1969 3 speed wiper wiring harness #2365510
09/04/17 11:15 PM
09/04/17 11:15 PM
Ks
P
pullandrag Offline OP
P
Ks
Yep it's all in the title is it available anywhere?All I got from the guy is a busted up pack rat chewed up mess I see two speed harnesses but I know that won't work any info would be great but my gut is telling me this is N/A??
Re: 1969 3 speed wiper wiring harness [Re: pullandrag] #2365568
09/05/17 12:44 AM
09/05/17 12:44 AM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
The 3-speed switch uses the 2-speed connector plus a single wire connector. The extra connector is already on the harness but taped up if only using a 2-speed switch/motor. Find the appropriate color coded wire in the schematic in the FSM and you'll find it on the harness. And its also already in the bulkhead connector.
Re: 1969 3 speed wiper wiring harness [Re: pullandrag] #2365619
09/05/17 03:19 AM
09/05/17 03:19 AM
Ks
P
P
Ks
Wow ok.,what do you do with the ballast wires?Thanks so much for the education
Re: 1969 3 speed wiper wiring harness [Re: pullandrag] #2365652
09/05/17 09:01 AM
09/05/17 09:01 AM
Mass
charge70 Offline
charge70  Offline
Mass
2 speed wiper motors have a separate wiring harness from the bulkhead connector to the motor.3 speed motors the harness is part on the wiper motor and as far as I know not available separately. You could find a core motor and cut the harness off and splice onto your motor or just find a working motor w/harness and install
1970 Dodge Charger R/T S.E. 1969 Dodge Dart GTS 440 M-Code 1970 Dodge Charger 500 383/4-speed w/A.C.
Re: 1969 3 speed wiper wiring harness [Re: pullandrag] #2366252
09/06/17 09:01 AM
09/06/17 09:01 AM
Canada
ACR2000 Offline
ACR2000  Offline
Canada
As Charger70 said, it is part of the 3 speed wiper motor.
You will need a Brown / green / blue and red wire
Shoot me a e-mail I will help you out
stephan.fournier@videotron.ca
Stephan
Re: 1969 3 speed wiper wiring harness [Re: pullandrag] #2366652
09/06/17 10:04 PM
09/06/17 10:04 PM
Ks
P
P
Ks
So in other words nothing about the two speed bulkhead harness will work to the 3 speed wiper motor like Stanton said?
Nobody reproduces the three speed harness? I know only part of it is attached to wiper motor I need the other end the goes to it from bulkhead and plugs into ARC2000s pic
Re: 1969 3 speed wiper wiring harness [Re: pullandrag] #2366760
09/07/17 01:18 AM
09/07/17 01:18 AM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
Shoot ARC2000 an email. If anyone has those pieces it'll be him.
If worse comes to worse and you can't find the male plastic connector you can use the bare terminals with a bit of heat shrink to insulate them from each other (until you eventually find that part). You can use the original bulkhead connector - just pop the pins out and plug in your new wires.
My guess is if Stefan has one end of the connector he's sure as hell got the other!
Re: 1969 3 speed wiper wiring harness [Re: pullandrag] #2367187
09/07/17 09:37 PM
09/07/17 09:37 PM
Ks
P
P
Ks
Thanks Stanton
Re: 1969 3 speed wiper wiring harness [Re: pullandrag] #2367207
09/07/17 10:16 PM
09/07/17 10:16 PM
Ks
P
P
Ks
Thanks Stanton
