Page 2 of 4 1 2 3 4
Re: Projected tip plugs more prone to detonation? [Re: tex013] #2373105
09/19/17 02:03 AM
09/19/17 02:03 AM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Not about that, if your hard testing can reveal real world results of course in your racing atmosphere/conditions, then we all learn some cool stuff and can pass it on............. beer
Re: Projected tip plugs more prone to detonation? [Re: davenc] #2373415
09/19/17 05:14 PM
09/19/17 05:14 PM
Liverpool, NY
SILVER67 Offline
SILVER67  Offline
Liverpool, NY
Here's an NGK non projected -7 in a 505 with 11-1 on 93 pump gas
Re: Projected tip plugs more prone to detonation? [Re: davenc] #2373552
09/19/17 09:03 PM
09/19/17 09:03 PM
Pattison Texas
CSK Offline
CSK  Offline
Pattison Texas
here is my projected tip -5 ngk, has some carbon on it , but I would expect that, they have been in there since day one, 4000 miles, mostly street , seven 1/4 mile passes in the heat of summer & no detonation. like I said 512,9.5 comp , small solid.
Re: Projected tip plugs more prone to detonation? [Re: CSK] #2373572
09/19/17 09:44 PM
09/19/17 09:44 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
What's w/those ashy deposits.........
Re: Projected tip plugs more prone to detonation? [Re: Thumperdart] #2373578
09/19/17 09:57 PM
09/19/17 09:57 PM
Pattison Texas
CSK Offline
CSK  Offline
Pattison Texas
the camera made them look lighter, its black carbon build up,a lot of tuning & the AFR was rich at different times.
Re: Projected tip plugs more prone to detonation? [Re: davenc] #2373580
09/19/17 10:00 PM
09/19/17 10:00 PM
Pattison Texas
CSK Offline
CSK  Offline
Pattison Texas
I had a REAL hard time getting the transfer slots, cruise AFR to lean out, I should have asked you for help smile its all good now.
Re: Projected tip plugs more prone to detonation? [Re: CSK] #2373583
09/19/17 10:06 PM
09/19/17 10:06 PM
Rittman Ohio
fourgearsavoy Online tonguue
fourgearsavoy  Online Tonguue
Rittman Ohio
They developed that twin ground plug to combat misfires to save cat converters. I started seeing them in Tacoma pick-up trucks with the 3.4 engine. I am currently running Denso iridium plugs for a Toyota Tundra in my 10.9 compression 493 with Indy EZ heads and they run perfect all year long.
I have considered using the twin ground plugs but it runs so well with the iridium plugs why change shruggy
Gus beer
64 Plymouth Savoy
Dana 60
Re: Projected tip plugs more prone to detonation? [Re: fourgearsavoy] #2373632
09/19/17 11:13 PM
09/19/17 11:13 PM
NC, USA
davenc Offline OP
davenc  Offline OP
NC, USA
Gus beer
What type of plug did you run prior to the iridiums? Did you notice anything on the change?
Re: Projected tip plugs more prone to detonation? [Re: davenc] #2373643
09/19/17 11:27 PM
09/19/17 11:27 PM
Az
Crizila Offline
Crizila  Offline
Az
Originally Posted By davenc
Are projected tip plugs more prone to detonation, as compared to the equivalent non-projected tip plug?
All else being equal, Yes!
Fastest 300
Re: Projected tip plugs more prone to detonation? [Re: Crizila] #2373658
09/19/17 11:46 PM
09/19/17 11:46 PM
NC, USA
davenc Offline OP
davenc  Offline OP
NC, USA
OK, this is the first voice with a clear contrary position. Can you share your thoughts on this? Do you think the projected tip is hotter than a standard plug and can act like a hot spot (that was my original thought)?
