Re: Engine building: what's commonly overlooked?
[Re: DGS]
#2365353
09/04/17 07:13 PM
09/04/17 07:13 PM
Posts: 20,203 PA.
pittsburghracer
"Little"John
"Little"John
PA.
How important it is to clean, clean, and clean again.
[Re: Adobedude]
#2365366
09/04/17 07:41 PM
09/04/17 07:41 PM
Posts: 96,666 On The Boat, On The Lake, Wa. ...
amxautox
Still Retired. Still Posting on Moparts. A Lot.
And just how much overtime at work is needed to get that $$$$.$$$. Took 6 months of CONSECUTIVE weekend overtime AND every workday to do the AMX, with more weekend work now and then after that. Yes it was more than just the engine but still, it'll cost more than you'll first figure.
Tom
"Everyone should believe in something; I believe I'll go fishing."
-Henry David Thoreau
Men and fish are alike. They both get into trouble when they open their mouths
author unknown
[Re: pittsburghracer]
#2365367
09/04/17 07:42 PM
09/04/17 07:42 PM
Posts: 11,769 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
How important it is to clean, clean, and clean again. This. And take nothing for granted.
[Re: DGS]
#2365403
09/04/17 08:35 PM
09/04/17 08:35 PM
Posts: 2,815 Sobieski Wi
bee1971
Sobieski Wi
Patience
Because I have none , especially when told something completely different
How long should it take from dropping a short block off at your engine rebuilder
Them ordering all parts
Machine work on that block
Assembly of that short block
Time to get the Snowmobiles out soon
1971 Dodge Charger Superbee 2011 Ram Sport 1500 Quad Cab Deep Water Blue Loaded Siberian Huskies
[Re: DGS]
#2365414
09/04/17 08:55 PM
09/04/17 08:55 PM
Posts: 14,515 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
My approach is.......assume none of it is right, or that any of it fits.
Don't be surprised if everything needs to be tweaked/fixed/massaged/adjusted.
In many cases, you're assembling a pile of parts that were never even in the same room until they arrived at your place, much less have been all bolted together and expected to actually run and live and make power.
I'm still surprised pretty often by some of the stuff I get that's made wrong and doesn't fit properly.
If you're trying to make some power, and you're intent on putting the motor together yourself.......try and learn.....and really understand.....what you're doing with regards to degreeing the cam.......especially if it's a custom grind. There is every chance lining up the dots will not have the cam installed at the desired c/l.
Every time I hear someone give the advice to just "advance the cam" I just cringe. This is often being given to someone who didn't degree the cam in the first place.....but they're being told to advance it(advance it to where from where?) Know where your cam is installed, and leave that question mark out of the equation.
Along the same lines, verify the TDC mark on the damper is aligned with the "0" on the timing tab.
[Re: bee1971]
#2365420
09/04/17 09:00 PM
09/04/17 09:00 PM
Posts: 20,203 PA.
pittsburghracer
"Little"John
"Little"John
PA.
Patience
When I was 20 years old I waited 13 months for one from a local mopar EXPERT. After I picked it up from him I told him I would never wait for an engine again, and never have. It takes me 2-7 days to get get my blocks machined then I take over doing everything else myself. Best thing I've ever done was learn how to build engines. At 61 years old I taught myself (with a Friends help) how to do my own transmissions.
[Re: DGS]
#2365489
09/04/17 10:48 PM
09/04/17 10:48 PM
Posts: 31,100 Oregon
AndyF
what are the most commonly overlooked steps/items when building an engine? Such as forgetting to take a measurement or forgetting to install an oil plug. Most common overlooked item is documentation. Very few people actually keep track of part numbers used, dimensions, clearances, etc. After a few months they don't remember what valve springs they used, what the bearing clearances are, what the ring gap was set at, which parts they used, etc. Then when they have a problem they have to start over.
[Re: Moparteacher]
#2365490
09/04/17 10:49 PM
09/04/17 10:49 PM
Posts: 10,559 Rittman Ohio
fourgearsavoy
Rittman Ohio
If you are building a stroker mock up the entire engine without rings and gaskets to check all clearances and measurements before your final cleaning and assembly. Then when you have done all your final measurements and grinding on the block and heads for pushrod and connecting rod clearance take it apart and clean it all again. Keep cleaning it until the white paper towel comes clean when wiping all your fingerprints off of everything. I always fit the cam first before anything else goes into the engine. Finally NEVER EVER install an oil pump out of the box without deburring and cleaning the passages first. I always "port and polish" my oil pump passages with a small dremel tool when I clean it and make sure the relief valve works smoothly. Building your own engine is just about the most rewarding thing you can do for yourself Gus
64 Plymouth Savoy 493 Indy EZ's by Nick at Compu-Flow 5-Speed Richmond faceplate Liberty box Dana 60
[Re: dvw]
#2365496
09/04/17 10:52 PM
09/04/17 10:52 PM
Posts: 20,203 PA.
pittsburghracer
"Little"John
"Little"John
PA.
Leave the "beer drinking" for the winners circle pictures.
Or late night around the campfire at the track with Friends.
[Re: AndyF]
#2365498
09/04/17 10:54 PM
09/04/17 10:54 PM
fourgearsavoy
Rittman Ohio
what are the most commonly overlooked steps/items when building an engine? Such as forgetting to take a measurement or forgetting to install an oil plug. Most common overlooked item is documentation. Very few people actually keep track of part numbers used, dimensions, clearances, etc. After a few months they don't remember what valve springs they used, what the bearing clearances are, what the ring gap was set at, which parts they used, etc. Then when they have a problem they have to start over. I was trying to find the engine build sheet from the SA engine book to copy. I have found it before but I cant find it now. It has the most complete list of items to check that you wil ever need. Gus
[Re: fourgearsavoy]
#2365512
09/04/17 11:21 PM
09/04/17 11:21 PM
RapidRobert
Mockup the eng complete from head to toe with gaskets. barely snug the heads so you can still use em. Have the gaskets dry. confirm that everything/all parts fit dead on. Have all your mods/tricks/additions/checks finished. then dissassemble & clean/oil & go back together. there is nothing worse than haveing to make chips on something in the middle of your final assy when something ain't right.
