Well Im starting off right! Broken Manley Head Bolt #237310
02/26/09 07:53 PM
02/26/09 07:53 PM
U.S.
moparniac Offline OP
U.S.
Thats right..... on the 3rd torque stage my new manley head bolt broke off on the #16 torque bolt sequence........ was torquing to 70lbs and SNAP.. the headbolt broke right in half...... whats the best way to get this thing out...... can you buy 1 manley head bolt?
the shorter one...... Im guessing since the threads didnt strip out maybe the bolt bottom out??? dont know..... didnt have a problem with my eddy heads...
yes the bolts were lubed up......
Indy EZ heads BTW...
Mopar Performance
Re: Well Im starting off right! Broken Manley Head Bolt [Re: moparniac] #237311
02/26/09 07:55 PM
02/26/09 07:55 PM
Q
Quicktree Offline
Quicktree  Offline
Q
you need to stay away from wrenches better have that torque wrench checked
Re: Well Im starting off right! Broken Manley Head Bolt [Re: moparniac] #237312
02/26/09 07:55 PM
02/26/09 07:55 PM
Alexandria, VA
SealockRacing Offline
Alexandria, VA
did it break off flush with the block? or is there some sticking out, if theres enough sticking out to grab with visegrips, just pull the head, and get it out, and replace?
if its flush, maybe try drilling it out? or using one of those ez outs or whatever.
John
Re: Well Im starting off right! Broken Manley Head Bolt [Re: SealockRacing] #237313
02/26/09 07:59 PM
02/26/09 07:59 PM
U.S.
U.S.
its about 3-4threads down from the top of the bolt where it snapped...... looks around flush with the block.....
its almost flat also where it snapped...
Mopar Performance
Re: Well Im starting off right! Broken Manley Head Bolt [Re: SealockRacing] #237314
02/26/09 07:59 PM
02/26/09 07:59 PM
long island NY
Ari440 Online content
Ari440  Online Content
long island NY
my block and heads where milled and on one bolt it didnt touch the head
now I use washers with the head bolts
1.39 9.85 - 137 mph
Re: Well Im starting off right! Broken Manley Head Bolt [Re: SealockRacing] #237315
02/26/09 08:03 PM
02/26/09 08:03 PM
cincinnati ohio
mcat4321 Offline
mcat4321  Offline
cincinnati ohio
i had the same issue with manely bolts last year. i went with studs . but take the head of and take it out . i dont think it can bottom out , so if it was lubed you should be able to get it out easily. i dont know if you did or not but i always chase every thread in a block , even if the machine shop does it or not...
Re: Well Im starting off right! Broken Manley Head Bolt *DELETED* [Re: moparniac] #237316
02/26/09 08:09 PM
02/26/09 08:09 PM
long time lurker, short time p...
P
PorkyPig Offline
PorkyPig  Offline
P
Toss the Manleys and buy some ARP stuff
Re: Well Im starting off right! Broken Manley Head Bolt [Re: PorkyPig] #237317
02/26/09 08:11 PM
02/26/09 08:11 PM
U.S.
U.S.
all threads were chased.
Mopar Performance
Re: Well Im starting off right! Broken Manley Head Bolt [Re: moparniac] #237318
02/26/09 08:27 PM
02/26/09 08:27 PM
U.S.
U.S.
whats the arp part number for indy heads??? thx
http://www.youtube.com/watch?v=RbDF9P1uDyk
Mopar Performance
Re: Well Im starting off right! Broken Manley Head Bolt [Re: moparniac] #237319
02/26/09 08:28 PM
02/26/09 08:28 PM
Canton, Ohio
Sport440 Offline
Sport440  Offline
Canton, Ohio
If the threads were chased and the bolt was lubed it should come out pretty easy. You may be able to tap the bolt out with a pointed chisel untill you can grab it with your fingers or a vice grip.
If not its easy out time.