Re: Projected tip plugs more prone to detonation? [Re: CSK] #2373666
09/19/17 11:58 PM
09/19/17 11:58 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
I'll say this, I do NOT shoot for lean cruise afr's cos we are not efi we have carbs and WET manifolds so richer mixture work/run way better for me and many others I build for. Now I don't mean cruising in the 11's or low 12's but cams w/duration and overlap need to be richer and if I want mileage, I cruise my Ranger.......... beer
Re: Projected tip plugs more prone to detonation? [Re: davenc] #2373685
09/20/17 12:27 AM
09/20/17 12:27 AM
Az
Crizila Offline
Crizila  Offline
Az
No matter what the heat range numbers say for a particular plug ( or comparing different brands of plugs), the farther the porcelain and tip is from the plug housing, the hotter it is going to run. The hotter it runs, the more prone to detonation it is going to be. Just because you can't hear it or see aluminum flecks on stuff, or melted ground straps, etc, doesn't mean your engine isn't running in some degree of detonation. Long before there were knock sensors on engines, I worked in a knock lab ( late 60's ) for a large oil company. An eye opener regarding engine detonation. I wouldn't be surprised if over half the build claims I see on this sight ( running outrageous CR's on pump gas )are running in some degree of detonation. It's just not enough to see / hear or to break stuff - but can be enough to negatively affect performance - and definitely enough to shorten engine life. Hence, knock sensors on all late model performance cars from the factory. KNOCK KNOCK, WHO'S THERE -----------. Hey Thumper, how's tricks? wave
Fastest 300
Re: Projected tip plugs more prone to detonation? [Re: Thumperdart] #2373699
09/20/17 12:56 AM
09/20/17 12:56 AM
Pattison Texas
CSK Offline
CSK  Offline
Pattison Texas
I understand all that, BUT my Charger is the only car I have to drive, so my AFR is on the edge of lean. smile
Re: Projected tip plugs more prone to detonation? [Re: Crizila] #2373707
09/20/17 01:05 AM
09/20/17 01:05 AM
I know of another guy in SO CA that worked in a knock lab also, he lead me to use the projected tip spark plugs in iron headed B and RB motors as well as all of the Mopar hemi motors for drag racing and street use work
Same information, different conclusions confused work
I had low compression(true 8.5 to 1) pump gas 350 Chevy boat motor that pinged, knocked, on regular pump gas with a Champion J12Y and quit knocking with a Champion J11Y work
I worked in service stations a long time ago before they became gas stations only and I have seen many stock motors that needed the spark plugs heat range changed for the driver work
Around town only grandma drive differently than there hot rodder grand kids did shruggy
Colder is always safer than a tiny bit to hot when it comes to gasoline and different driving conditions and fuel used work
Re: Projected tip plugs more prone to detonation? [Re: davenc] #2373820
09/20/17 11:13 AM
09/20/17 11:13 AM
Rittman Ohio
Rittman Ohio
Gus beer
Ran the iridium plugs since the first fire and never tried anything else shruggy I've been a tech for close to 35 years and I know how to read my plugs and they have a nice perfect burn on them and I have not heard any detonation even on 90* days with pump 93.
Gus beer
64 Plymouth Savoy
Dana 60
Re: Projected tip plugs more prone to detonation? [Re: fourgearsavoy] #2373829
09/20/17 11:33 AM
09/20/17 11:33 AM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
I ran Bosch platinums with good results years ago, but Chuck Senatore at Muscle Motors said he'd seen detonation problems when they were used with multi-strike ignitions. When I switched to a Crane HI-6, I stopped using them because of his comment.
FWIW, Autolite Racing series plugs have worked very well for me since then. Some are available w/ projected tips and all of them have the ground strap cut back to expose the electrode better.
Re: Projected tip plugs more prone to detonation? [Re: Crizila] #2373893
09/20/17 02:09 PM
09/20/17 02:09 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Who's tricks...........I missed something....... whistling
Re: Projected tip plugs more prone to detonation? [Re: davenc] #2374106
09/20/17 08:39 PM
09/20/17 08:39 PM
Macomb,IL
rdrnr33 Offline
rdrnr33  Offline
Macomb,IL
So because of this thread, I pulled the RN12Y plugs out of my 340 6 pack, and went back to the RN9Y. I could hear some detonation on light acceleration. I have been running octane booster. Plugs I took out have a red tint on them. Can anyone explain?
Re: Projected tip plugs more prone to detonation? [Re: davenc] #2374108
09/20/17 08:41 PM
09/20/17 08:41 PM
AndyF Offline
AndyF  Offline
Red tint is most likely from the octane booster.
Re: Projected tip plugs more prone to detonation? [Re: davenc] #2374116
09/20/17 08:50 PM
09/20/17 08:50 PM
Macomb,IL
rdrnr33 Offline
rdrnr33  Offline
Macomb,IL
So should I cut back on the octane booster or just see how the RN9Ys look after some road time?
Page 2 of 4 1 2 3 4
