Re: Old stinky bad gas - help me get it out of the tank
[Re: calmopar]
#2369476
09/12/17 03:04 PM
09/12/17 03:04 PM
Posts: 12,830 East Bay, N. Cal.
calmopar
East Bay, N. Cal.
Ya know...even if I decide for whatever reason not to go the route that Scott proposed, isn't it a good things for Moparts that he explained the right way to do this? I think so and I'm glad he offered up that advice.
Trying to enjoy life!
[Re: calmopar]
#2369486
09/12/17 03:17 PM
09/12/17 03:17 PM
Porter67
Id say yes and no, your lack of info posted...
What's going to work? How about taking a high-flow electric fuel pump, plumbing it in before the gas filter, and having it dump through a tube into a bucket? how fast would that go? What would you do? I have to get some bad gas out of three cars - stat.
You never stated if they were old pos cars you just need to move, drive on a trailer, just see if they ran, good cars that your foolish self let get gummed up....
If the cars a $300 parts car or a 2k beater is the right way to spend XXXX amount of money. When a repop tank is $80 shipped?
As well alot of repop tanks off ebay... like this repop tank $79 shipped for a 70 duster, so is the right way still to take out the old oem one, pay to ship it to be cleaned, boiled, sealed?
Its all about perspective, the right way or the right way for the situation.
http://www.ebay.com/itm/1970-1971-Dodge-Dart-Plymouth-Duster-Valiant-Scamp-Fuel-Gas-Tank-CR11D-/310708584961?fits=Year%3A1970%7CModel%3ADuster&epid=664196925&hash=item4857acc201:g:8WMAAOSwyZ5Uqxjh&vxp=mtr
Does your car need a cleaned, boiled, sealed tank at XXXX expense or would a $80 repop fit your needs?
[Re: calmopar]
#2369628
09/12/17 07:13 PM
09/12/17 07:13 PM
calmopar
East Bay, N. Cal.
I just want to start them so I can move them a few yards over inhospitable ground right now, that's all.
[Re: calmopar]
#2369670
09/12/17 08:19 PM
09/12/17 08:19 PM
calmopar
East Bay, N. Cal.
Hmm....I'll try that on the last car if it won't fire up. The previous one fired up just fine and then... (I'm asking on General to figure out where the problem might be)
[Re: 1971 Gran Coupe]
#2369742
09/12/17 10:15 PM
09/12/17 10:15 PM
calmopar
East Bay, N. Cal.
I just want to start them so I can move them a few yards over inhospitable ground right now, that's all. If that is all you want, use a tow strap and pull them that far. Or use a winch if you have one, or even a cable come along. I have a 4x4 truck and a tow strap but am not sure where to attach to the mopar to avoid damage.
[Re: calmopar]
#2369760
09/12/17 10:32 PM
09/12/17 10:32 PM
Posts: 2,414 St. Croix, US Virgin Islands
David_in_St_Croi
We have a 63 MG Midget. It sits up in Babylon for our yearly visit from the islands. Once it sat for at least 2 years, maybe 3. We charged the battery, turned the key, waited for the SU's to prime, pulled the starter switch and off it went. Then smelled petrol and shut her off. Discovered the flexible (made in USA) fuel lines had turned into sprinklers. Changed the hose, fired it back up again and went on our way. Never smelled the gas in the tank directly so did no worry about it. So much for modern gas being the devil's best friend. Even if ethanol is in the gas, how bad can it be. We make our coffee with the stuff down here.
Seriously, dilution is probably best for the OP's situation, or as stated, a tow rope. If the tank is really bad, just replace it.
[Re: calmopar]
#2369807
09/12/17 11:33 PM
09/12/17 11:33 PM
Posts: 9,550 Sacramento CA
Morty426
Sacramento CA
I just want to start them so I can move them a few yards over inhospitable ground right now, that's all. I'm flying into SFO Thursday around noon. If you want I can text you when I land and come over and help you push these things around. Way easier than trying to start them all. Then we can talk about hauling the yellow one away
