Re: New product idea?
[Re: AndyF]
#2367182
09/07/17 09:30 PM
09/07/17 09:30 PM
crabman173
crabman173
I recently visited a salvage operation that handles all metal from near by army base--they had TONS of tools and fine stuff like new all SCRAPPED--so they can buy new stuff with the budget but anyway--They had a pile of first quality USA made jack stands as big as a garage--$10 a whack I filled the pick up When I asked he said see the "cert" info on them--I looked and it seems they have been recertified for the weight --each one TESTED and re-certed every year --like they were going to go bad--well they do--so they were all scrapped-- I am guessing the tax payer spent a fortune buying them--then paid every year to have them re certed--then they scrapped them anyway--the best cared for jack stands in the world went bad so.......you want to go into the stand business?? Sell them to the ARMY You will be rich beyond your wildest dreams--To Hell with the public
[Re: cb1289]
#2367206
09/07/17 10:14 PM
09/07/17 10:14 PM
Posts: 52,972 Romeo MI
MR_P_BODY
I made up a set much like Andy's about 8 years ago when I built my Rampage.. they worked great ![wave wave](/ubbthreads/images/graemlins/custom/wave.gif)
[Re: AndyF]
#2367220
09/07/17 10:31 PM
09/07/17 10:31 PM
Posts: 625 Oakville, Wa
HOTMOPR
Oakville, Wa
Better have your rear splines dead nuts if you have a spool in the rear..
67 Barracuda, 470" B, Glide, FuelTech FT600, Precision, Ptc, QA1, Calvert, Smith racecraft, Afco, Dana 60. 275 radials
[Re: HOTMOPR]
#2367400
09/08/17 12:06 PM
09/08/17 12:06 PM
Posts: 2,776 Ontario Canada
MattW
Ontario Canada
Better have your rear splines dead nuts if you have a spool in the rear.. Wow Good point! Could you pull the axle and have enough adjustment with the splines? Matt
[Re: AndyF]
#2367408
09/08/17 12:26 PM
09/08/17 12:26 PM
Posts: 10,031 Frostbitefalls MN (Rocky&Bullw...
gregsdart
I would drill a couple of holes and add bolts or something to put tools about mid height so alignment home made tools , like 24 inch 1/2 inch square rods for alignment and levels for caster and camber. I drape two tape measures over the rods at 24 inch apart for doing toe in.
[Re: gregsdart]
#2367463
09/08/17 02:22 PM
09/08/17 02:22 PM
Posts: 472 Minnesota, USA
humpty
Minnesota, USA
I would drill a couple of holes and add bolts or something to put tools about mid height so alignment home made tools , like 24 inch 1/2 inch square rods for alignment and levels for caster and camber. I drape two tape measures over the rods at 24 inch apart for doing toe in. I like that idea a lot too!
[Re: HDNMOPERS]
#2367585
09/08/17 07:41 PM
09/08/17 07:41 PM
Posts: 3,095 Idaho
Runner
Idaho
I would be interested. Any chance you do a dual pattern. 5x4.5 and 5x5 patterns. Any chance you could throw in a set of your billet big block valve covers too. I'm joking. But yeah I'm interested in a set of those stands. are the valve covers available? i looked on your sight a week or so ago to see what a price for a set would be.
[Re: HDNMOPERS]
#2367606
09/08/17 08:33 PM
09/08/17 08:33 PM
Posts: 31,105 Oregon
AndyF
I would be interested. Any chance you do a dual pattern. 5x4.5 and 5x5 patterns. Any chance you could throw in a set of your billet big block valve covers too. I'm joking. But yeah I'm interested in a set of those stands. Yes, I think the next batch of hub stands will have multiple bolt patterns. 4, 4.5, 5 and maybe even 5.5. If it fits why not. I'll also add holes for a caster mounting bar as well as a couple of holes to mount a bar for measuring toe in. All of that seems easy to do. I'll cut a bunch of weight out also to reduce shipping cost.
[Re: moparx]
#2367651
09/08/17 10:31 PM
09/08/17 10:31 PM
Posts: 2,744 541 slobovia
A990
541 slobovia
Better have your rear splines dead nuts if you have a spool in the rear.. a way around that would be to drill the axle bolt holes oversize, then use flange nuts with large, grade 8 washers to attach the stands to the axles. this would not affect strength of the stands, nor the attaching point strength. The nascar example only shows two lugnuts. I dont think you need to build it for the full lug count Shear off the upper lug half of the bracket, and use it upside down on the lower lugnuts. You would only need to oversize the lower holes to allow for spool setups. (Hope this makes sense)
