Page 2 of 9 1 2 3 4 5 6 7 8 9
Re: Project VIP to drag week 2017 [Re: jyrki] #2228625
01/06/17 02:58 PM
01/06/17 02:58 PM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
Yep, following!
Rich H.
Esse Quam Videri
Re: Project VIP to drag week 2017 [Re: jyrki] #2228628
01/06/17 03:01 PM
01/06/17 03:01 PM
Tulsa, Oklahoma
340Cuda Offline
340Cuda  Offline
Tulsa, Oklahoma
When you say you have been accepted do you mean subject to inspection at the track technically? As you know registration is still months off.
Good luck with the project!
Bill
Re: Project VIP to drag week 2017 [Re: jyrki] #2228637
01/06/17 03:08 PM
01/06/17 03:08 PM
AB
E
Efidart Offline
Efidart  Offline
E
AB
Looks like it should work good! Glad to see another Mopar making the trek not just talking about it and never following through.
Need another point of compression in that thing wink leaving a bit on the table.
T&D will come around, they do good work and the rockers last. See if you can get the spring oiler upgrade (They make a tiny hole that sprays out of the rocker directly onto the spring) helps springs stay nice and cool.
Are you going to switch to a 3.50 gear or similar? 4.10 seems a little steep even with a 33" tall tire.
Changing Tires sucks.. avoid it if you can. ET Street R or a Hoosier Quick Time Pro is your friend..
Organize all your parts into tubs and label.
Round up the oil you would like to run before drag week, chances are there will not be any nearby.
Modifying for lifter oiling is the ticket! My rockers barely moved the whole week with Isky EZ-Roll X's and pushrod oiling.
Last but not least-
Bring earplugs!!!
TT Predator headed 572 7 Second Street Car.
Fastest Mopar Drag Week 2015
Fastest Mopar & Dodge Drag Week 2017
Pro Street Power Adder Champion Drag Week 2017
Re: Project VIP to drag week 2017 [Re: jyrki] #2228640
01/06/17 03:11 PM
01/06/17 03:11 PM
Iowa
burdar Offline
Owen's Dad
burdar  Offline
Owen's Dad
Iowa
The cars that are shipped over for Drag Week...I assume they need to be registered/licensed/tagged to be legal to drive on the highway? How is that done? Or do you just drive it and hope you don't run into any issues with highway patrol? Just curious.
Re: Project VIP to drag week 2017 [Re: jyrki] #2228650
01/06/17 03:23 PM
01/06/17 03:23 PM
Texas
mprhound Offline
mprhound  Offline
Texas
jyrki
have run the fbs heads on the street before? just wondering if there are any heating issues with them. I can't wait to get my fbs headed motor going, my block was just shipped to indy to get repaired.
Re: Project VIP to drag week 2017 [Re: jyrki] #2228673
01/06/17 04:11 PM
01/06/17 04:11 PM
Milwaukee WI
TRENDZ Offline
TRENDZ  Offline
Milwaukee WI
Without a larger picture, it's hard to tell, but how is the water routed? Are there hose outlets on the heads?
From what I see in the picture,(not enough) it LOOKS like the plan is, "in" one side, and "out" the other side. If that's the case, It needs to be reworked. The cooling system in a STANDARD configuration is actually two separate "compartments". What goes in one side will not come out of the other side.
I know nothing about your car is "standard", so if I'm off base ...
Re: Project VIP to drag week 2017 [Re: jyrki] #2228689
01/06/17 04:27 PM
01/06/17 04:27 PM
Milwaukee WI
TRENDZ Offline
TRENDZ  Offline
Milwaukee WI
Sorry, I see what's going on there. Upper/upper, lower/lower. Just an odd view.
Re: Project VIP to drag week 2017 [Re: TRENDZ] #2228690
01/06/17 04:29 PM
01/06/17 04:29 PM
Hot Rod Ridge
FastmOp Online tonguue
FastmOp  Online Tonguue
Hot Rod Ridge
Looks like an easy way to reverse cool.
Re: Project VIP to drag week 2017 [Re: jyrki] #2228923
01/06/17 10:13 PM
01/06/17 10:13 PM
Akron, Ohio
ProSport Offline
ProSport  Offline
Akron, Ohio
Very cool, I'll be watching.
Re: Project VIP to drag week 2017 [Re: jyrki] #2228992
01/06/17 11:42 PM
01/06/17 11:42 PM
Minnesota
Hemi_Joel Offline
Hemi_Joel  Offline
Minnesota
You will need to have the cage certified by NHRA. Do they do that in Europe? If not you will have to allow time and make arrangements to have it done when you get here and allow time for possible changes if required.
