Re: Floor jack pads [Re: floridian] #2368066
09/09/17 10:50 PM
09/09/17 10:50 PM
New York
rarefish Offline
rarefish  Offline
New York
Originally Posted By floridian
I just saw an article on building these using left over pieces of composite decking..
For half A$$ rigging, they didnt look to bad..
Good material to use and you can make em with your saw...
I saw that too. It was in Rock Auto's latest news letter on line.
Re: Floor jack pads [Re: cdstl] #2368195
09/10/17 10:11 AM
09/10/17 10:11 AM
STL
cdstl Offline OP
cdstl  Offline OP
STL
The ones that I got won't work. The slot that's in them is not deep enough and the pad will still squish the pinch weld when you try to jack the car. I'm only out $7 shipped. It looks like most of the other ones for sale are similar.
Can you post the link using the composite decking? I'm not finding much doing a Google search.
Maybe I'll try a hockey puck.
1972 Cuda 340 4 speed, 2001 Ram CTD 4x4 6 speed, 1970 Duster 408 4 speed, 1996 Ram 5.9 2x4 auto, 1965 Coronet 500
Re: Floor jack pads [Re: cdstl] #2368234
09/10/17 11:43 AM
09/10/17 11:43 AM
moparx Offline
moparx  Offline
years ago, i made some pinch weld pads for a floor jack from "unistrut" material. that's the stuff that comes in 8foot [and longer] lengths that have a bunch of slots in it. it is about 1 1/2" square channel, made from .100 or so thick material with rolled edges at the channel opening. i cut these in 8" [or so] lengths, and welded a plug that fit my floor jack in the middle of the piece opposite the channel opening. no padding on the top side, but these things worked surprisingly well on solid rockers, and the pinch weld lip had lots of clearance. don't know if i have pics of these or not. i'll have to check.
beer
Re: Floor jack pads [Re: rarefish] #2368265
09/10/17 01:01 PM
09/10/17 01:01 PM
Lost and Spaced
bboogieart Offline
bboogieart  Offline
Lost and Spaced
Not sure what you mean by "composite".
If it's the stuff made out of recycled milk bottles,
I used to run the extrusion machine that makes it.
I wouldn't trust it not to crumble or collapse under the weight.
If there is another materiel I don't think I've seen it...
I have mechanical Aptitude.
I can screw up anything.
Re: Floor jack pads [Re: bboogieart] #2368323
09/10/17 02:18 PM
09/10/17 02:18 PM
Lakeland FL
floridian Offline
floridian  Offline
Lakeland FL
The "FAKE" wood for decks..
Re: Floor jack pads [Re: floridian] #2368329
09/10/17 02:40 PM
09/10/17 02:40 PM
Lost and Spaced
bboogieart Offline
bboogieart  Offline
Lost and Spaced
That's what I used to manufacture.
It's made from recycled milk bottles.
I doubt it's stable enough to hold up under that weight repeatedly.
When used to build decks or picnic tables, it needs a lot of supporting structure. The wood joist at 16" on center will hold up a 2X6 board for a long time. When made into benches and pic nic tables it needs a metal sub-frame. Even then it can start to sag. Especially if left in the sun.
Re: Floor jack pads [Re: bboogieart] #2368924
09/11/17 05:34 PM
09/11/17 05:34 PM
Berwyn, IL
challenger70 Offline
Berwyn, IL
Re: Floor jack pads [Re: cdstl] #2369824
09/13/17 12:52 AM
09/13/17 12:52 AM
Jefferson State
srt Offline
ESYC
srt  Offline
ESYC
Jefferson State
I bought These <- click earlier this year.
