Re: superperformance valve cover gaskets
[Re: fast68plymouth]
#2365485
09/04/17 10:42 PM
09/04/17 10:42 PM
Posts: 31,081 Oregon
AndyF
The Fel-Pro 1612's work excellent for rpm heads and mp cast valve covers.
The big down side with them for me has been.......after they have been installed a while, when you remove the v/c, it usually tears the gasket, and you need to replace them.
I've had good results with the moroso gaskets on Indy heads using Indy v/c's, with studs and nylock nuts. I squish them down a little and call it good.
I'm jealous of how clean that engine bay is!!!
Next engine you do an engine with Indy covers try a set of the Cometic rubber coated steel gaskets. The Cometic gaskets are a step or two better than the Moroso gaskets. I've thrown all my Moroso gaskets away and switched all of my engines over to the Cometic gaskets. Zero leaks even after having the covers on and off a bunch. And the Cometic gaskets will hold a bunch of pan vacuum.
[Re: Sxrxrnr]
#2365487
09/04/17 10:44 PM
09/04/17 10:44 PM
AndyF
Unfortunately my bad luck, exactly the one's I have recently used on my BB Edy aluminum head, MOPAR performance aluminum valve covers. Both sides at rear bottom bolt seep no manner how tightly I cinch them and how often. It does seem that I can always get another half turn of the bolts as it appears this gasket has infinite crush capabilities. Had switched from cork for re-usuability which had only leaked a very modest amount on right rear cover,,,which was corrected with a dab of silicone black at that point. Moroso's, I have never removed but about to give them the silicone treatment,,,,but am uncertain if will do any good as they are now oil soaked. If this fails, back to cork I go. Yes I suspect that valve cover machining may be questionable too and in that is where my Moroso problems lie. Particularly as others are having success. With a nice clean engine compartment like that you should consider tossing the MP valve covers and getting some nice billet covers. Not sheet metal covers, billet ones. Like these:
![Name: DSC_9660 (Large).JPG
ID: 296953 DSC_9660 (Large).JPG](/ubbthreads/ubbthreads.php/ubb/download/Number/296953/filename/DSC_9660 (Large).JPG)
[Re: mopar dave]
#2365531
09/04/17 11:55 PM
09/04/17 11:55 PM
fast68plymouth
So. Burlington, Vt.
Dave......you do have some breathers on the motor, right?
Andy.....what's interesting on the mp cast covers is.......they seem to work just fine on stock heads with the normal Fel-Pro cork gaskets. I just silicone the gasket to the v/c, and I have been able to R&R the v/c's numerous times.....no leaks at all.
[Re: AndyF]
#2365620
09/05/17 03:21 AM
09/05/17 03:21 AM
Posts: 1,272 Northern Calyfornua
Sxrxrnr
Northern Calyfornua
Unfortunately my bad luck, exactly the one's I have recently used on my BB Edy aluminum head, MOPAR performance aluminum valve covers. Both sides at rear bottom bolt seep no manner how tightly I cinch them and how often. It does seem that I can always get another half turn of the bolts as it appears this gasket has infinite crush capabilities. Had switched from cork for re-usuability which had only leaked a very modest amount on right rear cover,,,which was corrected with a dab of silicone black at that point. Moroso's, I have never removed but about to give them the silicone treatment,,,,but am uncertain if will do any good as they are now oil soaked. If this fails, back to cork I go. Yes I suspect that valve cover machining may be questionable too and in that is where my Moroso problems lie. Particularly as others are having success. With a nice clean engine compartment like that you should consider tossing the MP valve covers and getting some nice billet covers. Not sheet metal covers, billet ones. Like these: Very high tech and what's more,,,very pretty. My wife might even let me set this in the living room.
[Re: mopar dave]
#2365695
09/05/17 11:13 AM
09/05/17 11:13 AM
Posts: 12,592 Great Neck,LI,new york
hemi-itis
You need to check the valve cover with a straight edge,if they ain't flat and you can't make them flat,then you need the 1/2 inch thick gaskets so you have room to crush,,,,,,don't ask how I know ![violin violin](/ubbthreads/images/graemlins/custom/violin.gif)
[Re: mopar dave]
#2365838
09/05/17 03:28 PM
09/05/17 03:28 PM
Posts: 3,675 Akron, Ohio U.S.A.
roadhazard
Akron, Ohio U.S.A.
Boy has this thread gone off the rails.....
MoparDave has a tech question about one of my products and I come on here to assist him in resolving the issue and diverts to Mopar Performance valve covers, this brand gasket, that brand gasket, pimping billet valve covers, etc..
When someone purchases from Superformance Products they get real, honest and cohesive tech support direct from the manufacturer. Take advantage of that benefit.
Posting an issue on a web forum muddies the water with expert "opinions" and can take hours or even days with back and forth questions and answers when a 5 minute phone call can get someone on track. I simply can not sit here and monitor moparts for everything that goes on or every question that may arise, it's just a side benefit that I'm a member who enjoys the hobby and willing to help where and when I can.
Dave, call me @ 866-925-78 five five and lets get the answers to your questions handled!
Thanks for your support
[Re: mopar dave]
#2365895
09/05/17 04:49 PM
09/05/17 04:49 PM
fast68plymouth
So. Burlington, Vt.
Boy has this thread gone off the rails..... Just the nature of the beast Greg.
[Re: mopar dave]
#2366043
09/05/17 09:17 PM
09/05/17 09:17 PM
Posts: 12,296 Benton, IL.
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
Personally, I don't think this thread got off the rails. Although, that does happen a lot around here. The OP asked a question of the members and the answers have been relatively on target. I like and use Superformance gaskets.....in certain places. They are the ONLY thing that I have found that can stop my intake from sucking oil. But their valve cover gaskets leaked on my Hemi. Fel Pros stopped the leaks. I think because they were softer. Plus they are a lot cheaper. I do have to torque them occasionally. And I change them when I adjust the valves. Works out to about $15 a year. But the oil stays in the engine now. Just my ![twocents twocents](/ubbthreads/images/graemlins/custom/twocents.gif) .
Master, again and still
[Re: mopar dave]
#2366045
09/05/17 09:20 PM
09/05/17 09:20 PM
roadhazard
Akron, Ohio U.S.A.
No reason to be sorry and I know you are not knocking anything, just need a little bit of help and I'm more than willing to give it. Just give me a call. It's just much easier and more productive to have a conversation over the phone than go through every little technical detail that may or may not be pertinent to you while pecking away at a keyboard while others take the conversation off into la la land. For those injecting the greatness of the 1612 (made of pulp fiber aka paper) I'd guess have never seen or used our Carbon-X that have been out for 4 years this month and have become very very popular. Posted 9/17/13 https://board.moparts.org/ubbthreads/ubbt...tml#Post1503062
[Re: mopar dave]
#2366088
09/05/17 10:33 PM
09/05/17 10:33 PM
Thumperdart
State of confusion
Getting the covers off now. Let me get a hard look at the flanges and ill call. Once you tighten em up a couple of times, you'll notice they will need to go back on into the same impregnation they made to seal and you can feel it when it's right........