RS23J71
RS27J77
RP23J71
RO23J71
WM21J8A
Re: Project VIP to drag week 2017 [Re: jyrki] #2229029
01/07/17 12:19 AM
01/07/17 12:19 AM
Topeka Kansas
K
ksj Offline
ksj  Offline
K
Topeka Kansas
Good advice Joel.And make sure your helmet is up to date.
Re: Project VIP to drag week 2017 [Re: jyrki] #2229161
01/07/17 04:12 AM
01/07/17 04:12 AM
Finalnd, Perkele
jyrki Offline OP
jyrki  Offline OP
Finalnd, Perkele
We have NHRA rules here as far as the major safety specs go, and the cage is 25.5 sertified. So. in theory 7.5 sec is possible. The helmets are Snell SA 2010, we have the HANS etc. But have to verify the chassis cert that it covers USA.
Plynouth VIP '67 TT IC EFI
Re: Project VIP to drag week 2017 [Re: jyrki] #2237855
01/20/17 01:42 PM
01/20/17 01:42 PM
Finalnd, Perkele
jyrki Offline OP
jyrki  Offline OP
Finalnd, Perkele
A small update. We have now installed the door glass and the windows are working, the fuel system has been trial fitted and the car is now being prepped for paint. That will take awhile. the new Indy block was taken in to a machine shop for drilling the oil channels for the lifters. However, it was slightly screwed up..., the drill bit ended up to the cam tunnel on the drivers side in the two last lifter holes. Just have to block the channel before them and propably have them oiled with a tube from the other side. On monday the block will go into a machine shop for final honing, and then a week after that in to another for sleeving the lifter holes. Once that is done we should be able to start putting the engine together. That is, if the lifters and rockers arrive...
Since not much happening at the moment I'll put here the story of the car for those that like to read to the point I have written it... it's also in the facebook but buries there under all stuff.
VIP story #1
Since the story of the “hero” is propably unknown to at least our international friends, here is the first part of the story:
It’s year 1967. Finland, one of only two countries in Europe taking part in WW2 while retaining unoccupied, is still mentally and financially recovering from the sufferings of the lost war against Soviet Union.
It’s been five years since the rationing of importing western cars ended. Majority of the cars around are still manufactured by our eastern friends, the western cars are mainly practical, cheap and small.
The small amount imported from the United States goes mainly to companies for their representative purposes. Most of them are black four door sedans with pretty basic equipment, six and three on the tree is the norm.
Within the few exceptions among the Plymouth – Chrysler cars imported by Berner OY, in the addition to the only known four door Hemi Plymouth made , is also the storys top of the line, blue Plymouth VIP. Originally equipped with a 318 engine, column shift automatic, manual steering and power disc brakes. Only less than 8000 coupes were built and today it’s relatively rare, the car of the story is most likely the only one in this use!
Years pass, the youth of the car is pretty much unknown, but during that period for example Finnish Hot rod Association is established in 1972. Come the oil crises, and the value of US gas guzzlers collapse, suddenly they become available for the youth just starting their drivers career, and they become one sign of the rebel against Finlandizing of the official Finland.
Plymouth VIP is still an expensive car, but despite of that it soon becomes a hobby car. One day it shows up with a red flake paint and a painted “vinyl roof”, ever changing.The last version before the hiatus is presented in the Finnish USA car magazine, the V8 Magazine, in 1987.
At that point the car is dark blue, Nascar steelies, and wide tires all around. The original 318 engine has been hopped up with two turbochargers blowing through two side draft Dell’orto carbs adapted to a four barrel intake. Soon after that, a massive engine failure, and the car is pushed on the back burner and soon forgotten…
Part#2
…At the same time Jyrki Aukio who had always had US cars in his family, is starting his street race career, racing officially for the first time in 1988 with a 1973 Valiant four door 360 running a 14.57/99 mph.
In the property where Jyrki gets to work on his car, is also working a guy named Jussi Lahti. Jyrkis working at the car raises Jussis interest, and he also decides to start building a street racer.
The next decade is pretty much spent on building Darts and Valiants and they gain name both in official and unofficial street races with their A-body Mopars. However working day in and out for a decade with the same vehicles takes its toll, and a need arises doing something different.
