mopar dave  Offline
Mt Morris Michigan
Dont know but definitely had more misfires on the race 7's than the projected tip 5's. Could be that running on the edge of rich may not clean off the 7 like it does the 5's. Gonna leave the 7's awhile and see how they work out.
Re: Projected tip plugs more prone to detonation? [Re: davenc] #2375600
09/23/17 06:41 PM
09/23/17 06:41 PM
crabman173
crabman173
We run R5671-8 NGK with 13.7:1 on alky perfect!
It is a recessed tip we use an old Vertex magneto run the gap about .018
It lights a 10% nitro alky mix perfectly would run more nitro but have way to much compression--next one is an 11:1 so we can lay the juice to it!
I will call NGK and buy exactly what they say
Re: Projected tip plugs more prone to detonation? [Re: mopar dave] #2375658
09/23/17 08:36 PM
09/23/17 08:36 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
No experience ever running hotter than maybe a 6 in ngk and that's too hot for most of what I mess with but you are close to 11.1 iirc so not exactly low comp. and if in fact it liked the 5's I'd look real close at the porcelain w/a mag. glass and see how they look but still say #7 if the tunes close............... beer Just re read that you ran non projected tips in a 7..........Is that correct cos that's not the best plug for you imo, get the 7 projected tip and let tune this thing............ work
Re: Projected tip plugs more prone to detonation? [Re: Thumperdart] #2375676
09/23/17 09:11 PM
09/23/17 09:11 PM
Mt Morris Michigan
mopar dave Offline
mopar dave  Offline
Mt Morris Michigan
Yes, the non projected tip race plug in a 7. I misunderstood you. Thought thats what i needed. The 5's looked too hot to me as the ground straps are burned white almost to the weld on the shell. I have some 6's with the double strap on the way. Ill try those next.
Re: Projected tip plugs more prone to detonation? [Re: mopar dave] #2375767
09/24/17 01:06 AM
09/24/17 01:06 AM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
No biggie but I thought I gave you the stocking # 5030 and plug number BCP7ES but either way, get these and see if they help............. thumbs
Re: Projected tip plugs more prone to detonation? [Re: Thumperdart] #2375873
09/24/17 12:40 PM
09/24/17 12:40 PM
Mt Morris Michigan
mopar dave Offline
mopar dave  Offline
Mt Morris Michigan
yes you did, but you also gave me a stock # 7173, which is what i used to run in my small block. no big deal thou. ill try the new 6's when they get here. until then, i will use the 7 race plug. thanks
Re: Projected tip plugs more prone to detonation? [Re: mopar dave] #2375912
09/24/17 02:07 PM
09/24/17 02:07 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
I would dump the race plug and the 7173's are the projected tip 8's..........You will chase your damn tail if you you don't do it right the first time............ drumhit
Re: Projected tip plugs more prone to detonation? [Re: dthemi] #2375954
09/24/17 03:38 PM
09/24/17 03:38 PM
541 slobovia
A990 Offline
A990  Offline
541 slobovia
Originally Posted By dthemi
Just to interject something I know doesn't answer the question. The most detonation resistant plug I've seen with in car, and on dyno experience is an NGK 6061-10. That is against autolite AR series, and champions true race series plugs.
Can't copy the pic, but look at the electrode, and strap arrangement in the link.
http://static.summitracing.com/global/images/prod/large/NGK-5962_w.jpg
Does the non resistor part cause problems?
Re: Projected tip plugs more prone to detonation? [Re: A990] #2375962
09/24/17 03:56 PM
09/24/17 03:56 PM
Mt Morris Michigan
mopar dave Offline
mopar dave  Offline
Mt Morris Michigan
I use Ice ignition. They recommend a non resistor plug. resistors work find in it as well.
Page 4 of 4 1 2 3 4
