Well Im starting off right! Broken Manley Head Bolt
#237310
02/26/09 07:53 PM
02/26/09 07:53 PM
Posts: 6,295 U.S.
moparniac
U.S.
Thats right..... on the 3rd torque stage my new manley head bolt broke off on the #16 torque bolt sequence........ was torquing to 70lbs and SNAP.. the headbolt broke right in half...... whats the best way to get this thing out...... can you buy 1 manley head bolt? the shorter one...... Im guessing since the threads didnt strip out maybe the bolt bottom out??? dont know..... didnt have a problem with my eddy heads... yes the bolts were lubed up...... Indy EZ heads BTW...
Mopar Performance
Re: Well Im starting off right! Broken Manley Head Bolt
[Re: SealockRacing]
#237313
02/26/09 07:59 PM
02/26/09 07:59 PM
Posts: 6,295 U.S.
moparniac
U.S.
its about 3-4threads down from the top of the bolt where it snapped...... looks around flush with the block..... its almost flat also where it snapped...
Mopar Performance
[Re: SealockRacing]
#237314
02/26/09 07:59 PM
02/26/09 07:59 PM
Posts: 5,618 long island NY
Ari440
long island NY
my block and heads where milled and on one bolt it didnt touch the head
now I use washers with the head bolts
1.39 9.85 - 137 mph
[Re: moparniac]
#237319
02/26/09 08:28 PM
02/26/09 08:28 PM
Posts: 6,591 Canton, Ohio
Sport440
Canton, Ohio
If the threads were chased and the bolt was lubed it should come out pretty easy. You may be able to tap the bolt out with a pointed chisel untill you can grab it with your fingers or a vice grip. If not its easy out time. Id replace ALL the bolts with Arps! Whats this about you wanting 1 Bolt. Replace them all, mike
[Re: Sport440]
#237320
02/26/09 08:47 PM
02/26/09 08:47 PM
Posts: 690 Johnstown, Ohio
fast383duster
mopar addict
mopar addict
Johnstown, Ohio
[Re: moparniac]
#237323
02/26/09 09:06 PM
02/26/09 09:06 PM
Posts: 52,972 Romeo MI
MR_P_BODY
Before you do any type of tool on it, use you finger pushing on the end of the bolt while turning, I've had alot come out easy after something went wrong. Alot of times the snap shakes them free
[Re: moparniac]
#237324
02/26/09 09:39 PM
02/26/09 09:39 PM
Sport440
Canton, Ohio
Wedge, I dont know the correct part number of the Arp bolts for your heads. I have it somewhere Im sure, but it maybe just as easy to call Arp. If your heads use the Same Arp bolts as the Eddy RPM,s, and I think they might. The Eddy part# for the headbolts is #8591 Witch is actually the Arp bolts. Oh, and like MrPBody said, Sometimes you can even just press your thumb or finger against the snapped off bolt and it may twist out. mike
[Re: moparniac]
#237325
02/26/09 09:45 PM
02/26/09 09:45 PM
Posts: 3,544 Syracuse,NY
CompWedgeEngines
Syracuse,NY
If you cant get it out, dont drill it etc. Take a large nut ( 3/4") , center it over the broken bolt, and touch off the mig welder a few times inside the nut and weld the stud to the nut...it will come right out. Its better than taking the chance of getting drill filings in the motor.
RIP Monte Smith
[Re: fast383duster]
#237326
02/26/09 10:55 PM
02/26/09 10:55 PM
Posts: 15,478 the boonies
aarcuda
the boonies
it should come out easy- if mr p bodys trick doesnt work (try that first) there should be no tension on the bolt unless it bottomed out
[Re: 8secDart]
#237329
02/27/09 06:37 AM
02/27/09 06:37 AM
Posts: 6,295 U.S.
moparniac
U.S.
I still think it bottomed out..... however without removing the head I am gonna try a hex head wrench with some superglue and let it harden and see if I can back it out that way.....
summits site: Manley offers these superior cylinder head bolt kits for a variety of applications. They are longer than stock for use with washers, heat treated for added strength, and their 1/2 in. hex head improves wrenchability.
Mopar Performance