During their trips they begin to speculate with the idea of building together a full size street car that would run mid 9’s like their pump gas engine, naturally aspirated A-bodies did at the time. The key, they agree, to achieve that and still retain street able would be turbocharging.
In 2004 Jyrki gets a call from Jussi; “Just bought a new car, a ’67 Plymouth VIP roller”. Jyrki thinks for a few minutes, takes another call and then returns to Jussi; “I bought turbos for it”.
They had no rush with the project, both still continued racing with their own vehicles until the VIP was moved in to the garage in the fall of 2005 and the fly cutter started to sing…
A lot of parts had already been gathered for the project, and the progress was rapid. The rear frame was replaced with Quarter Max parts, four link with coil overs. The car was built with an intention that it would full fill the FHRA Street D rules of the time, while still being able to be registered it and have it inspected as street legal.
The car was externally ready by 2006 FHRA American Car Show where it was introduced. However, the drivetrain was still in parts since the engine parts ordered hadn’t arrived.
http://kuvia.1g.fi/kuvat/Tapahtumat+2006/ACS-2006/Acs-06-164.jpg
And then the waiting begun…, the summer was already in the midpoint when a decision was made that for the 2006 season they would forget the turbochargers for now.
Instead, the engine was put together naturally aspirated with a carburetor. The rest of the season was raced with that combination, and surprisingly well it run; The heavy car with a low stall converter and too long gear ratio for the naturally aspirated engine run a best of 10.6 sec at 129mph.
Part #3
Even though the car run pretty well for its size naturally aspirated, we were left with mixed feelings. Compared to the earlier leaf spring cars that had to be steered through the quarter mile, the two speed four link car was boring to drive. The car run straight like a train and the only thing to do during the run was to wait the rpm gauge needle reach such figures that it was appropriate to push in the second gear.
Year 2007 started like the year before; waiting for the parts to arrive. The short stroke crank proved out to be the most challenging item. Finally after the season had already begun, the parts arrived. We rushed to get it together and the first race we attended was our annual European Championship race in July.
We arrived to the pits late, and the car had not run once. Saku Ritola from R-Motorsport helped us to get the car started with the EFI and when it did, we immediately drove it to tech, passed it, and straight to the line up for the last qualification round.
http://kuvia.1g.fi/kuvat/Tapahtumat+2007/FHRA/NitroNationals5-8.7_07/Pit/5-8.7_07-081.jpg
I instructed Jussi just to run through, and for a moment floor it to get some data to the ECU. Jussi did just that and the first run with the turbos was 12.6 seconds at 86 mph. At the pits we noticed that the data logging feature of the ECU hadn’t been turned on, still Jussi reported that for the brief period he pushed it, the car pulled pretty well.
We qualified last in the eliminator, and were to meet Olli Rämä in Jussis old Valiant, low 10 second car with its new drivetrain, in the first round, and get another chance.
Next morning in the eliminations the strategy was the same, just to get some data about the engine functions. The data logger was on, burnout went fine, staging and launch. Jussi didn’t rush, got worse reactions and was immediately left behind, then after a while floored it. Since everything seemed to work fine he stayed on it and almost caught Olli in the finish line running a better ET and loosing with a hole shot. However, everything worked and the tune up was safe according to the log, and the first 9 second Et was reality; 9.97/137 mph!
http://kuvia.1g.fi/kuvat/Tapahtumat+2008/FHRA/DefaFinals29-31.8.2008/Defa29_31_08_7.jpg
In the next race we continued with the same tune up, running better than in our A-bodies, 9.37/148 mph, and in the next one 9.27/149.
https://www.youtube.com/watch?v=Gqo3YcoO35Q
With only our national finals left, we decided to install second springs in to the waste gates and see what happens with a bit more boost. I was in the line up running another car, so didn’t see how it went, thought I heard something but didn’t believe my ears.
However, it turned out to be true, the car responded well raising the boost and run 8.55/159 mph! As the race continued, the ET dropped in to 8.44/162 mph! The performance had more than met our hopes and even though we were glad about that, breaking the 8.50 second barrier caused some new challenges.
http://kuvia.1g.fi/kuvat/Tapahtumat+2007/FHRA/DefaWinterFinals31.8-2.9/Race/31.8-2.9_07-605.jpg
So, we were at a point where we had to ditch the basically one year old roll cage and start prepping the car for SFI 25.5 spec that at the time was the quickest unibody spec, at least in Finland.
