Rod side clearance #236761
02/26/09 12:10 PM
02/26/09 12:10 PM
Fl. USA
PS Arrow Offline OP
PS Arrow  Offline OP
Fl. USA
Can ya tell someones doing assembly???
What is acceptable rod side clearance, using Eagle Rods?
Thanks in advance!!!
John
Re: Rod side clearance [Re: PS Arrow] #236762
02/26/09 12:21 PM
02/26/09 12:21 PM
John
I use .012 or larger, looser is better than to tight
Re: Rod side clearance [Re: Cab_Burge] #236763
02/26/09 12:25 PM
02/26/09 12:25 PM
Fl. USA
PS Arrow Offline OP
PS Arrow  Offline OP
Fl. USA
Thanks Cab, what would be considered too much?
Re: Rod side clearance [Re: PS Arrow] #236764
02/26/09 12:51 PM
02/26/09 12:51 PM
WOW! I would think that .012 is on the tight side I was thinking like 020 would be on the tight side. I wrote mine down when I did the motor 4 years ago I will have to check!
Re: Rod side clearance #236765
02/26/09 12:59 PM
02/26/09 12:59 PM
Fl. USA
PS Arrow Offline OP
PS Arrow  Offline OP
Fl. USA
Please update if you find out , thanks Mike!!!
Re: Rod side clearance [Re: PS Arrow] #236766
02/26/09 12:59 PM
02/26/09 12:59 PM
My street motor(518 C.I.) has a set of CAT H beam BB Chevy rods that have .052 on one journal and the tightest is around .030 I think that the Mopar factory service manuals call fro .008 to .020 on most of thier motors, I have never seen one that was close to .020 before tear down from the factory, all of them are wider than .020 I have seen a lot of discussion on this forum on rod side clearances about having to much causing high oil consumption due to flooding the cylinder walls at high RPM, I have always thought that the rod bearing clearances are more important than the side clearances when it comes to oil control on the cylinder walls
Re: Rod side clearance [Re: Cab_Burge] #236767
02/26/09 01:02 PM
02/26/09 01:02 PM
Fl. USA
PS Arrow Offline OP
PS Arrow  Offline OP
Fl. USA
OK cool...Whew...I was measuring .030 and wasnt sure if I had a problem or not. Thanks a bunch!!!
Re: Rod side clearance [Re: PS Arrow] #236768
02/26/09 01:09 PM
02/26/09 01:09 PM
sorry had to run out to the garage the tightest I had was .036 on the loose side was .049
Mike
Re: Rod side clearance [Re: PS Arrow] #236769
02/26/09 01:24 PM
02/26/09 01:24 PM
the boonies
aarcuda Offline
aarcuda  Offline
the boonies
scared me too. i had something like .026-.030 and I was
but sure enough, thats ok. I even read in my engine manual or my rebuild book a warning about excessive oil loss if they were looser than .020. but its not a real worry says the internet
Re: Rod side clearance [Re: aarcuda] #236770
02/26/09 02:26 PM
02/26/09 02:26 PM
Fl. USA
PS Arrow Offline OP
PS Arrow  Offline OP
Fl. USA
Thanks All!!!
Re: Rod side clearance [Re: PS Arrow] #236771
02/26/09 02:32 PM
02/26/09 02:32 PM
Marysville, O-H-I-O
70Cuda383 Offline
70Cuda383  Offline
Marysville, O-H-I-O
I think my 440 source rods were around .017-.019 ..but I didn't write it down, I just checked it to make sure it wasn't too tight, saw they were all ok, and continued putting it together.
**Photobucket sucks**
Re: Rod side clearance [Re: 70Cuda383] #236772
02/26/09 02:49 PM
02/26/09 02:49 PM
Rock Springs
Bob_Coomer Offline
Bob_Coomer  Offline
Rock Springs
Don'T worry if it ends up being even .050+ wont hurt a thing. Back before the days of all these stroker cranks etc, you would run into this often with a crank and Chevy rods, never had one single problem IIRC I ran a engine around .070 or so. I know its not prefer ed, but didn't hurt a thing.
Re: Rod side clearance [Re: Bob_Coomer] #236773
02/26/09 04:13 PM
02/26/09 04:13 PM
Eighty Four, PA
B G Racing Offline
B G Racing  Offline
Eighty Four, PA
.018 to .024 ideally
Re: Rod side clearance [Re: B G Racing] #236774
02/26/09 06:01 PM
02/26/09 06:01 PM
Oregon,USA
RAT PATROL Offline
RAT PATROL  Offline
Oregon,USA
Mine is .035, Ideally it would have a lightweight billet in it instead.
Re: Rod side clearance [Re: PS Arrow] #236775
02/26/09 06:16 PM
02/26/09 06:16 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
My old school chevy rods are bet .035-.050 so who knows. I`ve personally seen motors fail with around .009.
Re: Rod side clearance [Re: Thumperdart] #236776
02/26/09 07:30 PM
02/26/09 07:30 PM
Eighty Four, PA
B G Racing Offline
B G Racing  Offline
Eighty Four, PA
Better loose than tight.The only adverse effect of wide clearence is that more oil is thrown on the cylinder walls.Too tight and you may get gaulding or metal transfer from rod to rod or rod to crank.Some times you just have to live with the extra clearence.
Re: Rod side clearance [Re: B G Racing] #236777
02/26/09 07:45 PM
02/26/09 07:45 PM
Fredericksburg Va
P
plycuda Offline
plycuda  Offline
P
Fredericksburg Va
my mgp aluminum rods say .015-.017