Id replace ALL the bolts with Arps! Whats this about you wanting 1 Bolt. Replace them all, mike
Re: Well Im starting off right! Broken Manley Head Bolt [Re: Sport440] #237320
02/26/09 08:47 PM
02/26/09 08:47 PM
Johnstown, Ohio
fast383duster Offline
mopar addict
mopar addict
Johnstown, Ohio
Ryan Goodin S/Pro B386 High Speed Graphix T-shirts, Signs and More! www.highspeedgraphix.com
Re: Well Im starting off right! Broken Manley Head Bolt [Re: fast383duster] #237321
02/26/09 08:52 PM
02/26/09 08:52 PM
U.S.
U.S.
I take it this is the correct part#
Mopar Performance
Re: Well Im starting off right! Broken Manley Head Bolt [Re: moparniac] #237322
02/26/09 08:56 PM
02/26/09 08:56 PM
In the 8's
FY1TA Offline
FY1TA  Offline
In the 8's
I had a Manley break on mine while putting it back together right at 70 lbs . Took the head back off and screwed it out with my fingers . I bought a set of ARPS .
Re: Well Im starting off right! Broken Manley Head Bolt [Re: moparniac] #237323
02/26/09 09:06 PM
02/26/09 09:06 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Before you do any type of tool on it, use you finger
pushing on the end of the bolt while turning, I've
had alot come out easy after something went wrong.
Alot of times the snap shakes them free
Re: Well Im starting off right! Broken Manley Head Bolt [Re: moparniac] #237324
02/26/09 09:39 PM
02/26/09 09:39 PM
Canton, Ohio
Sport440 Offline
Sport440  Offline
Canton, Ohio
Wedge, I dont know the correct part number of the Arp bolts for your heads. I have it somewhere Im sure, but it maybe just as easy to call Arp.
If your heads use the Same Arp bolts as the Eddy RPM,s, and I think they might. The Eddy part# for the headbolts is #8591 Witch is actually the Arp bolts.
Oh, and like MrPBody said, Sometimes you can even just press your thumb or finger against the snapped off bolt and it may twist out. mike
Re: Well Im starting off right! Broken Manley Head Bolt [Re: moparniac] #237325
02/26/09 09:45 PM
02/26/09 09:45 PM
Syracuse,NY
CompWedgeEngines Offline
Syracuse,NY
If you cant get it out, dont drill it etc. Take a large nut ( 3/4") , center it over the broken bolt, and touch off the mig welder a few times inside the nut and weld the stud to the nut...it will come right out. Its better than taking the chance of getting drill filings in the motor.
RIP Monte Smith
Re: Well Im starting off right! Broken Manley Head Bolt [Re: fast383duster] #237326
02/26/09 10:55 PM
02/26/09 10:55 PM
the boonies
aarcuda Offline
aarcuda  Offline
the boonies
it should come out easy- if mr p bodys trick doesnt work (try that first) there should be no tension on the bolt unless it bottomed out
Re: Well Im starting off right! Broken Manley Head Bolt [Re: aarcuda] #237327
02/27/09 01:23 AM
02/27/09 01:23 AM
Polson, MT
DoctorDiff Offline
DoctorDiff  Offline
Polson, MT
If the bolt is broken flush and I can't spin it out with my finger or a pick, I sometimes slot the stub with a cut-off wheel and use a screw driver.
Re: Well Im starting off right! Broken Manley Head Bolt [Re: DoctorDiff] #237328
02/27/09 02:52 AM
02/27/09 02:52 AM
Salisbury North Carolina
8secDart Offline
8secDart  Offline
Manley head bolts go in dry.I bet it bottomed out or the lube increased the torque.
Re: Well Im starting off right! Broken Manley Head Bolt [Re: 8secDart] #237329
02/27/09 06:37 AM
02/27/09 06:37 AM
U.S.
U.S.
I still think it bottomed out..... however without removing the head I am gonna try a hex head wrench with some superglue and let it harden and see if I can back it out that way.....
summits site:
Manley offers these superior cylinder head bolt kits for a variety of applications. They are longer than stock for use with washers, heat treated for added strength, and their 1/2 in. hex head improves wrenchability.
Mopar Performance