It was evident that the new cage had to be built out of cro mo since the car according to the SFI 25.5 spec must weigh under 3600 lbs. During the next winter we first stripped the car, then Jaffu Holms Island Race Cars welded the cage together, and we did the rest of the job. At the same time all the glass except the windshield was converted to Lexan, the doors were made out of fiberglass, and we met the SFI specs!
Next summer 2008 we continued from where we have left, won the first races with the car and made a national street car record of 8.13/170 mph, guess it's the only C-body ever done that!
http://kuvia.1g.fi/kuvat/Tapahtumat+2008/FHRA/DefaFinals29-31.8.2008/Defa29_31_08_394.jpg
To be continued….
Re: Project VIP to drag week 2017 [Re: jyrki] #2282951
04/05/17 05:58 PM
04/05/17 05:58 PM
Finalnd, Perkele
jyrki Offline OP
jyrki  Offline OP
Finalnd, Perkele
It's been a while...., a lot of dealys but we are getting there.
Hot Rod noticed us too. http://www.hotrod.com/articles/vip-flying-finns/
Re: Project VIP to drag week 2017 [Re: jyrki] #2282970
04/05/17 06:37 PM
04/05/17 06:37 PM
IL
Dart451 Offline
Dart451  Offline
IL
Love the big cars! We entered dragweek also, looking forward to seeing your car.
We live about a hour from cordova so if you need anything let me know.
Re: Project VIP to drag week 2017 [Re: jyrki] #2283654
04/06/17 11:27 PM
04/06/17 11:27 PM
Morrow, OH
markz528 Offline
markz528  Offline
Morrow, OH
Originally Posted By jyrki
We run the car until I crashed it in the street in 2014,
I didn't know you crashed it! However, I vaguely remember you driving that thing around your shop yard in the snow when I visited. Were you driving that thing around in the snow????? LOL!
Good luck with it! I love the car and your talent..........
Re: Project VIP to drag week 2017 [Re: jyrki] #2324552
06/21/17 06:26 AM
06/21/17 06:26 AM
Finalnd, Perkele
jyrki Offline OP
jyrki  Offline OP
Finalnd, Perkele
https://www.youtube.com/watch?v=aAT1V-wKnKs
Long time without updates...
So far about everything that can go wrong has.
We got the engine to dyno in the begining of May. Got the street tune up done but run in to problems with power pulls. Only got 1250 hp at 13 psi until decided that the engine doesn't work. Some valves were leaking, the head gaskets leaked, one lifter bushing broke...
Got those fixed and put it together with new rings and bearings, but a new dyno didn't fit in to schedule. A day before the first test day we found out that the Ford Motorsport brakes didn't fit with the billet specialties wheels..., so had to build new brakes out of a checy set we luckily had.
The first tests were the first time the driver drove the car. Got three runs done without boost control, the best was 9.90 at 140 mph, and again small technical problems.
Got them fixed again and a new test at a local airport. Made four runs and played with the hboost control a little..., now the engine seems to work mechanically but with no traction at the airport high 10's were the best.
Now I'm building a new oil pan out of aluminum because the zillion time modified original steel tends to create a new leak every time out. There is still a lot to do in the car, and we only have one chance to test it before shipping. Hopefully we get everything done so that we can get some kind of a handle about how things work.
The last time the engine was apart I decided to detune it quite a lot, swapping the cam to a regular comp cams XE street roller. At this point it isn't so important what the thing is capable of running, more important is to get it more reliable, and the cam with way smaller spring pressures should definitely help.
Here is a small video from last weekend: https://www.youtube.com/watch?v=xulWJKff2-g
Re: Project VIP to drag week 2017 [Re: jyrki] #2324715
06/21/17 02:06 PM
06/21/17 02:06 PM
MN
JERICOGTX Offline
JERICOGTX  Offline
MN
Been following on FB. Hope things work out and you can make it. How soon does it have to ship to be here on time?
69 GTX 68 Road Runner
Re: Project VIP to drag week 2017 [Re: jyrki] #2324867
06/21/17 07:19 PM
06/21/17 07:19 PM
Finalnd, Perkele
jyrki Offline OP
jyrki  Offline OP
Finalnd, Perkele
Early July, there has been some problems with shipping and customs recently, so we have to leave some extra for it.
Re: Project VIP to drag week 2017 [Re: jyrki] #2324934
06/21/17 09:56 PM
06/21/17 09:56 PM
Manitoba Canada
67autocross Offline
67autocross  Offline
Manitoba Canada
Looking forward to seeing you at Drag Week! Can you link your Facebook page??
A new iron curtain drawn across the 49th parallel
