Re: OK! No more BS. Time to start working.
[Re: sgcuda]
#2382316
10/05/17 10:12 AM
10/05/17 10:12 AM
Posts: 13,360 Marion, South Carolina [><]
an8sec70cuda
Did you have them flycut yourself?
[Re: sgcuda]
#2382546
10/05/17 05:33 PM
10/05/17 05:33 PM
Posts: 4,243 Charlotte, North Carolina
sgcuda
I had them done with the rest of the engine work. All of the engine work was done at the same time. Check heads, block work up, clearance for stroker, replace cam bearings, line hone for new caps, clearance for valves, balance bottom end. They had all engine parts for mock up.
[image][/image]
[Re: sgcuda]
#2423069
12/24/17 01:31 PM
12/24/17 01:31 PM
sgcuda
OK. So this year. I got the 500 fired up, after many setbacks. Found some issues, but got tired of it. After brainstorming with a close friend, it was decided that as long as I own this motor, it would be possessed by the spirit of Chuckie. So, I sold the motor, and am now embarking on bigger and better. Looking at what kind of B1 heads to buy. Really have my eyes on a set of B1MC's. but still checking to see if they are really MC's. Also have a set of PSO's in sight, but have a lot of port and epoxy work, which has never really thrilled me as far as long term use. Aiming at putting together a 572, maybe bigger, not sure yet. Taking a break, cleaning up the garage, enjoying the holidays. Will start fresh with the New Year and maybe get this old girl to the track. Long overdue. Merry Christmas everyone.
[Re: Jeremiah]
#2423291
12/24/17 09:33 PM
12/24/17 09:33 PM
sgcuda
Kenny that is a bad deal on the pistons. I'm glad you are moving on to bigger and more bada$$ pastures.
On the pistons being fly-cut - Was this to solve a PtV clearance issue? If so, can we re-hash what the rod/stroke combo was along with the cam specs? I'm getting into a similar scenario and was wondering if losing some quench/squishy was beneficial in lieu of cutting on the pistons (or changing to a dished piston).
My 511 low deck was really close on the PtV (.080 Ex, .100 In) and luckily only .020 had to be removed from the valve face. That was with a cam that checks out at less than .750 at the spring retainer.
Merry CHristmas to you too buddy! With the "QUALITY" work done to my engine, I'm thinking that nobody checked for sure and plunge cut the pistons, just to be on the safe side. When I saw pics of original pistons on 440source site, they took a ton of material out of the valve relief pockets on the intake side of my pistons. I'm sure they would have been safe with half the cut they took, that is, if they needed to be cut at all. .100" clearance on the intake is plenty safe IMO. My combo was a 4.15" crank, 6.76" rod, 4.380" flat top piston, -0.005" deck height. I was using -1 heads, heavy milled to 60cc chambers, .040" copper head gaskets. .765"/.714" cam lift with 1.7 rockers, 269/276 @ .050" duration. And a Merry Christmas to you.
[Re: sgcuda]
#2423381
12/25/17 01:11 AM
12/25/17 01:11 AM
Posts: 43,157 Bend,OR USA
Cab_Burge
Solid roller cam with decent spring pressures, 250+ lbs. on the seat and 600 + Lbs. opened on a mild lobe, I shoot for .060 at the closest on the intakes and .080 on the exhaust I've ran them with more than that clearances with no visible closeness on the piston top carbon at or under 7500 RPM, less than .050 I see near witness marks on the carbon This is on a automatic car, not a stick shift motor
[Re: sgcuda]
#2430157
01/06/18 08:31 PM
01/06/18 08:31 PM
sgcuda
Ok. New build time. Intake on its way. Crank and rods in the works. Heads going for inspection and touch up. Engine block is hurt. Will be looking for ideas on repairs in the near future.
[Re: sgcuda]
#2430500
01/07/18 02:28 PM
01/07/18 02:28 PM
Posts: 1,505 TN
SCATPACK 1
TN
Well, it didn't start out in the piston. Must have been sitting on the crank scarper and windage tray areas. Got pulled up through the cam area when I pulled the crank around. Not sure if I want to reuse the oil pan. Rust from chipmunk urine, I guess. Internals look good so far.
2 squirrels climb into a wedge block for a beer...
Just read your post and hate to see this set back. (Should put a squirrel powered decal on scoop). But how did the squirrel get in the oil pan? Was the timing cover off or something else left off for a while? That looks like it has been there for a while with the rust on the pan. Hope you get it going soon.
Old Geezer Racing
[Re: SCATPACK 1]
#2430621
01/07/18 06:02 PM
01/07/18 06:02 PM
sgcuda
Just read your post and hate to see this set back. (Should put a squirrel powered decal on scoop). But how did the squirrel get in the oil pan? Was the timing cover off or something else left off for a while? That looks like it has been there for a while with the rust on the pan. Hope you get it going soon. [/quote] I had the intake off, and 2 cloth type fender covers over the valley. They ate through them and used the material for a nest. Since there weren't any lifters in it yet, I guess they did their thing and shimmied down around the camshaft and into the bottom end. My Milodon pan has a solid windage tray on it which became their bedroom floor. I pulled enough stuffing out to fill a bed pillow. A lot was behind #4 piston, rest in the pan. The first one chugs a beer and says....
[Re: sgcuda]
#2457745
02/26/18 04:28 AM
02/26/18 04:28 AM
Posts: 19,317 State of confusion
Thumperdart
State of confusion
I like that spoiler a lot............
